Question about JVC HD-56G786 56" Rear Projection HDTV
RE: PICTURE QUALITY
I PURCHASED MY 56" JVC AROUND CHRISTMAS 2006. THE AVERAGE RUN TIME PER DAY APPRX. 3-HOURS. JUST IN THE
LAST MONTH THE PICTURE HAS BEGUN TO FLASH A BLUE
BACKGROUND AFTER RUNNING ONLY A SHORT PERIOD OF TIME.
AT TIMES THE SCREEN WILL FLASH FROM NORMAL TO THIS
BLUE BACKGROUND AND BACK TO NORMAL AGAIN. THIS MAY
HAPPEN WITHIN A FEW SECONDS, OR THE PROCESS MIGHT
TAKE AN HOUR TO CORRECT ITSELF. SOMETIMES IF I LEAVE
THE TV ON, AND JUST TURN OFF THE DIRECT TV RECIEVER
FOR A FEW SECONDS IT WILL COME BACK UP NORMAL. BUT
NOT ALWAYS, IF I TURN THE TV OFF FOR A FEW SECONDS
IT WILL CORRECT ITSELF ALMOST EVERY TIME. BUT IT DOES
NOT LAST. IT ALSO SEEMS TO BE MOST COMMON WITHIN THE
FIRST HOUR OR SO. PLEASE HELP, I LOVE THIS TV AND THE
PICTURE WHEN IT WORKS. THANKS.
Thank you
Posted on Feb 03, 2008
6ya staff
SOURCE:
After how many hours a week a employee is considered full time ?
By US federal law a full-time employee is one who works on average at least 30 hours per week, or 130 hours per month.
Nov 06, 2015 | Computers & Internet
How do I find out a percentage of a number
You likely mean this to be the 'Average' number of employees per day rather than percentage. However you need to work out based on hr's per day that each employee can work. Lets assume though that they work full time, 8hrs per day. Then you would work out as follows:
3223.5 /8 /28 /306 = 0.047 employees per day
If they only work 1 hr per day it would be:
3223.5 /28 /306 = 0.376 employees per day
Each employee would need to work:
3223.5 /306 = 10.53hrs per month
Mar 02, 2015 | Office Equipment & Supplies
JVC HD-56FN97 when turned on blue light is solid,red ligt blinks a few times and goes out. My picture is very dark despite adjustments I make in the menu, any help or feed back apreciated.
The set does use a lamp for a light source and average life is 2 years or 2000 hours---many lamps before they actually fail get to be darker.
Dec 04, 2012 | JVC HD-56FN97 56" Television
How much would it cost to run this computer for 24 hours? just an estimate is fine
Wattage is simply calculated by multiplying voltage by amperage. Look on the back of your system, and it will say how many amps the system uses. Often, it will also provide the wattage. For instance, the back of a ViewSonic E220 is 2.5A at 120V - ~300 Watts/Hr. An average rate is 10 cents per kilowatt hour, or 3 cents per hour to leave your monitor on. or 72 cents per day.
A computer system can use between 150 and 600 or more watts per hour. Together, it could cost between $20 and $60 a month
Read more: Click Here
* Please rate this solution with Thumbs up and Testimony to help us improve providing support
Jan 06, 2011 | HP Compaq Presario SR5350F Desktop PC...
Can i use the timer for a water headter to trun on and off
Paragon 8145-20 is a 240V defrost timer
It is probably not best choice for water heater timer
Timer initiates defrost cycles each 4 hours.
A water heater timer should have more scheduling options.
-For example estimates show average run-time for water heater is 3 hours per day, depending on incoming water temperature, thermostat setting, and number of gallons used.
-To save money using water heater timer, you have to schedule times carefully so water heater runs less than 3 hours per day.
-Now your average electric water heater heats about 20 gallons per hour.
-Average shower uses 4-9 gallons hot water, so water heater needs to run 15-30 minutes (15 summer, 30 winter)
-Average bath uses 12-15 gallons hot water so water heater runs 45-60 minutes
-But lets say you run water heater for 1 hour and make 20 gallons of hot water. Then you take a shower, expecting hot water to remain in tank.
-Here's the problem ... cold water entered the tank to replace the shower water ... and the new cold water is cooling the rest of the tank.
-So a timer means scheduling hot water to match shower and bath events. For example taking shower and bath in immediate succession.
-Or set the timer for each individual hot water event ... for example set timer for 1/2 hour for shower, and later timer turns on 1 hour for bath, or 1-1/2 hr for 2 baths, etc
-> The flexible programming described above is not a characteristic of defrost timers.
I suggest Intermatic WH-31 240V or Intermatic T-104 240V or GE 15207. These are mechanical repeat-24 hour timers with manual override where each day has same schedule.
Digital programmable timers like Intermatic EH40 offer 7-day, 40 event programming. Weekends and weekdays can be different.
To see several box-type timers:
http://waterheatertimer.org/Boxtype.html
Sep 29, 2010 | Paragon 8145-20 Defrost Timer
Samsung dlp has dark picture?
It sounds like your lamp is about to die out,this tv lamps are good for 6000-8000 life hours witch is a average time of 2-4 years old and with time the picture starts to get darker and darker until one day black screen here is a link with the lamp you need
http://www.discount-merchant.com/SearchResults.asp?Search=BP96-00608A
Sep 03, 2010 | Samsung DLP HL-P5663W 56" TV
What are the average amp hours used per week on the model mcbr415s
HELLO THERE
I WILL SEND YOU A COUPLE OF SHEETS TO CALCULATE THIS OK
  1. Alphasolar: System load sizing worksheet Calculate your average amp-hours per day requirement ... This is your average amp-hour requirement per day that will be used to size your ...alphasolar.com/alpha_solar_089.htm - Cached
Sep 12, 2009 | Refrigerators
Dim monitor
5 years old, lamps are good for about 50 000 to 60 000 hours of life you would have to do the math based on average number of hours per week/month and see where your are, several things to check initially are inside look for blown capacitors, you can find images all over the net Google "blown capacitor image" and you will see what to look for.
Next could be inverter failure as they get old and work pretty hard. Last the ccfl lamps may be dieing of old age like the florescent lamps in buildings, they get burnt at each of the ends and have a hard time lighting up.
let me know what you find.
Apr 20, 2009 | ViewSonic VE710b 17" Flat Panel LCD...
VW PASSAT BRAKE COST!
ROTORS WILL RUN ABOUT $60-80 PER ROTOR. PREMIUM PADS RUN ABOUT $40-70 PER PAD. PLUS ABOUT 3-4 HOURS OR SHOP TIME AT AN AVERAGE OF $60-70 PER HOUR
I DO SUGGEST CALLING 3-4 OTHER SHOPS NEAR YOUR AREA AND GET AN ESTIMATE FROM THEM AS WELL.
Mar 31, 2009 | 2002 Volkswagen Passat
JVC HD-56G786 56" Rear Projection HDTV Logo
210 people viewed this question
Top JVC Televison & Video Experts
Todd Hill
Todd Hill
matt martin
matt martin
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
