Question about Ovens
Kemore Gas oven - trouble igniting
Hi, We have a Kenmore Gas Stove/Oven that does not consistently ignite. Whether it is at the first point of turning on the oven or in the midle of baking. You hear the gas and ignitire try a few times and then stop. A few minutes later it will try a few time and ignite. Other times the oven ignites on the first try. Any thoughts? Model 665-75022102 Thank you for your help Oven will not ignite. Kenmore Model 362-7556591
  • Anonymous Mar 13, 2014
    The oven is either failing to ignite or losing ignition after a varied period of time. What could be causing the problem?
    Novelist:
  • 130 Answers
Depending on the age of the oven, it is possible that your ignitor is now weak and it is taking longer to ignite.
Posted on Feb 03, 2008
I have a Hot Point Gas Stove my burners all turn on but when I turn on oven nothing seems to happen
If you have a pilotless model it is very likely that your oven igniter is bad. This is fairly easy to replace. A contunuity check will show if the igniter is bad.
Nov 25, 2013 | Stoves Ovens
Kenmore Oven and stove not igniting
If both top and oven are not igniting, then most likely you need an ignitor board. I should be located behind the left side of the console as you are looking from the front of the stove. I will look it up to be sure. There should be a tech sheet on the back panel of the stove to help in checking the boards.
Thanks/Mike
Dec 02, 2007 | Ovens
My oven doesn't work but my top burners do. It's a gas stove Model #36273271690
The ignitor is not working right and is going bad....
have the repair man replace the ignitor, or DIY....
Check out this tip about your problem...
Oven not Working or Oven not Heating
Oven Problems Replacing the Igniter
heatman101
Oct 28, 2010 | Kenmore Ovens
I am having trouble with the electronic ignition lighting the gas burner in the oven. It makes the clicking sound, but there is no spark 75% of the time. Gas flow is consistant every time. It is a model...
I tried the one thing no repair person or manual ever mentioned: take out the bottom drawer, which is used for storage, and check the wire connection under the stove that connects to the ignition wire. If it is loose, disconnect at the spade connector, clean, and re-attach. Now it works fine.
Dec 10, 2009 | Kenmore Ovens
I have a kenmore gas range with electric ignitors. My question is that my stove top doesnt ignite but lets gas by and I can use a lighter to lite them. However my oven doesn't do anything...no gas no...
Electric gas igniters sometimes get stuck in one position causing a clicking sound. The clicking sound that you hear is the electric arc that is pulsing from the igniter conductor (wire) to ground (the gas burner). It receives power from the electrical outlet that the stove is plugged into.
Residue from food and sometimes cleaning products may be preventing the igniter from producing a spark (Arc) to the base of the burner. This is a common problem that occurs when the stove has been cleaned or food is allowed to build up. Make sure that the igniter and the burner base are clean and dry. This will help with proper operation. Oven cleaner and a small tooth brush may be used to accomplish this. Another problem with ignition may occur if you have too little (touching) or too much space between the igniter and the base of the burner; it will prevent the burner from igniting. You should only have a little more space than the thickness of a nickel between the burner base and the igniter. A good “blue” arc from the igniter to the burner base is optimal. If this doesn’t work, you may need to replace the electric igniter module. Good luck.
Nov 06, 2009 | Kenmore 40494 / 40495 / 40499 Electric...
There is no gas going to my oven. Only the
hello, i can help you. first of all, if the broiler works then you must have gas coming into the stove. as far as getting to the gas line, it is in the rear of the stove. typically you have to pull out the stove to get to it. that said, here are some things to consider.
Not all gas ranges/ovens require electricity. If yours has a clock, electronic igniters, self-cleaning, or any other electrical features, the unit needs electricity to work properly. Check to see whether there's power getting to the range/oven. Does anything turn on--even a light? If not, check for a blown fuse or tripped circuit breaker.
It won't bake If your oven won't bake, check these:
Bake igniter
Other causes
Bake igniter Usually when an oven won't bake, it's because the bake igniter is weak or burned out. The igniter is a small, round or rectangular device, that's about 1 inch by 4 to 8 inches. It's near the burner itself.
The burner is the tube-type device the gas flows through before it's ignited. It has many small holes on the sides to let the gas, when ignited, form a long, low flame. If the igniter is weak, if it glows red but doesn't get hot enough, or if it's burned out, the gas doesn't flow to the burner and the burner won't ignite. If this is the problem, you may need to replace either the igniter or the gas safety valve. Usually the igniter is to blame.
Other causes Other reasons that your oven may not bake are:
  • The clock settings are incorrect (if you have timed baking or a self-cleaning oven).
  • The thermostat is defective.
  • The safety valve that prevents accidental gas flow is defective.
  • The selector switch is defective.
It bakes poorly Here are two instances of when food "bakes poorly:"
  • When the item takes far too long to finish, you probably have a weak bake igniter. Often, you need to replace the igniter, but you may want to troubleshoot the oven's electrical system further to more precisely locate the defect.
  • When the temperature is consistent but too high or too low, the oven thermostat or sensor is either mis-calibrated or defective. If your oven uses an electronic temperature-regulating device, you may have an electric sensor in the oven instead of a mechanical thermostat. If the oven temperature is off by 30 to 40 degrees in this type of unit, you must replace the sensor.
    On many units with a mechanical thermostat, you can remove the thermostat knob and adjust the knob itself to more accurately represent the actual setting of the thermostat. If, when you remove the knob, there's a screw on the back of it with a small calibration plate, you can loosen the screw, adjust the plate, then tighten the screw again. If the knob isn't adjustable, and the oven temperature is off by more than 30 to 40 degrees, you need to replace the thermostat to solve the problem.
Jun 22, 2009 | Ovens
Oven will not light
Hi!!! Even if your ignitor glows just change it it has a weak charge..Also if you change glow ignitor and it does not come on then your gas safety gas valve if shorted good luck..
Jan 04, 2009 | Kenmore 30464 / 30465 / 30469 Gas Single...
Kenmore Oven not working
Remove the bottom panel from inside the stove. Turn on the stove and see if the igniter glows bright red. If not glowing, replace the igniter. In some cases, even if the igniter is glowing, the resistance may not be low enough to turn on the gas valve. In either case the igniter has probably gone bad. ($50.00 to $90.00 for igniter)
May 27, 2008 | Ovens
Kenmore Oven Mod# 665.75012104
hi. thanks for the question .i would replace the bake igniter. that will solve your problem. happy graduation .thanks the appliance doc
May 07, 2008 | Kenmore 30464 / 30465 / 30469 Gas Single...
Hi Deeg, there was a service flash regarding this problem. The bake burner and bake igniter have been modified to assure consistent oven ignition and performance. The number of ports on the burner have increased located at the electrode tip. The electrode shield has also been modified. This repair should be covered under warranty. The kit part number is 8190618 for your information. If your serial number ranges from RK01 through RR11, this is your problem. I would call Sears and request service. Catriver.
Sep 12, 2007 | Kenmore 30464 / 30465 / 30469 Gas Single...
Ovens Logo
507 people viewed this question
Top Ovens Experts
Marvin
Marvin
Sal De
Craig Butler
Craig Butler
Are you an Oven Expert? Answer questions, earn points and help others
