Question about Dishwashers
Vidio recorder when i record it wont play back what is recorded but it will play pre recorded tapes Is it campatable for LG television please model no VR550/07
    Scholar:
  • 90 Answers
If it plays back pre recorded tapes then there is nothing wrong with that section of the unit. Does it playback audio and not picture or does it not playback anything.
Also, when trying to playback a recording what is seen of the screen? Snow(black and white dots or wiggly picture?
The unit uses two separate circuits to record and playback tapes. Is any thing else connected to the unit while you are recording? If you are using anything plugged into other ports on the recorder it may not see the camera input causing it to not record anything..
Posted on Feb 03, 2008
SOURCE:
Problem with recording/playback
If it plays back a pre-recorded tape OK, then the tape head will be good. If it doesn't you might have problem, with either the head or the pre-amp stage.
However if it is playing back OK but not recording, then you have problem in the record circuit. Some tape decks physically switch the circuit when you press record. Pushing the record button will cause a switch to move position. In some cases dirt or dust can get into the switch and it doesn't connect properly. Switch cleaning fluid will correct the problem.
However the record circuit itself could be faulty. Perhaps an IC has developed a fault on one channel, which will need to be replaced.
Watching what happens when you press record with the top cover off, showing the workings, might point to some movement of the mechanism to reveal a faulty switch.
Jul 07, 2016 | Audio Players & Recorders
Not all cd tapes play clearly out of 12 tapes ,4 sound ok ,8 soundwrak
Are these all commercial pre-recorded tapes? Or are they tapes that were recorded at home? Is the tape deck one that the tape loads in from the short side and must be flipped around to play the other side....or is it one that the tape loads in with the tape facing in and is auto-reversing? Pre-recorded commercial tapes should work on most machines without problems. Home recorded tapes can be a problem, especially on the type of deck that the tape must be swapped over to play the reverse side. Many users use C90 or C120 tapes to home record. These tapes are thinner than normal tapes and are prone to getting overly tight and then can break and/or stretch. This causes jamming in the deck and distortion of the playback.
Jan 18, 2015 | JVC Car Audio & Video
Dubbing VHS to DVD With Magnavox
If you are trying to dub a commercial (pre-recorded) tape it will not work. If this is not what you are trying to do, get back to us.
Jun 07, 2013 | Magnavox ZV427MG9 DVD Recorder/ VCR
When I put a VCR tape into my LG V271 DVD/VCR to record, it plays and when I push record, it ejects.
Hi,this is a normal reaction of the recorder..in order to protect the pre-recorded VHS tapes there is a "Breakable tiny plastic part" on the back of cassette..You cassette might have that part broke and missing ..to correct the problem ,pls apply a scotch tape to cover that area (hole ) and than try to record again.. Hope this helps! Take care and please Remember to rate/vote and
give me 4 Thumbs Up for me to continue for Helping out the Community :)
Thanks
Aug 26, 2011 | LG V271 Player
Play back poor now Camcorder does not record
The head is dirty or bad - insert a brand new blank tape in the camcorder and perform a record through the entire tape without stopping the process until it finishes the record all the way through - this should clean the heads. Playback a pre-recorded tape. If it plays back ok then attempt an actual record. If unsuccessful, then the heads are bad.
Nov 12, 2010 | JVC GR-DX77E Mini DV Digital Camcorder
Lg 766 wont play a pre recorded dvd every thing else is fine
Not all DVD players will play a pre-recorded DVD that was made on a computer. These types are designed to play only what is called pressed DVD's.
When a CD or a DVD is recorded on a computer it is not really the same as when the media has been press recorded.
Most all of the new model DVD and CD players will play computer recorded media. When buying a player, it is important to make sure that the specs are what you need.
Jerry G.
Jul 11, 2008 | Televison & Video
Transferring vidio from cam-corder to vcr tapes
YOu should have your our from your cam to the input of your vcr and the output of the vcr to the input of the tv... then simply set your vcr to the input channel that your cam is connected to ans it should show up on the tv, if it does not hit the tv/vcr button on the remote ... hit record and our done
Dec 31, 2007 | Sanyo VHR-H607 VHS VCR
How do you copy from one vcr to another
ok hear u go
recorder vcr all rc pin go in vidio in audio in .
play back vcr all pin goes out audio out vidio out ..
blank tape gos to recorder
hope that help u
Nov 30, 2007 | Sanyo VWM-950 VHS VCR
VHS Recording Tape
not much of a help but sounds like your record head is bad on the vhs heads,
use cleaning tape try that, if that fixes great, if it helps but not fully there, you might have to clean them by hand with very soft paper town and rubbing alcohol rub side to side very easy , if none of the above work you have a bad record head or record board, not worth repair vs cost
good luck
Aug 25, 2007 | Philips Magnavox 20MC4304 20 in....
Dishwashers Logo
96 people viewed this question
Top Dishwashers Experts
Marvin
Marvin
