Computers & Internet Logo
Anonymous Posted on Jan 05, 2010
I want my desktop to boot from cd. But in the boot priorities there is no option for CD-ROM. How can I make CD-ROM first boot priority?
Anonymous
Level 2:
  • Expert 290 Answers
  • Posted on Jan 05, 2010
Anonymous
Expert
Level 2:
Answers
290
Questions
0
Helped
92216
Points
892
If there is no cd rom, you need to check for it your bios detects your cd rom drive, and make sure you connect it properly.
If you are using IDE CD-ROM,make sure it doesnt conflict on your Master-Slave configuration. if you are using SATA CD-ROM make sure it connects properly to your SATA Ports, and also check if you have properly connect the power cable to your CD Drive.
How do I unlock the Bios on an Acer ES-1 111M Laptop
To boot from a CD, DVD or USB device, make sure that the device has boot sequence priority over the hard drive.
BIOS Boot
BIOS (Basic Input Output Subsystem) is a programmable chip that controls how information is passed to various devices in the computer system. A typical method to access the BIOS settings screen is to press ESC, F1, F2, F8 or F10 during the boot sequence.
BIOS settings allow you to run a boot sequence from a floppy drive, a hard drive, a CD-ROM drive or an external device. You may configure the order that your computer searches these physical devices for the boot sequence.
The first device in the order list has the first boot priority. For example, to boot from a CD-ROM drive instead of a hard drive, place the CD-ROM drive ahead of the hard drive in priority.
Before you set boot priority for a USB device, plug the device into a USB port.
To specify the boot sequence:
  1. Start the computer and press ESC, F1, F2, F8 or F10 during the initial startup screen. Depending on the BIOS manufacturer, a menu may appear.
  2. Choose to enter BIOS setup. The BIOS setup utility page appears.
  3. Use the arrow keys to select the BOOT tab. System devices appear in order of priority.
  4. To give a CD or DVD drive boot sequence priority over the hard drive, move it to the first position in the list.
  5. To give a USB device boot sequence priority over the hard drive, do the following:
    • Move the hard drive device to the top of the boot sequence list.
    • Expand the hard drive device to display all hard drives.
    • Move the USB device to the top of the list of hard drives.
  6. Save and exit the BIOS setup utility.
  7. The computer will restart with the changed settings.
Boot Priority Options
Some computer manufacturers allow you to select the device that contains the boot sequence from a special device selection menu. The example below uses a Dell system board.
To set boot priority using a device selection menu:
  1. When the computer starts to boot up, after the manufacturer's ID screen, press F12 several times. The device selection menu appears.
  2. Use the up and down arrows to select CD-ROM or
Windows 8 Gateway desktop trying to load Win7. I
Hi
You can try with Free Boot Managers and Multi-Boot Loaders you can find lot of free stuff available in online. So download and follow the instructions.
OSL2000 is an advanced multi boot manager you can install multiple OS in a Single PC.
Hope this will be helpful
Have a good day.
Regards
NANDU
1helpful
How to boot from an external cd rom on a dell optiplex sx260 because it does not have an option to boot from an external cd rom..
Maybe it's not installed into windows, or whatever system, with a "driver." That is a program you can get off the internet that tells your computer how to operate that device.
Once installed, a restart and going into bios setup, you should find it in boot priority under the boot tab. If installed it should be there and you set it to top priority and save with f10 and exit. It will reboot and look first in the cd rom for an operating system.
When i connect my samsung CD ROM drive (CD-RW/DVD DRIVE SM-332) hard disk doesn't work and it shows an error hard disk drive Emmett failure.but when i disconnect my samsung CD ROM drive (CD-RW/DVD DRIVE...
You will have to chnage the Boot Priority
Go to BOIS setup coniguration option by hiting F2 , F12 or Del key when staring the system
Change the priority to CD ROM as first priority and insert the Windows Disk and reboot the system to Run the Win XP setup
I have a dell gx520 running xp home . I want to dual boot ubuntu but the cd rom will not read from ubuntu disk. It readsxp and music cd's ok so it is not the rom at fault
Make sure you set the BIOS to boot on the CD rom first. You can set it via the BIOS utility. Usually you press the F5 key and then go to boot options. And then place your CD ROM drive on the 1st boot priority.
Make sure also that your CD installer is working and not from a bad ISO download.
1helpful
Emachine T4060 -black screen-no cd-rom boot
If it is DVD Drive, then sometimes in BIOS you'll also find the option for DVD Drive together with CD Drive. Choose the correct one and boot your PC.
Please come back and vote for me, if this turns to be helpful for you. Thnx
Boot options
You need first to check your device if it has been detected on your computer, check your bios for hardware information, make sure the device is being detected. And also, check if it doesnt conflict on the other devices like your hard disk regarding the Master-Slave configuration, there should be 1 Primary Master, and 1 Primary Slave, Secondary Master, and so on, thats the case if you have an IDE CD-ROM, if you have Sata then you just need to connect it properly or just check if your Sata has been enabled on your BIOS settings. Also , check if you have a good powersupply , make sure the power supplied on your device is ok.
Where can I get a new DVD Cd for my sony pcv-v200g.
Hello
please check first the bios settings check the boot priority select the 1st boot priority to cd or dvd rom then exit and save while inserted the bootable cd..
Angel
Thanks..
3answers
My dell desktop doesn't start or boot from cd rom
Basically you need to go to Bios to change your "Boot device pripority". Please follow these steps to do this.
Please follow these steps to install XP on your PC.
1. Please start your PC with power button. At the very first screen, at the left down corner, you will see the button to be pressed to go to Setup i.e. Bios of the PC. For most of the PCs , it is delete button. For some of them, it is F2 also. So, after starting the PC press Del to go into setup.
2. After you enter setup of the PC, please go to Advance bios setup.
3. There you select Boot device priority.
4. here the first boot device priority should be CD ROM, then the HDD. Please see the instructions given at right down corner and select this priority.
5. After you rightly selected boot device priority as given above, Press F10 to save the changes and then press F12 to exit.
6. Now the PC will restart again, but be sure that you put win XP cd in the drive before it restarts.
7. Now you will see a note that : press any key to boot from CD ROM, so please press any key.
8. The PC will boot from the CD ROM now , now you can follow the instructions given on the screen.
1helpful
Laptop won't boot from external CD drive yet internal one is unresponsive
if you want to boot a cd e.g windows xp os disk then you have to go to the bios by pressing del or f2 or f8 ot f10 depending on the motherboard you use. try to find boot option -> boot priority or first boot device.if you find boot priority then select cdrom as first priority . if you find first boot option then also select cd rom. sometime if your disk is not bootable then it won't boot.
Grand Canyon Tech
Grand Canyon Tech
