Question about GE Profile JTP18 Electric Single Oven
Ge profile double wall convection oven
I have this alarm that sounds with an "FO" showing on by oven clock...I have reset the breaker alarm sounds continuously then stops..however nothing works except the clock............help!
  • Anonymous Mar 12, 2014
    was broiling, at 6 minutes alarms came on and oven is now totally cool but they will not stop. how do i turn them off
    An expert whose answer gotĀ voted for 100 times.
    Sniper:
  • 68 Answers
My solution for the F7 problem may work for you. It won't cost you anything to try it. It is simple and free. You can find it at the following link:
http://www.fixya.com/howto/h155060-dreaded_f7_error
Please let me know if this works for you. You can email me at:
[email protected]
Good Luck,
Powerman
Posted on Feb 04, 2008
6ya staff
SOURCE:
Ovens work fine . .ONCE ! Then buttons do nothing until you turn off the wall breaker for an hour. Then the oven works ONE time again.
Tom Sh, you own every kind of appliance, or you are attempting to be a repairman with free advice from Fixya?
Replace the touchpad. Help Me Find My Model Number RepairClinic com
Aug 30, 2016 | Ovens Ovens
Oven does not heat
Nothing Works, or the Oven / Range / Stovetop Works Only At Certain Times:
1.Home breaker flipped or the fuse blown?Possibly an electrical surge has flipped the breaker. Check your breaker or fuse box and replace or reset as necessary.
2.Power cord plugged in?Grab the plug and wiggle to determine a good connection.
3.Power cord damage?Damaged rubber with wires showing through or the wire is being pinched can cause issues. Electrical tape is acceptable for covering damaged wires.
4.Aclicking sound could be something wrong with a relay. Check for any loose connections around the main control board on your oven. The click you hear is a relay losing power and switching back on. If the clock resets then something is causing power interruptions to the board.
Apr 18, 2014 | Frigidaire Ovens
No power after self cleaning
5.
6.Even a bad relay door switch will hinder your oven from operating.
If your oven has internal fuses, a wiring or component problem could have caused a fuse to blow. A blown fuse is an indication that a component has shorted or failed, and the problem will need to be corrected. Most ovens that use fuses will have an indication of the circuits that are affected by a particular fuse. If an oven fuse has blown, then you should inspect the oven element and the associated wiring to determine the cause before replacing the fuse.
Dec 14, 2013 | LG LWD3081ST Electric Double Oven
We have an indicator tone that goes off every minute, but it appears that nothing is set: oven is off, timer is off, clock is set. What is this? What can we do to turn it off?
It sounds like your electronic control is on the verge of dying. Try cutting of the power to the oven via the circuit breaker for at least 10 minutes then turn it back on and reset the clock. If the oven continues to beep something in the control is failing. It also could be the touch pad has a stuck button and usually the only way to repair that is to replace it. You could try powering down the oven and disconnecting the touch pad then power it back up. If the beeping goes away you need to replace the touch pad.
Aug 29, 2011 | Hotpoint Ovens
My oven is dead - no display, no nothing. Circuit breakers are fine. Turned them off overnight, still nothing on oven this morning. This happened about a year ago but oven came on again ten minutes...
What you need to check is for power at the clock.TURN OFF BREAKER gain access to clock and use volt meter. One the clock will be wires maked L1 & N on those 2 wires when breaker is turned back on their should be 120 vac. IF 120 vac at those 2 wires,replace the clock, if not 120 vac into clock check for burnt/broken wires
Aug 20, 2011 | Jenn-Air Electric Single Oven
My wall oven's heating elements stopped working. Clock, enterior light still work.Model REG74BL*3
Sounds like one leg of the 220v ele. supply has tripped. All thats working, works off of one leg. The elements need both legs to heat. Find your breaker for the oven, reset breaker. It may look ok, but flip the breaker off and then back on. This should fix it.
Please rate solution
Sep 02, 2009 | Frigidaire Ovens
GE Profile oven beeps and displays FO
Your electronic oven control(clock) is bad and must be replaced.
Sep 02, 2009 | GE Ovens
GE Profile JTP18 Electric Single Oven Logo
226 people viewed this question
Top GE Ovens Experts
William Miller
William Miller
Ekse
Marvin
Marvin
Are you a GE Oven Expert? Answer questions, earn points and help others
