Question about Alpine CDE-9881 CD Player
No sound through speakers
I installed the cda-9883 in my 95 passat and everything works but there is no sound through the speakers, i have checked the ic power function and also the mute feature and also double checked the wiring, i am totally confused!!!! i also tried hooking up a speaker direct to the headunit and still no sound.
any help would be appreciated
no sound through speakers problem when cd insert but went radio stacion
  • Anonymous Jul 20, 2008
    i have jeep liverty and i was having the same problem
    if you buy the wiring harness to connect you radio you will see a blue cable with white line coming out from the harness, connect the cable to tha red positive and you will here sound, maybe you car have infiniti audio sistem
  • Anonymous May 12, 2009
    my radio sounds good but yhen i go to play a cd i git no sound
Check the manual to see how to turn IC on and off. Maybe the deck is set to de-activate the internal amp
Posted on Jul 13, 2008
    Problem Solver:
  • 8 Answers
Are you using RCA outputs(the round red and white plugs)? if you are then your amp is not turning on and if you are hooking up speakers to your RCA's (low level) then you will not hear any audio the signal is to low. would need to know more about how you checked the ic power?? one could verify an output ic by hooking up an amp since the RCA audio signal is picked off just before the output. if the low level works but the speakers do not then you have a bad output. anything else an o-scope would be handy.
good luch stereo tech (genesisportland@hotmail.com)
Posted on Feb 03, 2008
Hi there I have alpine cda 9856 cd player and it turns on and does every normal however it won't output and sound on either radio or cd. I have checked for any bad connections and can't seem t
Did you make sure you have no shorted or grounded speakers or speaker wires? Make sure you don't have a bad speaker also. If everything checks out, you may have a bad internal output ic.
Jan 15, 2013 | Alpine CDA-9856 CD Player
I have a alpine cda 9883 head unit that is wired correctly but will not put out sound everything works just does not put out any sound. could it be a problem in the circuit board? if so how can i fix it
first, make sure you have no bare wires or shorts in your speaker wires, also make sure your speakers are all good and none of them are shorted out. if they all check good, you may have a bad output ic.
Sep 01, 2010 | Car Audio & Video
Alpine cda 7893 no sound
this radio does have setting to turn off internal amp go into menu and check it hold down set button to access menu I think
Nov 20, 2008 | Alpine CDA 7893 CD Player
CDA 9885 No idea why it suddenly stopped working
It sounds like you have a bad ground connection. You need to take the radio out and check all the connections. I bet you have a loose one somewhere. That is what the problem was with my bronco
Sep 08, 2008 | Alpine CDA-9885 CD Player
Alpine CDA-9857 Volume Fluctuations
Please see my solution posted on Mar 13. No other brain waves yet!
Mar 13, 2008 | Alpine CDA-9857 CD Player
No sound
I have the same problem but it works for about two minutes before it cuts off I think its a short in the speaker wire because I've tested everything else and it still did the same thing
Jan 15, 2008 | Alpine CDA-9853 CD Player
Peripheral's Connex2Car adapter to an Alpine CDA-9851
the alpine should recognize it as a "changer" when you select the source; ie: radio, CD, changer. Sounds simple, but have you turned up the volume on the iPod?
The Alpine adapter is $100, but works great, you can totally control all your iPods functions, and it displays all song info on the Alpine decks display.
Dec 30, 2007 | Alpine CDA-9851 CD Player
Alpine CDA-7840
Some 4-Runners have a factory system that uses a separate amplifier to power the rear speakers. In this case you need to activate the amplifier using the blue/white remote output from your Alpine deck. It sounds like the wire that activates the amplifier is currently attached to the deck's blue "power antenna" output, so that the amplifier is only on when the tuner is selected. Disconnect whatever is attached to the blue wire behind the deck, and attach it to the blue/white wire instead. That should solve the problem.
Jun 09, 2007 | Alpine CDA-7840
Alpine CDE-9881 CD Player Logo
384 people viewed this question
Top Alpine Car Audio & Video Experts
xxxxxx xxx
hoyzee1
Tygh Duval
Tygh Duval
Are you an Alpine Car Audio and Video Expert? Answer questions, earn points and help others
