Question about Alpine CDE-9852 CD Player
No volume the radio has volume but the cd read the disk but no has volume
Hooked up the wrong wires look at your wires again
Posted on Mar 29, 2008
Why is my Insignia ns-b3112 have sound on the radio but no sound on any cd's?
hi have you tried putting a cd cleaner in it because over time the lens which reads the cd can become dusty making it impossible for it to play hope this helps
Oct 14, 2016 | Insignia Boombox NS-B3112
Every time i play the cd player it jumps back to the radio
Did you check if the DVD disk you are trying to play is actually playable? Mabe the player can't read the disk so reboots to radio. Also, you should try with another DVD disk
If disk is ok, recheck your original setup options, but I'm quite sure that it's some electronic failure of your device. Simply should not make sense some hidden option to play radio wnen you select the DVD player.
So your final optin probably should de take your device to repair service. Look at your original warranty for nearest authorized repair service, even if warranty has expired.
Oct 18, 2015 | Clarion NX501 Navigation system with DVD...
Had to jump start car, now no volume through radio, cd, ipod, etc....no volume at all. The system is reading the cd, radio, etc.....just no volume at all. Checked the fuse, it is fine. How do you fix the...
sounds like it is a theft lock device that leaves the radio useless to would be thieves i would check owners manual or contact dealer there mey be a factory default code to fix this
Jun 29, 2010 | 2008 Infiniti G37
Hitachi ext. drive formatted for a PC, but now I want to read it
you need to reformat the drive for MAC...
Use Disk Utility To completely erase a Macintosh hard drive that runs OS X 10.3.x or above—not just individual files on the drive—you can use the Disk Utility that is built into the Macintosh operating system.
How to Use Disk Utility to Erase a Macintosh Hard Drive (OS X 10.3.x or 10.4.x)
  1. You must reboot your computer using the OS X system CD that came with your Macintosh. To do so, follow these steps:
  • Insert the CD into the CD drive.
  • Hold down the C key during the startup process.
  1. Select your preferred language. You will then see the Welcome to the Mac OS X Installer window.
  2. From the Installer Menu Bar, click Open Disk Utility. You will then see the Disk Utility window.
  3. In the left pane of the Disk Utility window, click the drive you want to erase.
  4. In the right pane of the Disk Utility window, click the Erase tab.
  5. From the Volume Format drop-down menu, select Mac OS Extended (Journaled).
  6. In the Name field, highlight the existing text and type the name the hard drive is to be called after it's formatted.
  7. NOTE: If you ever plan to connect another computer running OS 9 to this hard drive, you'll want to install the Mac OS 9 disk driver, so that this disk will be visible from an OS 9-booted computer. If you don't know if you will do this in the future, it's best to install these drivers.
  8. The following are the available security options:
  • Don't Erase Data—This option only rewrites the headers on the disk. Files can be recovered by forensics, disk utilities, and other advanced recovery software.
  • Zero Out Data—There are forensics utilities that, albeit expensive and time consuming, can retrieve zeroed-out data.
  • 7-Pass Erase—This is considered sufficient by government standards to erase data from a disk. It writes random data over the disk seven times. It may take several hours or more to complete this process.
  • 35-Pass Erase—This makes it absolutely impossible to regain any data off the drive. This option takes an extremely long time, possibly more than one day.
  1. Click the radio button in front of 7-Pass Erase (recommended by UD).
  2. Click OK.
  3. Click Erase.
  4. Confirm you want to erase. The program will unmount the volume, partition the drive, and rename the volume to the name you typed in step #7 above.
May 19, 2010 | Hitachi Computers & Internet
Alana cd/mp3 radio doesn't read mp3 cds
I have the same problem with my ibiza. Existing a solution ? This alana radio can read mp3 disk ? Thank you
Mar 01, 2010 | Car Audio & Video
CD WON'T PLAY BOSE SYSTEM SAYS NOT READABLE?????
I assume you have cleaned the lense and the disk can be read in another player. Either the disk is an unsupported format or the disk itself is too old to be read by that unit (some models have weaker lenses, lees tolerant at faults) .
Nov 01, 2009 | Bose Wave Radio
No sound and cd read Paused
I had the same problem a few times. I found that it went into pause mode when the CD was playing and the volume was turned down to zero. Try turning the volume back up. The CD should exit pause mode.
Aug 06, 2009 | 2005 Volvo XC90
Radio want play cd's, keeps reading err.
Try a cd player laser cleaning disk. If you still have errors, restart the radio. Remove the radio fuse in the fuse block wait five minutes the reinstall. Let me know how it goes.
May 11, 2009 | Car Audio & Video
Disk error
if its a burned disk some pioneer units do not read burned movies or music
Feb 12, 2008 | Pioneer AVIC-N2 DVD/CD/navigation receiver...
CD will not play
try to put a paper clip into the reset button benrrth the vol knob
Dec 10, 2007 | Car Audio & Video
Alpine CDE-9852 CD Player Logo
41 people viewed this question
Top Alpine Car Audio & Video Experts
xxxxxx xxx
hoyzee1
Jaime Hernandez
Are you an Alpine Car Audio and Video Expert? Answer questions, earn points and help others
