Related Tags:
This problem should be removed because:
Problem with Procom MN100HPA Heater
heater parts
where can you buy parts for this heater propane lp gas
Solutions (1)
Best Solution
You can contact Master Parts at 800-446-1446. They are the parts distributor for ProCom. I hope this helps you...
Need to convert to LP from Natural Gas
I purchased a Dyna-Glo unvented gas heater several years ago and never used it. Now I may be able to use it if I can convert it to LP gas....
We have a dynna glo zero clearance for Natural Gas
We have a dyna glo zero clearance for Natural Gas that has been run on propane for 3 years and now emits black smoke. Can we convert this to...
I actually have the mn300
I actually have the mn300 natural gas version trying to find away to convert to propane any help would be appreciated
can i switch a model RN30 from natural gas to
can i switch a model RN30 from natural gas to propane?
Add Your Solution
heater grid color
what color should the grids be when burning
can lite pilot, but nothing stays on
Trouble free for a few years, it went out one nite and I haven't been able to re-light the unit. With the pilot...
I just purchased a procom
I just purchased a procom MN300TPA had it hooked up and just started it for the first time. The pilot lit and stays lit...
When I pushed the ignition button to light the
When I pushed the ignition button to light the pilot the button fell through the hole opening where it fits. I have...
thank you i just installed my new heater. it is
thank you i just installed my new heater. it is hooked up to 365 gal propane tank and is the only thing hooked to it. i...
Fix-O-Meter
95
95 people viewed this problem
- 2 people found this problem to be helpful.
- 0 people are following this problem. Be the first!
Top Procom Heater Experts
Verification:
Please enter the characters below to complete your post
Can't read it? Try a different one
