Question about Estate TGDX640JQ Gas Dryer
No heat I have an Estate TGDX640JQ Gas Dryer (Estate-Whirlpool). I noticed yesterday that the dryer was still running 2 hours later than when I turned it on. The timer didn't move as it usually does and I noticed there was no heat in which to dry the clothes, although the dryer does run and tumbles the clothing. This morning, I turned it on for a few seconds and it seemed to initially have heat, but lasted for less than a minute. Do you have any suggestions and, if so, is this worth repairing?
  • 7 more comments
  • mcwilliams Feb 03, 2008
    I wanted to clarify that the timer does move to set it on an appropriate setting but does not move along with the set amount of time. Still no heat.
    Is the "over" the small white square shaped box at the bottom to the left side? That is all I see and wasn't sure how to pull it off. I will try this and let you know how it works out. Thanks so much.
    If the cover the small white square shaped piece at the left side of dryer or do you mean pull the whole cover off. There is nothing to pull off, except a small approx 1" X 1" square shaped button that sticks out further than the whole entire dryer.
  • bradford 2 May 18, 2008
    no heat and timer doesnt move
  • dobberb Oct 28, 2008
    Timer not moving and no heat ,but will tumble and fan is blowing ..Where would fuse/ fusable link be located??
  • greens4ver Jan 24, 2009
    my dryer does not get heat it does run and the burner doesnot glow
  • rib4 Feb 09, 2009
    mine does the same thing no heatand doesnt shut off can anyone help
  • bradford 2 May 11, 2010
    I checked all fuseable links replaced timer and still cant find problem. Again timer stay in same spot while dryer runs forever. All the while no heat is on.
  • Anonymous Mar 25, 2014
    runs but doesn't dry the clothes
What I learned is that the dryer needed a new fuse. The service man took off the back panel to reach any components and replaced the fuse. The dryer now works.
Posted on Feb 08, 2008
What I learned is that the fuse needed to be replaced on the dryer. The back had to be opened in order to reach any elements, but the service man replaced the fuse and my dryer now works again.
Thanks for the suggestions.
    Novelist:
  • 130 Answers
Mcwilliams if you pull the over off the front of the dryer at the bottom you can see the gas burner assy. Put the dryer on time dry and start the dryer, you should see a glow from the ignitor, then hear a click, then the heat come on. In the auto dry mode, the timer advances along with the dryness level. No heat, No timer advancing. If you don't see a glow, there should be a thermosat on the heater can, see if it is tripped. If so if it is resetable, reset then try again. You may have a bad ignitor.
Posted on Feb 03, 2008
  • Jeff York
    Jeff York Feb 03, 2008
    No that won't show you anything. Remove the back of the dryer to see the heater. Normally on Gas dryers it is required to have a front access on it.
Hello, My dryer is turning however there is not
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101
Aug 11, 2011 | Estate TGDX640JQ Gas Dryer
No heat
heatman101
Mar 29, 2011 | Estate TGDX640JQ Gas Dryer
My estate dryer is not producing heat throughout the entire dry cycle.It does initially, but not all the time.Saw heating element glow and flame up shortly after , but will not stay on and dryer will run...
Often a dryer heating element burns out, but doesn't trip the circuit breaker or blow a fuse. The heating element is simply a long coil of special wire. You can check it for continuity with an ohm meter. No continuity means the element is bad and you need to replace it--electric heating elements aren't repairable. On many dryers, there's a thermal fuse mounted to the exhaust duct inside the back cover panel. The fuse--which is about an inch long--is usually embedded in black resin and mounted in a white plastic housing. If the fuse has blown, you need to replace it. (You can't re-set it.)
Nov 25, 2010 | Estate TGDX640JQ Gas Dryer
Everything goes on, just no heat with my gas dryer.
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check out this electric no heat tip...
heatman101
Sep 30, 2010 | Estate TGDX640JQ Gas Dryer
Will not heat
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
heatman101
Sep 25, 2010 | Estate TGDX640JQ Gas Dryer
Whirlpool Estate gas dryer dries but has a loud rattling sound when its in operation.
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
Dryer Repair Squeaks, Grinding, Clicking and Knocking Noise
heatman101
Asker's Testimonial "That answer was very informative - thank you for taking the time to educate me. " - teresa241964
Aug 11, 2010 | Estate TGDX640JQ Gas Dryer
Dryer runs but does not heat at all
heatman101
Aug 03, 2010 | Estate TGDX640JQ Gas Dryer
Dryer ran all night now no heat
Remove back of dryer and take out the elament shield and replace element don't over strech it start at one side and work it around thank you for useing fixya rate me
Jul 13, 2009 | Estate TGDX640JQ Gas Dryer
No puilot on.
U must rmove the whole front of the dryer to get to the pilot. Good luck.
Oct 17, 2008 | Estate TGDX640JQ Gas Dryer
Timer doesnt move while dryer is on
Please page me here so that i can get back to you
May 19, 2008 | Estate TGDX640JQ Gas Dryer
Estate TGDX640JQ Gas Dryer Logo
415 people viewed this question
Top Estate Dryers Experts
John Tripp
John Tripp
Craig Butler
Craig Butler
Mike
Are you an Estate Dryer Expert? Answer questions, earn points and help others
