Question about Mr. Coffee ECM20 Espresso Machine
Coffee tastes burnt/No steam for froth
After I brew espresso in my ECM20 I turn the knob to steam the milk, but nothing happens. No steam or water comes out. The espresso also tastes burnt to me but that's not a new problem, it's always tasted burnt when I make espresso based drinks. Anyone else having this problem?
  • 1 more comment
  • JJsAhBoo143 Feb 10, 2008
    I haven't tried this yet, I need to buy some of that solution. Thanks for your help!!!!!!!!!!!!!!
  • mamagroomer2 May 16, 2009
    I cant figure out how to use the frothing system on my ECM20?? Anyoen know how??? BTW Vinegar and water help clean out coffee pots VERY WELL! Just re-do the cycle 2 or 3 times to get the vinegar-ry taste out!
  • Anonymous Mar 30, 2014
    using starbucks dark roast espresso on standard espresso setting
I have the same problem! help!!!!
Posted on Oct 15, 2009
  • 2,039 Answers
So i guess our expresso you dont have that creamy topping that lack pressure descalcify not with vinegar remove caicium in chunks have a chance of blocking everything descalcifier solution melt the calcium 1part solution 1 part water fill the water with solution open the valve if some come out close it leave the solution in it for 15 minute repeat untill empty rinse very good cheers
Posted on Feb 03, 2008
DISPENSING SPOUT ON ECM20 IS CLOGGED
It's probably clogged up with hard water deposits. Fill the water reservoir with plain white vinegar and put the espresso pot in place as usual, but do not load coffee! Run as usual for making espresso.You may have to run a couple of tanks, until the vinegar is pretty much colorless. Then run a couple of tanks of water to flush the vinegar. If your machine has a steam valve for frothing milk, put the steamer pot under it and open the valve as well. Over time, the steam valve can clog up with milk solids, called casein, which is actually a form of organic plastic.
Dec 08, 2013 | Mr. Coffee ECM20 Espresso Machine
After frothing the milk it can take ages to reset back to prepare black coffee again. Both lights flash green for up to 15minutes before being ready to make another cup. Does anyone know why?
Hi Jan, This happens because the machine is too hot, due to higher heat being required for the frothing. After frothing, press the button as if you would want to brew a cup,I should blink. At that very same time, turn the steam knob fully open to let some steam out, ,which will lower the inside temperature. This should solve your issue.. Good luck, Claudio
Dec 12, 2011 | DeLonghi Esclusivo Magnifica ESAM3300...
DONT KNOW HOW TO USE THE LEFT SIDE
Add water to the left side, tighten well. Put milk in the stainless steel carafe.
Add coffee to the left side container in the filter basket. Place carafe under the coffee container. Turn knob toward you to the 'off' position. Turn power to 'on' on Espresso (left) side. Once coffee is about halfway brewed, place stainless steel carafe with milk under the steamer with spout just below milk line, and turn knob away from you to the 'on' position. Frothing the milk is an art form and becomes easier with practice. Make sure all steam is depleted, then enjoy your cappuccino!
To make espresso, do the above without the milk.
Sep 09, 2010 | West Bend 55108 Espresso/coffee Maker
Saeco Talea Giro no steam or water from spout
I have the same problem as well, talked to a repair shop and it's definitely a "send in" or warranty repair. I was told it's an o-ring issue. I have no water coming out of the steam wand and it goes into the dispense tray instead.
Apr 11, 2009 | Saeco Talea Giro Espresso Machine
Can't get milk to foam
Place 1/3 part distilled white vinegar and 2/3 part water into the water reservoir. Turn the machine on and wait for the heat light to go off. Once the heat light goes off, turn the steam vs. water knob to the water drop icon, and turn the main function knob to steam/water. Make sure to have your frothing cup underneath the steam element ready to catch the water. The vinegar/water solution should clear out the calcium that clogs the steam element. Also, remove the cover to the steam element and dip it in a bowl with vinegar for about 5 minutes, and use something like a pipe cleaner to clean out that cover. Then apply vinegar and hot water to a rag and clean the calcium off the shaft of the steam element. Once you are all finished with this, run plain water through the espresso maker on the steam/water setting to clear out the bitter vinegar residue. Now, try again to make espresso and froth it.
Since milk contains calcium, the steam element has to be decalcified more often than a regular coffee maker. The EM-100 is a beautiful machine, but it is definitely high-maintenance - you will probably spend more time cleaning it than making cappuccino, etc.
-Tha Mp3 Doctor (is also a huge Cuisinart fan)
Feb 22, 2009 | Cuisinart EM-200 Espresso Machine
Sissling when making espresso
First of all, do you steam your milk first then immediately brew the shot? If so, that is your problem. When you depress the steam switch, the temperature elevates way past what is optimal for brewing espresso. If you try to brew immediately after steaming milk or using the hot water feature, that would definitely be why your espresso sizzles. Your shot will likely come out burnt tasting, thin and just plain rancid.
Either brew your shot first (learn temperature surfing for your best shots), or immediately after steaming milk, turn off the steam switch, depress the brew switch (without portafilter in place) for a few seconds until no steam comes out- only water (wait till you don't hear the sizzling sound). Hope this helps.
Aug 07, 2008 | Rancilio Silvia Espresso Machine
I don't know about the burning business but I had the same problem with the steam wand. the first thing I did to solve this problem was to take small object like a needle or safety pen and insert it into the base of the steam wand. (I have feeling that most problems related to the steaming wand are due to deposits clogging the wand itself.) After I cleared out as best I could I used vinegar and water to help remove any calcium deposits. Sure enough, after inserting the needle into the wand steam began to flow again.
Feb 26, 2008 | Mr. Coffee ECM10
Froth control problems
Your vinegar did the job: it as removed the deposits, now these deposits are clogging the four holes porcelain valve.....if the froth lever is not broken.
Remove all the screw you can see on the top and under the top of it, remove the cover, unscrew the frothing device down to the porcelain valve consisting of two 4 holes discs, clean them, and voila!
Dec 22, 2007 | Krups XP 1500 Espresso Machine & Coffee...
Mr. Coffee ECM20 Espresso Machine Logo
456 people viewed this question
Top Mr. Coffee Coffee Makers & Espresso Machines Experts
Greg Cann
Greg Cann
Henry  Thomas
Henry Thomas
Are you a Mr. Coffee Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
