Question about Hotpoint Ultima WF860 Front Load Washer
HOTPOINT F-01 error code
I've the same problem with my Hotpoint washing machine WF860P giving F01 flashing on screen ,machine not working, how could over come this and make the machine work again?
door locked not open.
Please if you know the solution let me know
Shiya
  • 5 more comments
  • fearisthemin
    fearisthemin Oct 16, 2008
    my hotpoint washer was running then it went bang,triped the main fuse box.now getting error code f01.do i need a new motor?????
  • surciuoli Nov 27, 2008
    hi same problem wt761 washing machine. error code f-01
    plese help!!!
    stella
  • Anonymous Mar 01, 2009
    I have the same problem, did the 10 minute thing, no luck.
  • Anonymous Mar 18, 2014
    washer fills then flashes up f08 and then drains
    hotpoint washing machine wf860p fills with water then displays f08 and then drains, still stuck on f08
    washing machine fills then displays code f08 and drains,stuck on f08
  • Anonymous Mar 23, 2014
    Machine has stopped with f01 error code and now cannot open the door
  • 4 Answers
Ive just had the same problem on my ultima WT640 1400 spin. Had f-01 code, used this website and turned off for less than 5 mins. Just trying out a final spin which will take 15 mins, all is well at the moment.
Posted on May 14, 2010
Had the same problem (after owning the machine for all of ten minutes!) - rang Hotpoint and they said it's some sort of error with the computer software, best way to fix it is to unplug the machine for 10 mins and then start up again, it should resolve itself. Nothing to do with a short circuit as that table of error codes indicates - the machine just needs to reset.
Posted on May 18, 2008
2 Suggested Answers
dazmaraz
  • 67 Answers
SOURCE: F01 flashes and machine not work.WF860P
motor triac short circuit check motor and module connections, if o.k poss motor fault
Posted on Mar 03, 2008
How can i fix my hotpoint wt940 with F-01
Hi Hayley,
Please help us help you. Expand on what is working and what is not. SO please add to your comments and repost.
First things first. Water is always a hazard with electricity. Please turn of the power source to your machine and do a fine cleanup, Take canister vacuum and get the hard reach places. A large box fan will help dry the machine and the floor. Pull the machine away from the wall. If possible lift the top off the machine to allow air flow and a panel cover for examination. a hair dryer can be used to dry electronic components in the event of an overload. Give it a chance.
If the machine restarts and is faulting. Here is a link to diagnose the coding Error Codes Hotpoint Service
F01 - Short circuit motor triac*
Here is a place for an online repair manual Free Online HOTPOINT Washing Machine Repair Manual
Here is the Hotpoint manual conversion site Download Manual Hotpoint Service
It appears you may need a new module if the cleanup does not clear out the code
http://www.ukwhitegoods.co.uk/help/fault-codes/laundry-fault-codes/3336-hotpoint-first-edition-hvl-series-washing-machine-and-washer-dryer-error-codes.html
Fare. Well.
Jan 05, 2015 | Hotpoint Washing Machines
Washing machine is flashing f01
F01 is an Electronic circuit board fault
I recommend you disconnect (unplug) the appliance from the mains supply for a minimum of 2 minutes. Reconnect supply and wait 30 seconds and try starting the machine again.
Oct 19, 2014 | Hotpoint Washing Machines
F01 on display wmpf722
f01 is module problem.
a new module will correct it.
Mar 23, 2014 | Hotpoint Washing Machines
Hotpoint WMF540 flashing F01
In general this would indicate a fault in the motor, actual wording from Hotpoint is
Nov 27, 2011 | Hotpoint Washing Machines
Error f01 flashing on machine
F01 on a Washer Dryer means you have a motor fault.
I suggest check the motor and associated wiring. You may just have a broken wire.
Hope this helps.
Oct 08, 2011 | Hotpoint Aquarius WD640 Front Load...
My machine is a WD640 washer/dryer and is displaying in the led display F-01 ? The machine will also not fill with water but the countdown on the cycles are working
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0cm 5.4pt 0cm 5.4pt; mso-para-margin:0cm; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} F01 on a Washer Dryer means you have a motor fault. Check the motor and associated wiring. You may just have a broken wire. Click on the link for more Hotpoint, Creda and Indesit error codes. Or use these links for WMA & WM workshop manuals.
Mar 11, 2010 | Hotpoint Aquarius WD640 Front Load...
F-01 error hotpoint WMD960P
Error code F01 is indicating ashort circuit motor triac.
Check connections on motor the motor plug and then control module.
Please rate my solution.
Thanks.
Nov 17, 2009 | Hotpoint Washing Machines
Hotpoint wt 540 mini light and on off lighs flash changed mogel board switched on and all lights now flash hotpoint w
f01 was the origional fault motor triac failure-when replacing module was it prorammed correctly-clarify on what lights are now flashing-if everthing is flashing like a bad connection then the main board is a faulty one
Nov 09, 2009 | Washing Machines
Hotpoint ultima wf860 washing machine displays error code f-01 and won't spin
F01 - Short circuit - motor triac. its loacted on main printed circuit board. you need a new board.
Oct 29, 2009 | Washing Machines
Hotpoint Ultima WF860 Front Load Washer Logo
5,644 people viewed this question
Top Hotpoint Washing Machines Experts
vince
Eric Taylor
ptpumpman
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
