Question about Gateway FPD 1730 17" Flat Panel LCD Monitor
Video jumps up about 3 lines
Searched google using "FPD1730 monitor jumps" and found that others are also reporting this issue. Was not able to find the entry or answer in Fixya.
  • Dileep Keshavanarayana
    Dileep Keshavanarayana May 11, 2010
    tell me in detail the exact problem...i can solve it
  • Patrick Michaels
    Patrick Michaels May 11, 2010
    Can you more clearly describe the 'jumping' of the video?
  • 983 Answers
Tell me in detail the exact problem...i can solve it
Posted on Feb 12, 2008
6ya staff
SOURCE:
Lg 42ld520, audio is ok, picture has issue. While watching a program, screen became darkened, horizontal lines, wavy split images. Repairable or replace? any guidance would be appreciated.
90 percent of the problems with flat panels comes down the power supply board. Without this actually in my shop there is no way to know for sure but I would try that. If you take the back off you will find the main PS board. Get the numbers off of the board and do a search for the replacement. A great resource for this is Allied Electronics. I use them all the time. The price of the board should be pretty inexpensive so no losing much if you try it out. Good luck.
Dec 05, 2014 | LG 42ld520 42-inch 1080p 120 Hz Lcd Hdtv
Remote will not operate
i have had the same issues with my remote for at least 3 years now. i had given up on it but your question made me curious. i searched google and found others with same problem. their suggestion was to tap on the clear plastic on the face of your reciever. they said it was hard to believe but it works. it is hard to believe and it does work.
Mar 08, 2014 | Kenwood VR-507 Receiver
Line screen
Try connecting an external monitor to your computer and observe if the external monitor shows the same issue. If not, then you would need to get the screen of your computer fixed. If there is a line in the screen of the external monitor, then updating the video driver would fix the problem.
Do you want to update it automatically and all other drivers to make sure that everything will be on their working condition? Install RadarSync. Google it.
David
Jun 07, 2013 | Acer Aspire One PC Notebook
Iwant to register my new mrter
I have searched and searched and could not find anything about registering your A & D One-touch Blood Pressure Monitor Plus Memory. Even the Owners Manual that I found on line, along with the Warranty information, does not indicate anything about registering the unit.
However, if you want to try to pursue this call 888-726-9966. Maybe they can provide you with more information.
Hope this helps.....
Feb 28, 2011 | One Touch A & D One-touch Blood Pressure...
My monitor has color vertical lines on half the screen
If the monitor is a lcd you have a faulty inverter and it needs to be changed, you can find monitor inverters on a google search stating your make and model, and there some how to's again if google searched how to change the inverter.
If the monitor is a CRT then its possible the tube circuitry is failing and it would be worth investing in a new monitor.
Jan 20, 2010 | Office Equipment & Supplies
I am getting power and the monitor turns on and
It is a hardware problem. So you can repaired it from service center.
Nov 09, 2009 | Gateway FPD 1730 17" Flat Panel LCD...
Gateway LCD powers on but has no picture
To solve your problem you can go to any rad shack or electronics store and pick up a DVI-AVG adapter. The're about $14.00.
Jan 16, 2009 | Sceptre X9G Komodo IV 19" Flat Panel LCD...
Red Vertical lines on 15" Acer LCD Monitor
I think this is most likely a monitor problem. Can you try a different monitor of computer to the monitor? That would help pinpoint the problem. Is it under warranty?
Sep 17, 2008 | Acer AL1715 (Black, Silver) 17" LCD...
Green Light, no Display - Gateway FPD1730
I picked up a FPD1730 monitor for free which was just sitting out in my apartment hallway. I suspected something was wrong and sure e**ugh there was ** backlight, but I could see faint video when I shined a flashlight on it.
A quick Google search of the inverter model # led me to a German forum which suggested replacing the fuse labeled "F1" on the inverter board. I don't have a matching fuse on hand but I bridged the connection with a wire and sure e**ugh the backlight came back on. Short-circuiting like this is definitely **t 100% safe but if you can find a 4A fuse then it's a really cheap and quick fix.
Jul 29, 2007 | Gateway FPD 1730 17" Flat Panel LCD...
Open Questions:
See all Gateway FPD 1730 17" Flat Panel LCD Monitor Questions
Gateway FPD 1730 17" Flat Panel LCD Monitor Logo
51 people viewed this question
Top Gateway Computers & Internet Experts
Ekse
Prashant M
Prashant M
Thomas F. Schneider
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
