Question about Chenbro (PC61566-SL-W) ATX Mid-Tower Case
User Guide CHENBRO
CHENBRO PC61566-SL-W
Looking for a User Manual for this case. Please help
  • Stanman1812 Feb 03, 2008
    Thanks but this assuming I already have a certian level of tech know how...
    I need to know specifically how to connect the wires from this case to my Intel motherboard. Some of the items are pretty self explanatory most are not (like the HD led cable, Gnd cable, power cable, etc) the case manual has a diagram for that stuff so if anyone knows where I can get a case install manual, tks!
    Scholar:
  • 119 Answers
Look here..this must more than sufficient
http://www.bjorn3d.com/read_pf.php?cID=813
bye bye
Posted on Feb 03, 2008
Looking for unlock con c9yxtel phone
https://www.youtube.com/watch?v=vxIxxup2WNE
Sep 08, 2014 | Chenbro ARC2-656-C9...
Hey how do you connect the power supply in a Chenbro RM22300 Case? Which one of the coloured cords goes to which plug on the psu? Any help would be greatly appreciated. Also this is for an Australian Power...
IMHO it doesn't matter if it is an Australian PSU. (Power Supply Unit)
The only thing that would change from country to country, is the AC electricity coming in.
Australia uses 220 Volts at 50 Hertz (Hertz stands for Cycles per Second)
Europe uses 220 Volts at 50 Hertz
USA uses 120 Volts at 60 Hertz
Japan uses 100 Volts at 50 Hertz
The PSU converts the AC electricity into DC electricity.
The DC voltage, and amperage is very small.
Now to the PSU and the Chenbro RM22300
Inside the chassis is a Chassis Management Board.
(It is a PCB
Printed Circuit Board)
Orient your view of the CMB (Chassis Management Board), with the blue dip switch to the bottom.
{Dip Switch is a rectangular blue block with 10 white dip switches }
To the right, and situated towards the bottom are two white Molex connectors.
(Actually they are each a 4-pin standard Peripheral power connector. Molex is a misnomer. It is the first company to produce a plug with this configuration. Sort of like calling an open-end adjustable wrench, a Crescent wrench)
This gives you more information on the 4-pin standard Peripheral power cable,
http://www.playtool.com/pages/psuconnectors/connectors.html#peripheral
{The Red wire is 5 Volts DC
The Yellow wire is 12 Volts DC
The two Black wires are Ground wires.
Two D cell flashlight batteries produce 3 Volts DC }
There should be two 4-pin standard Peripheral power cables coming from the PSU.
They plug into the two white connectors mentioned above.
(The shape of the plug, and the connector on the CMB, will only allow the plug to be plugged in, in one direction)
There should also be a Purple cable.
The Purple cable plugs into JP1.
Looking at the CMB as stated above, there are two square looking connectors to the right of the board.
The one at the top is JP1.
(The one under JP1 is JM1)
I would also like you to have the User Manual.
Download it from Chenbro Support,
http://www.chenbro.com/corporatesite/service_download_result.php?type=pro&mk=30&sk=48
On this page left-click on the blue - DOWNLOAD - to the right of -
RM22300 - CMB User Manual for Windows - 899.8KB - 2010-07-13
This is a PDF file. {The computer you are using now has Adobe Reader on it, which uses PDF files}
After you click on the above link it may take up to 30 seconds before the first page will come up.
It may also take additional time for the file to fully download.
{Watch the download progress bar}
There is a way to save a copy of this file to your computer. If you are not aware of how to perform
this, and would like to, please post in a Comment.
{This way you will not have to download again.
You will also be able to burn a copy off to a CD, and have it for safekeeping.
You can also delete it from the computer you downloaded it on, and save Harddrive space }
Regards,
joecoolvette
Jul 12, 2011 | Chenbro RM22300 (RM22300-300H) ATX...
Looking for a manual for a Chenbro 84H220910-074 drive cage. I bouoght 3, and there was no manual with any of them. Nothing on thier site, and no response from thier tech support.
this is from a newegg feedback. the manual is not on their site but according to this guy comments here it is to configure
Pros: It works.
Find documentation here:
http://usa.chenbro.com/corporatesite/service_download_result.php?type=pro&mk=50&sk=
There are extensive connections for fans, alarms and RAID cards (activity & error lights) . Configurable 'high temp' and fan alarms.
Cons: Documentation VERY hard to find.
For the drive trays, Blue power indicator, and green activity light are passed from back-plane to front of drive tray with 'light pipes'. The blue is too bright and bleeds into the green, making it difficult to see the activity lights.
Also, both power connectors need juice or the alarm on the tray goes off. Since I am not using redundant power supplies, I eventually used a 'Y' chord to apply power to both inputs. Not a big deal, just took a while to figure out why the alarm wouldn't ******* (this before I found the documentation mentioned above).
Other Thoughts: The cooling fan is LOUD. I'll look for a more quiet one in the future.
Mar 28, 2011 | Chenbro 84H220910-074 Hotswap HDD Cage w/...
Looking for user manual for Samsung WM1245A - have
user manual comes in various languages. please click on the link below directly http://www.usersmanualguide.com/samsung/washing_machine__drum_type/wm1245a in this link there is manual provided in all the available languages. select the language you wish to see the manual.and click on that particular manual. also for more details please click on this link directly http://safemanuals.com/user-guide-instructions-owner-manual/SAMSUNG/WM1245A-_S this will help.thanks/.
Feb 20, 2010 | Samsung WE356A5W Washer/Dryer Laundry...
Looking for a user manual for model i834. Is
Here is a link to your manual. It is on the right side of the webpage where you see two men (cartoon characters) standing
http://safemanuals.com/user-guide-instructions-owner-manual/POLAROID/I834-_E
I hope this helps and good luck. Please vote and leave a message.
Oct 30, 2009 | Polaroid i834 Digital Camera
Problem with connecting power button to MB.
jsut remove and re-insert the all cable
www.compudesk.in
Sep 14, 2009 | Chenbro Xpider PC61166 Mid-Tower...
Looking for documentation on how to set up drive cables from raid board with the sr107 server
there is no documentation you can get but find an experienced technician to educate you
Dec 18, 2008 | Chenbro SR107 (SR107-BLACK-550W) Extended...
User'manual sl-75frv/75frv-l
hi,
the i use some sites for the link of your manual of your sl-75frv/75frv-l and this one is given, check this and hope this what you need:
http://safemanuals.com/user-guide-instructions-owner-manual/SOLTEK/SL-75KAV-_E
God Bless.
Nov 28, 2008 | Computers & Internet
NEED INSTRUCTIONS MANUAL!!!
http://www.hillbillyhousewife.com/breadmachinemanual.htm
This was helpful to me. Good luck!
Mar 16, 2008 | Kitchen Appliances - Others
Chenbro (PC61566-SL-W) ATX Mid-Tower Case Logo
171 people viewed this question
Top Chenbro Computers & Internet Experts
Alun Cox
David Payne
David Payne
Are you a Chenbro Computer and Internet Expert? Answer questions, earn points and help others
