Question about Tomtom ONE GPS Receiver
How to adjust the time on my tom tom one
When I started to switch ON the tom tom one button, there are adjustment to set up the clock, so I started to adjust the button make a slip with my my finger and the time is one hour more then the current time now, so please help me to rectify the problem ? Thank you
  • Anonymous Jun 02, 2008
    tomtom one has the wrong time of day
  • thdrmtboy Nov 08, 2008
    how to adjust the time on my tom tom
  • 504 Answers
If you haven't had the unit long, you may want to reset the factory settings. It will bring the unit back to the way it was when purchased. You will have to change any setting you have adjusted, including the time.
Posted on Feb 04, 2008
Setting the Sharp atomic clock SPC315
Sharp SPC315 Clock Setup Instructions
Set Time Hours and Minutes:
Press Time/12/24 and Alarm1/ON/OFF buttons at the same time for two seconds and it will start to blink the hour.
Press the Adjust/Channel button to change the hour.
Press the Time/12/24 to go to minute
Press the Adjust/Channel button to change the minute.
Press the Time/12/24 to set.
Set Alarm1 and Alarm2:
Press the Alarm1/Alarm2 button to toggle either Alarm1 or Alarm2 to set.
Pres the Alarm1/Alarm2 and Alarm2/ON/OFF buttons at the same time for two seconds and it will start to blink the hour.
Press the Alarm1/Alarm2 to go to minute
Press the Alarm1/Alarm2 to set.
Set Calendar Year:
Press Calendar/C/F and Max/Min buttons at the same time for two seconds and it will start to blink the calendar year.
Press the Adjust/Channel button to change the year.
Press the Calendar/C/F to go to Month.
Press the Adjust/Channel button to change the Month.
Press the Calendar/C/F to go to Day.
Press the Adjust/Channel button to change the Day.
Mar 01, 2015 | Sharp Atomic Weather Station Alarm Clock...
How do I set the alarm on my Sharp Accu-Set Model SPC452?
  • 1 Insert batteries into your atomic clock. Without these the clock won't work. The number of batteries required depends on the clock. There is usually a panel on the back of the clock where you can insert the batteries.
  • 2 Set the clock. Usually, this is done automatically, as the clock will seek out and receive the signal within 6 to 8 minutes. If this doesn't happen, you'll need to do it yourself. Hold down the "Set" button. A figure on the clock will start blinking. Adjust this by pressing the adjustment button. Press "Set" again to go to a new time. Continue until the clock is properly set. No matter what you put time you put in manually, the clock should adjust to the atomic setting within 48 hours.
  • 3 Set the time zone on your atomic clock. How to do this depends on your specific clock. On some, there is a time zone slider; you simply slide it to your time zone. Otherwise, you will need to enter the manual mode you used to set the clock. Switch the mode until the time zone starts blinking. Now, adjust until your current time zone is selected. If it goes by Greenwich Mean Time (GMT), the time zones in the United States are -5 for Eastern time, -6 for Central, -7 for Mountain, and -8 for Pacific.
  • Read more : http://www.ehow.com/how_6403731_instructions-time-zone-atomic-clock.html
    Jan 29, 2015 | Audio Players & Recorders
    How do i change the time on my Tom-Tom
    To select the time format and to set the time, follow these steps:
    1. From the main menu, tap Change preferences.
    2. Tap Set clock.
    3. Select how the time should be displayed and then tap Next.
    4. The easiest way to set the time is by tapping the Sync button. Your navigation device will then take the time from GPS information.
      Note: You can only use Sync if your device can receive a satellite signal, so you cannot set the clock in this way when you are indoors.
    5. After using Sync to set the time, you may have to adjust the hours depending on your time zone and the daylight-saving time.
    May 23, 2011 | Tomtom ONE GPS Receiver
    Clock is 2 hours ahead of actual cst time
    If you have an atomic clock/watch that is not showing the right time, you could have one or two separate problems. First, the clock may not be set for the correct time zone. Second, the clock may have a manual switch to adjust the time for daylight savings time. Each of these problems can make your clock display the incorrect hour of the time, especially after you change the batteries and your clock "forgets" some or all of its prior settings.
    Check the back of your clock to see if there is a button or switch to set the correct time zone. If your clock appears to be set to your time zone, change the switch to another time zone and see whether the clock moves forward/backward to adjust. Once it has finished adjusting to the new time zone, adjust the clock back to your time zone to see whether it will now correctly reset to display the time.
    I have seen atomic clocks that have manual adjustments for these settings as well as ones that adjust automatically other than the time zone. If you provide the manufacturer and model number of your clock, we should be able to provide more detailed instructions.
    May 06, 2011 | Watches
    Need to set clock on oven
    Instructions
      • 1
        Check the oven to ensure that it is off and that the timer isn't running. The buttons used to set the clock are the same buttons that adjust the oven, and you may end up making unintended adjustments to the oven.
      • 2
        Press the "Clock" button to enter the clock setting mode. The LCD will show the current time set on the oven.
      • 3
        Use the "Set Temp/Time +" or "Set Temp/Time -" buttons to adjust the clock to the current time. Depending on your model of stove you may need to use the "Hour," "Min" or the "Temp/Hour" up and down arrow buttons to set the time.
