Back to:
Tags:
Home Theater Systems
Generic problem for all Home Theater Systems
Cant get sound from speakers (by 2 users)
posted by curley34 on Feb 03, 2008
hi i have a samsung tx 72 (theatre)& samsung t4671f (LCD). The main problem is I get no sound when i switch to satellite. It does work when DVD is operated.
Im using a direct tv non-HD sat-box, which is connected to the tv with the RCA plugs& S-video cable. When I switched to this set-up, I have sound which is LOUDER from only the TV..
Any Help Would Be Apreciated,
Chris
I have the same problem.
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
1 Other User Has The Same Problem
Comment by Guest, posted on Feb 11, 2008
when i play dvd the speaker on the system work but when dvd stops cant get sound
Solution #1
posted on Feb 04, 2008
Not Rated (0)
Shammi174
Rank:Apprentice Apprentice
Rating: 78%, 2 votes
connect a 2 rca - 2rca cable from your tv monitor audio output to the audio in TV of the your Receiver it will shure to solve your problem.
Was this solution helpful? Show your Appreciation by rating it:
Thank You!
Was the solution helpful?
Show your appreciation by commenting on cant get sound from speakers:
I don't want to Accept this solution
Solution #2
Not Rated (0)
Joe master
Rank:Wiz Wiz
Rating: 75%, 16 votes
That is because you didn't have the audio input connection right.
1. HDMI cable going from the Samsung tx72 output to Your Samsung TV HDMI input 2.
2. Non HD directv box Left and right audio output should be connected directly to the Samsung DVD receiver under Satellite input.Select"Satellite"for the sound from your Samsung tx72.You are good to go!
Joe
Thank You!
Can you Help with these Home Theater Systems problems?
Panasonic Home Theater System System
When you touch the volume control, the volume increases...
JVC TH-C50 System
dvd not change, or read
Tascam 2488 Portastudio Multitrack Recorder...
can get guitar effects ok. can also use guitar effects on...
Samsung HT-X810T Theater System
Hello, can anyone assist me to setup my imac to the...
Bose Lifestyle 48 System
Many but not all of the song titles of music stored on my...
Loading problems.
Repair Service
Find Home Theater Sys. Repairman Near You:
Browse the Repair Directory
Repairman, Get Listed FREE
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
