Question about Whirlpool Duet GHW9150P Front Load Washer
Duet washer leaks during use; rinse cycle?
Hi. My Duet washer, purchased in November 2006, has leaked sometime during the cycle during several of the past few loads. I think it's during the rinse cycle. Any thoughts? Duet Washer is leaking. I have a little water on the floor and some in the drawer underneath the machine as I opted for the drawer kit when I bought the unit. I believe it is about 5 years old. Front gasket by door does not have any cracks in it upon inspection.
Any Ideas??? E-mail is
  • 8,617 Answers
Check the water pump hose connections and the water pumps housing bolts themselves could have loosened from vibration. more likely the hose connections on the pump itself though. Hope this helps.
Posted on Feb 03, 2008
Water has started pouring out from under my washer
Hello, you've indicated this problem only arrises during the rinse cycle, is that correct ? The leak doesn't occur during the wash cycle initial fill level ? I want to distinguish the difference because there has been a repair tip issued by whirlpool for the duet and sport washer's. This may be applicable to your machine. If it is indeed only during the rinse, the problem is within the door assembly. Specifically the glass and it's "seat" to the frame. Let me know, I'll watch for your reply. macmarkus :)
Mar 14, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Kenmore series 70 washer leaks during rinse?
the was exhaust hose is either plugged or cracked. also check the drain it is put into as this sometimes will be puleeged with fabric from the clothes you wash
Jul 10, 2009 | Kenmore 22422 Top Load Washer
Whirpool Duet Sport Washer still making noise now it s leaking
make sure to look really close all it takes is alittle whole in that seal anywhere to cause a leak try to look close while it is running but first dry everything you can and then run it. also make sure your door glass is clean if it is leaking down the front just alittle dirt or hair can cause a leak aswell
Mar 08, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool calypso model GVW9959K-0 leaking during rinse cycle
hi my name is joyce
Sounds like your pump is leaking. if it is leaking when you are on a spin cycle.
now if it is stuck on f1 cycle and wont drain unplug and let stay unpluged for 60 seconds and replug and see if you can restart on drain and spin cycle. let me know if I can help with any other problems.
Feb 06, 2009 | Whirlpool Calypso GVW9959K Top Load Washer
Washer does nothing during rinse then leaks during spin cycle
hi thanks for the question i would check the drain hose your problem is the washer is not draining check the drain hose thanks the appliance doc
Sep 27, 2008 | Maytag Atlantis MAV6000 Top Load Washer
WhirlPool Front Load Washer Leaking
to richhardh..
did u try holding the "End of Cycle Signal" button for 3 ?
May 16, 2008 | Whirlpool Duet GHW9150P Front Load Washer
could have a bad boot seal please post your email here and i will send you the service manual on how to change it
Jan 23, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Duet GHW9150P Front Load Washer Logo
875 people viewed this question
Dan Webster
Dan Webster
Sal De
