Question about Sony FD Trinitron WEGA KV-32XBR400 32" TV
Sony Trinitron KV32FS16==> Need to push pwr button multiple times
Hi, I have a Sony Trinitron KV32FS16==> Need to push pwr button multiple times. The flyback transformer will buzz, and shut off, so I replaced the flyback. When I push the power button now, I get the same result. It will buzz, then shut off. I need to push the pwr button multiple times and eventually it will turn on.... Any thoughts on the issue? I heard maybe the horizontal output would need to be replaced....But not sure...
    Sergeant:
    Champion:
  • 301 Answers
After it fails how many times does the red LED blink? check the board very closely for any cracked solder. and then check the main regulators. also look to see if you have any physically bad capacitors, they might look like they are exploding on the top.
Posted on Apr 30, 2008
REPLACEMENT FLYBACK TRANSFORMER SONY TRINITRON CRT TV KV-2062E IS REQUIRED
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience.
http://electro-medical.blogspot.com/
Jan 02, 2016 | Sony Televison & Video
Hello, I have an old Sony Trinitron KY L34CF1 32" tv that has just developed a problem. When I push the main power button, nothing happens except that the little red led flashes. I f I push the...
turn (only by 2 to 5 degrees ) all the knobs on flyback transformer in clockwise direction & then switch on tv .............you will get picture atleast for 1 or 2 mins ............ this confirms only flyback transformer is defective ........ so it has to be replaced by new one .................otherwise transistor (big in size fixed near flyback with its back clamped or screewed to aluminium metal ) has to be checked ......if that is also fine then complete main board has to be checked ...... but flyback replacement is a must ........in your case iam 100 % sure only flyback is deffective ...........vishnuswamy_26.jpg
Sep 15, 2011 | Sony FD Trinitron WEGA KV-32FS210 32" TV
When I push the power on/off button on either the remote or on the television itself, I can hear the power click on, then it shuts off, then the stand-by light next to the power button on the television...
you have a defective horizontal output or the flyback is bad.
horizontal output is a big transitor on a heatsink near the flyback. the flyback is the coil that feeds energie to the bulb with a thick red cable.
be careful to discarge the bulb before removing the flyback.
Aug 26, 2010 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Tv won't stay on push on button and shuts off w/in 2 seconds
common to having a flyback transformer problem. this will require parts replacement
Dec 27, 2009 | Sony FD Trinitron WEGA KV-36FS120 36" TV
Tv will not stay on, push the on button , tv comes on for a split second and shuts off
Ur high voltage is dead,the FBT,the flyback transformer is dead.The big block of plastic with a red wire with a cap that hook up CRT(tv tube).
Sep 29, 2009 | Sony FD Trinitron WEGA KV-27FS100 27" TV
Blinking red light 3 times on sony 34hs420
Ur high voltage transformer it dead.The big block of plastic with the red wire with a cap hook to the CRT(ur tv tube).It call the FBT,
the Flyback Transformer that thing it dead.
Sep 03, 2009 | Sony FD Trinitron WEGA KV-34HS420 34" TV
When I press the ON button it makes a weird sound and turns off
Ur hight voltage transformer is dead.It call a Flyback transformer,it the one with the big long red wire with the cap go to ur CRT(Ur tv tube).That thing is dead that where the noise came from.
Aug 23, 2009 | Sony FD Trinitron WEGA KD-36FS130 36" TV
Tv won't power on
the flashes are a indication of the actual problem. 5 flashes along with a popping sound is the flyback transformer failing to provide the high voltage necessary to reproduce the image on the screen.
Jul 04, 2009 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Timer button blinks but doesn't turn on
There are several faults that can cause this. Shorted diodes in the high voltage, a bad flyback transformer, a shorted CRT driver IC. None of them are very easy to fix.
Mar 29, 2009 | Sony FD Trinitron WEGA KV-32FS120 32" TV
TV Doesnt work
replace the flyback transformer.
Mar 01, 2009 | Sony FD Trinitron WEGA KV-24FS100 24" TV
Sony FD Trinitron WEGA KV-32XBR400 32" TV Logo
239 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
