Question about Asko W6461 Front Load Washer
Asko 12505 My Asko front loading washer no longer heats water. Is this something I can fix on my own?
  • Ian Roberts May 27, 2008
    I have an Asko 12605 (in Australia) - similar to a 12505 and whenever the temperature dial is at any position other than zero the heater operates but never cuts out, so "cooks" the clothes. When set to Zero it does a cold wash normally (not taking in any hot fill water either) so this looks good. Would this be just a thermostat failure (and could I replace it) or might there be any other compenent (solenoid etc) that may be in the circuit? Can you get circuit diagrams?
    Ian Roberts
  • 126 Answers
It's probably the heater, or the thermostat. You must have a serviceman to fix that:)
Posted on Feb 03, 2008
My Asko 12505 washer keeps heating the water and will not stop. It has even melted the drawer for soap and softener. What can I do?
Stop using it. You are risking a fire or electrocution. Since parts have been melted, I would suggest replacing the whole machine.
Mar 21, 2016 | Asko Washing Machines
Asko 12505 has no power
i assume you checked the fuses with a meter?how old is the unit?
Sep 16, 2007 | Washing Machines
Should I put powder detergent in the tray or in the drum in my Asko front load washer?
But the powder in the tray. I have a asko washer myself
You should to able to go on line and download your manual
Go to Asko.com Good Luck
Feb 12, 2013 | Asko W6461 Front Load Washer
I have an asko 10505 washer. how do you open the door?
here is a video that shows someone closing an Asko machine. I think you just have to get your hand in that place where she shuts the door and pull.
http://www.youtube.com/watch?v=kmvxNwqUDJ8
Mar 28, 2011 | Asko W6021 Front Load Washer
Hi, I have the ASKO W6222 front load washer, my
if the valve was stuck open it would run all the time the washer was on i would say that there is a power short running to the valve turning it on when not selected
sonic boom electronics australia
Jan 04, 2011 | Asko W6222 Top Load Washer
My Asko Front load washer model W6021 Prewash
hi you need to replace the inlet valve,take off the top panel and you will see the valve behind the soap drawer with the black hoses.you can get a book from asko.com.au
Jun 15, 2010 | Asko W6021 Front Load Washer
Have an asco 12505 front load washer. instead of spinning, only rotates back and forth like wash cycle. Why?
may be timer or lower board if it has one,hard to tell without being there,it wont be the motor
Jun 05, 2010 | Asko Washing Machines
Clothes smell.
Mold, mildew and other fun things use washers as a breeding ground. Clean your machine with a generous amount of white vinegar run through a cycle. Or there is a product called Affresh you can buy at Lowes or Home Depot.
Jun 21, 2008 | Asko W6221 Front Load Washer
Asko Washer
I have a 12505 also. It is a 220VAC unit. There are two fuses that are intended to be accessible from the rear. On our unit, these blow every few years and need to be replaced. The unit shows no signs of life when they go. The fuse holders tend to disintegrate from the heat, so I have had to replace these multiple times also.
Nov 20, 2007 | Washing Machines
Asko W6461 Front Load Washer Logo
254 people viewed this question
Top Asko Washing Machines Experts
Gerry Harvey
Gerry Harvey
Oloyede Monsuru
Are you an Asko Washing Machine Expert? Answer questions, earn points and help others
