Multifuel stoves can accommodate various fuels including
white gas, unleaded auto gasoline, kerosene, jet fuel and diesel. They tend to
cost more than any other camping stove.
Dave you can use all three types that you have listed.
The pump is typically set for Number 2/ Diesel Fuel and if you run Kerosene the unit will run a little bit hotter but with a 3E359B you will typically run diesel due to the amount it will use and the increased cost of kerosene over diesel fuel.
Number 1 is similar to kerosene and is the fraction that boils off right after gasoline. Number 2 is the diesel fuel that trucks and some cars run on, leading to the name "road diesel". It is the same thing as heating oil.
no please don't mix. disaster waiting to happen. You will be changing flash point. Do not do it.If kerosene hard to come by ,see if you know someone in aviation that can give you sumped jet fuel.
clean all of your filters and the spark plug and go back to useing K1 kerosene. Diesel fuel has a higher ignition temp. burns dirty and has a tendency to gel.
