Hello rcatron. I think I can help hammer-out your issue. The MC9090 has a backup battery similar to a BIOS battery on a PC motherboard. What this does is holds a constant charge so that the unit's settings are always active and ready to be recalled when it starts up. Generally speaking: if the settings aren't coming back after you reset the unit, it would mean that the backup battery has lost it's charge and with that the ability to hold the configuration (cache/flash) data. However, since all of your units are doing this (correct?) I highly doubt that all of their backup batteries have gone belly-up simultaneously. There a couple causes that immediately come to mind.
If neither of these apply, then please feel free to send me a message or an email and I will be happy to help you troubleshoot further. I hope this helps. Good luck!
This is a very common problem with this scanner, especially if its running Windows CE rather than Pocket PC or Windows Mobile.
Every time the terminal cold boots (has been left a significant time without the main battery and backup battery is depleted) it will rebuild any configurations from reg files saved within the Application folder on the device.
To save the wireless settings the profile (and options for peace of mind) need to be save/exported. This is done by hitting the wireless icon located in eth taskbar on the right hand side, from the menu select options. This pops up a box which contains a drop down box, from this select "export" then you can export profiles and options. Each time you will be prompted to save, use default and the relevant reg file will be saved to the Application folder and hence the settings will now persist through an old boot.
If you need any more help then please do not hesitate to contact us:-
[email protected] or TEL +44(0)1202 620955
http://www.biastechnology.com/
