Question about Dell Dimension 3000 PC Desktop
Installing memory i have an older dell and want to put the memory card from it in other dell desktop,but i dont know for sure where to find the memory to install,can i do this
  • andi n.
    andi n. May 11, 2010
    you are talking about ramm memory?
    Teacher:
    An expert who has written 2 tips or uploaded 1 video tip.
  • 171 Answers
It is slim type chips on card that is ram that is near by processor you remove the ram by pressing the locks on two sides after removing the ram install on other desktop on small place and same side which you remove from old if it fix it will work if not ram is not supporting the motherboard
Posted on Mar 09, 2008
    Scholar:
  • 119 Answers
If you reffer to the possition on the board..well they are close to the proccesor.but be sure you have the same ddramm or sdramm for both of them...so...the same tipe of ramms..
Posted on Feb 03, 2008
  • 108 Answers
You can do this if both of your Desktops are using the same memory card or the memory card you need to replace from one to another desktop is supported by both the Desktop boards.
If you have not sure you can provide me the Model No for both the Desktops for more precise solution.
When i turn on my compter the screen shows no imput and goes to sleep
Remove the System's RAM or Memory and try to clean the copper connector with an eraser, put it back and try to turn on the system
if its still doesn't work remove any video enhancing device and connect your video output the the built-it video card, if still dont work, try a different video card on the system, if still dont work check the monitor for any further problems
Nov 07, 2013 | Dell Dimension 4600 PC Desktop
How do I transfer photos to my new dell computer using the cord. I do not want to take them off my memory card too
Hi! create an IP AD to have access with other computer if u're done, if you see your new dell in just copy and paste it in to..
May 31, 2011 | Dell OptiPlex 380 MT Desktop Computer...
I have a dell dimension 4600. It has original memory cards installed. 2 256 MB for a total of 512 ram. I recently tried to install 1 GB memory card. When I start up computer it beeps several times,...
hello
several beeps in a system is caused by a memory issue -- If you've recently added or tried to add additional memory to the computer and have started getting these beeps. Remove all new memory you've added to the computer. If the computer works fine after removing the new memory you're encountering either an incompatibility or defective new memory.
Sometimes when the computer is moved and/or over time a memory stick can become loose causing the computer to be unable to read the memory or get errors as it's reading it. Try fixing this issue by opening the computer removing each of the memory sticks you have in the computer and then placing them back into the computer.
If reseating the memory did not resolve the issue try swapping the location of the memory. If you have only one stick of memory in the computer try moving it to another slot and then boot the computer.
If you have more than one stick of memory try removing all but one stick of memory and boot the computer. If this does not resolve the issue try removing that stick of memory and try one of the other sticks of memory.
the specs can be found at this link
http://support.dell.com/support/edocs/systems/dim4600/en/4600i/sm/specs.htm
the system you have is upgradable to 4G of RAM, and this RAM must be installed in equal pairs
so if you have 4 slots to insert memory in (assuming you will retain the 2 256M) , you must install the other slots by 2 512M, 2 1G or 2 2G DIMMs -- make sure you isntall exact same DIMMs, dont mix memory makers or specs, other than what Dell specifies
memory type must be
PC2700 (333-MHz) or PC3200 (400-MHz) DDR SDRAM
(non-ECC)
i hope this helps --
Dec 09, 2010 | Dell Dimension 4600 PC Desktop
Dell Dimension C5100 Yesterday it was fine and today it turns on but no visual on the screen. Changed monitor that wasn't it, disconnected the video from the on board video output and installed a pci...
you need to open cpu cabinet. Open back cover of cpu then refix the RAM memory. Pull cmos cell from motherboard for 10 minutes then put it back then all settings defaults. Make sure RAM is working fine. Try with another RAM .If you use 2 RAM memory then check with only 1 RAM 1 by 1. Open processor fan and processor then put it back . Clean dust from all parts . Reconnect both connection to harddrive. Make sure motherboard don't touch the cabinet. Remove pci card if any reattach vga card if you use pci vga card.Pull cmos cell cell from motherboard for 10 minutes then reconnect it.Then check. Let me know if you need further assistance. Thanks for using FixYa.
Sep 02, 2010 | Dell Dimension 5100 (D51L1) PC Desktop
Memory card ?
Hi there.
At the front of the computer you should see 1-4 different sized small slots, the card should slide into one of these slots.
Good luck
Jun 02, 2009 | Dell Dimension 3100 PC Desktop
Parity error :only when im playing games, after playing a game 20 minutes (10 if it has good graphics) the computer screen goes blue and it says "Call your hardware vendor for support NMI: Parity check/...
increase ur virtual memory then for high resolution game u should install a graphics card , nvidia graphics card is the good quality card . After doing that plz check
Jun 01, 2009 | IBM Lenovo ThinkPad R60 Notebook
I am looking for the resource disk for dell
if you have another computer, laptop or even a memory stick, download the relevant drivers from the http://support.dell.com website and install the drivers on your desktop and it should be fine afterwards.
If you have any issues post back and let me know
Apr 17, 2009 | Dell OptiPlex GX260 PC Desktop
Can I install any ram memorie cards that will fit my Dell gx260
The memory has to be the same type that is in your PC. Not necessarily the same manufacturer.
Your PC came with PC2700 DDR memory Dimms.
If you have DDR memory sticks from your other PC, then it may work.
Just make sure you unplug the PC and touch the metal case before you pick up and install the memory.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
Dec 13, 2008 | Dell OptiPlex GX260 PC Desktop
Dell dimension 3000 memory card
if your pc is old, it may not be compatible with that amount of memory.. check to see your are buying the correct type of memory, a lot of pc's vary depending on model.. be sure to push down firmly when installing the memory stick.. hope this helps
Feb 21, 2008 | Dell Dimension 3000 PC Desktop
Dell Dimension 3000 PC Desktop Burned Out w/Memory Upgrade
Is the video card built into the motherboard? If not you can try replacing just the video card to see if that works. Otherwise I am afraid you may have to replace the motherboard.
Feb 02, 2008 | Dell Dimension 3000 PC Desktop
Dell Dimension 3000 PC Desktop Logo
96 people viewed this question
Alun Cox
mukhtar21 shaikh
mukhtar21 shaikh
