Back to:
Tags:
Fuji 36.7 GB Hard Drive
My pendrive shows write protected and use another... (by 3 users)
posted by muir on Feb 03, 2008
my pendrive shows write protected and use another device
I have the same problem.
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
2 Other Users Have The Same Problem
Comment by Guest, posted on Jun 27, 2008
i am also face the same problem plz give me solution on this id
gharesuraj@yahoo.co.in
Comment by Guest, posted on Feb 08, 2008
my pen drive is write protecteed pls help
Best Solution
posted on Feb 03, 2008
Helpful (85)
eagle338
Rank:Wiz Wiz
Rating: 81%, 984 votes
Ur pendrive will have a small switch usually at the bottom right corner. Just push it in the opposite direction..
Was this solution helpful? Show your Appreciation by rating it:
Thank You!
Was the solution helpful?
Show your appreciation by commenting on my pendrive shows write protected and use another device:
I don't want to Accept this solution
Solution #2
posted on Jun 11, 2008
Not Rated (0)
dilipbagdi
Rank:Guru Guru
Rating: 86%, 470 votes
First try to see is there any lock in your usb pen drive and see if its not locking the pen drive, because some pen drives comes with that option to protect usb .it looks like slide switch .for one end it will lock the media and when you switch to other side you have the full access
but if that's not the reason it might be the problem with registry
Use the Registry Hack to Disable Writing to USB Drives
Here is the link .just download the zip folder and after opening the folder you will find a file just double click on it..
http://www.howtogeek.com/wp-content/uploads/DisableUSBWrite.zip
Low feed backs hurt my ratings and I tried my level best to resolve the issue. so show your appreciation by rating it.
Thanks for using fixya support..You have a wonderful day
Thank You!
Solution #3
posted on Apr 09, 2008
Not Rated (0)
Guest
Rank:Apprentice Apprentice
Rating: 0%, 0 votes
If you take the hold switch/button/function off the portable drive/watch/whatever and reconnect the leads it should now work. Good luck!
himani kapoor
Thank You!
Can you Help with these Hard Drives problems?
Hard Drives
someone plugged a 17v power supply (instead of 12v) into a...
Hard Drives
i just purchased a maxtor basics portable hard drive so i...
Hard Drives
I plug my simpledrive into the wall and the usb port. It...
Hard Drives
I lost  the power cable of the acomdata external...
Hard Drives
Hay boss, did you ever get a solution to your external...
Loading problems.
Repair Service
Find Hard Drive Repairman Near You:
Browse the Repair Directory
Repairman, Get Listed FREE
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
