That may not help.
Try this address as most routers can be assessed by it:
www.routerlogin.net
Should that not work try these steps which should definitely work:
For XP:
1) Go to Start, then click Run.
For Vista:
1) There should be a key that looks like a Flag or the Windows Symbol, hold it and press R.
The following is for both OS's.
2) Type in cmd and hit enter.
3) Type in ipconfig and hit enter.
4)
>For Ethernet Connection:
look for Ethernet LAN adapter and under it for Default Gateway.
>For Wireless Connection:
look for Wireless LAN adapter and under it for Default Gateway.
Note down this address and this is what you put into the browsers address bar.
Note: There will be more after Wireless LAN adapter and Ethernet LAN adapter but that is the start of the entry you are looking for.
This should get you to your routers login interface. If nothing is there or it is 0.0.0.0 you need to probably either check your connection to your router or try resetting your router by unplugging and plugging it back in or using the reset button.
Testimonial: "spot on"
Try 192.168.1.1
let me know
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/edwy_1a56970cf1ea4620