      • 4
        Save the new clock setting by pressing the "Start" button. Depending on your stove model, you may need to press the "Clock" button a second time if the "Start" button does not work.
    Read more: How to Set the Clock on a Whirl Pool Stove ' eHow.com http://www.ehow.com/how_5692616_set-clock-whirl-pool-stove.html#ixzz1H3Wfexf6
    Mar 19, 2011 | Ovens
    How do I change the time on my tom tom
    The clock on your navigation device is automatically synchronised with the satellite clocks. You can also set the clock manually, for example when the device is indoors and unable to receive a satellite signal. The default setting is to automatically adjust the clock for the current time zone.
    How to change clock settings To select the time format and to set the time, follow these steps:
    Open the Main menu and tap Settings.
    In the Settings menu, tap Set clock.
    Select how the time should be displayed, then tap Next.
    When you do not have a satellite signal, you are asked if you want to set the time manually.
    Note: Since you need to be outside for your navigation device to receive a satellite signal, you might want to immediately set the time manually. The device will then set the time automatically when you next take the device outside.
    Tap Yes to set the time manually or tap No to set your device to update the time automatically using GPS satellites.
    Hope this was helpful. Thank you for using fixya.
    Jan 26, 2011 | Tomtom GPS
    What buttons change time display
    How do I set the clock?
    A5
    There are several methods to set the clock, depending on the model.
    Method 1
    Press and hold the BAND and DISPLAY buttons to display the clock
    Press and hold the BAND and DISPLAY buttons until the time display flashes
    SEARCH left to adjust the hours; right to adjust the minutes
    Press BAND button to store the time
    Method 2
    Same as Method 1, except press DISP to store the time
    Method 3
    Press ADJ
    SEARCH left or right to select clock and press ENT
    SEARCH left or right to select the hour or minute
    Turn rotary knob clockwise or counter-clockwise to set the correct time
    Press enter to store the time
    Press ADJ to return to the previous mode
    Method 4
    Press and hold the BAND and FUNCTION buttons to display the clock
    Press and hold the BAND and FUNCTION buttons until the display flashes
    Search left to adjust hours; right to adjust minutes
    Method 5
    While the display is showing the clock, press and hold the CLOCK knob until the minutes flash
    Press the CLOCK knob to adjust the minutes
    When the CLOCK knob is released for 5 seconds, the hours will flash
    Press the CLOCK knob to adjust the hours
    When the CLOCK knob is released for 5 seconds, the time will be stored
    A5
    Method 1
    Method 2
    Method 3
    Press ADJ
    Method 4
    Method 5
    A5
    Method 1
    Method 2
    Method 3
    Press ADJ
    Method 4
    Method 5
    A5
    Method 1
    Method 2
    Method 3
    Press ADJ
    Method 4
    Method 5
    A5
    Method 1
    Method 2
    Method 3
    Press ADJ
    Method 4
    Method 5
    go to this web site for any thing about ur stereo
    http://www.clarion.com/us/en/support/faq/Audio/index.html
    Feb 18, 2010 | Clarion Car Audio & Video
    My solar clock needs setting. I set it back an
    1) Pull the batteries and replace them, or gently insert a straightened paper clip into the "reset" hole in the back of the clock. The clock will beep.
    2) Press the "receive" button" so the clock sets itself. The default time zone will be "EA".
    3) Press the "adjust" button untill the time zone is showing (rather than the day-of-the-week).
    4) Press and HOLD the "set" button down untill the hours digits start to flash2.gif.
    5) Now press the "set" button again six times. The time zone characters will flash.
    6) Press the "adjust" button untill your time zone appears.
    7) Press the "mode" button to return the clock to normal operation.
    8) Press the "adjust" button to display the day-of-week.
    Nov 09, 2009 | SkyScan 86742 Digital Atomic Wall Clock
    I need the instructions for alarm clock model number cc208s
    Please try this....
    Setting the Clock
    1. Press and hold the Clk Set Button.
    2. While holding the Clk Set Button, press the Skip/Search/Hour/Minute Buttons to adjust the hour and minute.
    3. Release the Clk Set Button to set the time.
    Setting the Alarm
    1. Press and hold the Alm Set Button.
    2. While holding the Alm Set Button , press the Skip/Search/Hour/Minute Buttons to adjust the hour and minute for the alarm time.
    3. Release the Alm Set Button to set the time.
    4. Adjust the Auto/Off/On Button to Auto.
    5. Adjust the AM/FM/CD Switch to the desired function for the alarm, or reduce the Volume Dial to "Buzz" to wake to the unit’s buzzer.
    Cheers!
    Jul 13, 2009 | Audio Players & Recorders
    Manual for timex 609t alarm clock
    you should be able to just push the Time button (top one third from the right) and when it starts to blink, just change it like you change the alarm.
    Oct 17, 2007 | Audio Players & Recorders
    Tomtom ONE GPS Receiver Logo
    692 people viewed this question
    Top Tomtom GPS Experts
    LP
    k24674
    Marvin
    Marvin
    Are you a Tomtom GPS Expert? Answer questions, earn points and help others
