I have misplaced my owners manual and I'd like to know how to use the self cleaning feature on my coffee maker.
I copy pasted from the pdf..
Christian.
Self Cleaning:
If the Self Clean light begins to flash when
the coffeemaker is turned on, it is telling you
that the calcium buildup is interfering with the
functioning of your coffeemaker and the flavor
of your coffee. To clean, fill the water reservoir
to capacity with a mixture of 1/3 white vinegar
and 2/3 water. Press the Self Clean button.
When the self clean light glows, turn the
coffeemaker on by pressing the flip switch to
ON. The Self Clean light will shine steadily.
The coffeemaker is now in Self Clean mode.
One cycle should be sufficient to adequately
clean the coffeemaker. When the cycle is
completed and the five beeps sound, the coffeemaker
will shut off. Turn the coffeemaker
ON to see if the Self Clean light continues to
flash. If it does, turn it to OFF and then repeat
the cleaning procedure with a fresh solution of
vinegar and water.
If the Self Clean light no longer flashes, turn
the coffeemaker to OFF and then run one
cycle of fresh cold water through the unit
before using the unit again to brew coffee.
Notes on the Self Clean Function
Pressing the Self Clean button cancels all
other settings. If it is pressed accidentally,
press it again to return the coffeemaker to all
its previous settings. Pressing ON/OFF will
also exit the Self Clean Mode and turn the
coffeemaker OFF.
Hello there,
Not sure if you have solved the problem. I have found the actual owner's manual by researching on line... Hope this helps. Here is the link...
http://www.cuisinart.com/share/man/30_man.pdf
Marilyn
Here's the link for a manual
http://www.cuisinart.com/share/man/26_man.pdf
I'm ordering a different pot in the next minutes. Good Luck
here's the link for a manual.
See the solution by Noggin posted on this site on March 2007:
http://www.fixya.com/support/t137060-self_clean_feature_coffee_pot
Thanks, this is just what I needed!!
can't find my owners manual how do I use the self cleaning
lost manual need self cleaning instructions
the coffe makes very slow, apparent buildup of calcium or other water minerals, the coffee also has a bitter flavor.
The coffeepot does not finish the brewing process (only 1/2 cup water
comes out) - I've tried cleaning it by hand, can't find my manual.
I have also misplaced my manual and would like to know how to use the Self-clean feature. Thank you.
i need to know how to use the self clean feature
The clean light comes on and flashes and I don't know what to do or how to do it. Don't know the model number but it was new this Christmas. Has a stainless steel caraffe.
CLEAN LIGHT BLINKING. I DON'T KNOW WHAT TO DO.
I do not know how to self clean my coffeee maker. Can you help?
stops brewing early.then you have to turn back on
I have lost my owners manual. I woul dlike to know how to use the self cleaning on my coffee maker.
How do you use the self cleaning option?
i need to knoww how to use this feature.
I have a cuisinart Automatic grind and brew. It has a self clean button but I don't know how to clean it-- I lost the manual
lost my manual, need self clean instruction
I h
the self clean button is lit on my coffee maker and I want to know how to clean it
need to self clean my coffee maker. the light is on.
have lost manual. how does the self cleaning feature work?
I too, have misplaced my manual and would like to use the self clean feature...help!
I also have misplaced the owner's manual and I need to learn how to clean the coffee maker.
How do I self clean this coffee maker
I HAVE LOST MY OWNERS MANUAL AND THE CLEANING LIGHT IS ON. CAN I GET A MANUAL FAXED OR E-MAILED???
How do I clean coffee maker, it is brewing slowly and there is a built up of lyme
how do u use it
I have a Cuisinart Brew Central and I have misplaced the owner's manual. The clean light has been blinking and I'm not sure what to do. Can you help?
Cara Biller
How does the self clean program work? Â Can't find my guide
