Question about Sony STR-DE545 Receiver
STR-DE545 Receiver -
No sound when watching TV/Satellite. The receiver says "opt Unlock". Sound is great with all other components.
  • Anonymous Feb 15, 2008
    I have no sound on TV/ SAT . It says opt unlock
Turn the reciever off. Count to 9 slowly. Press the setup button and power on at the same time.let t run its demo. Turn the power off. count to 8 slowly. Turn the reciever back on. Porblem solved?
Posted on Aug 23, 2009
  • 593 Answers
I just turned my DVD player off when my STR-DE545 was still in DVD input mode and it came up LOCKED, maybe the input that you are using is not receiving a signal?
Posted on Feb 24, 2008
Str-de545 sony not putting out sound to rear speakers
From page 46 (Troubleshooting)-
No sound or only a very low-level sound is heard from the rear speakers.
>>> Make sure the sound field function is on (press SOUND FIELD - MODE).
>>> Select a sound field containing the word "cinema" or "virtual" (see pages 28-30).
>>> Adjust the speaker volume (see page 19).
>>> Make sure the rear speaker size parameter is set to either SMALL or LARGE (see page 17).
Jan 11, 2011 | Sony STR-DE545 Receiver
I have no sound while watching tv. It is hooked up to a satellite system and the other tv/satellite systems are working fine. I have sound while I watch a dvd but nothing while watching tv. Its like the...
I suggest you check the satellite receiver first, you can use the component or HDMI cable for the satellite receiver to check it. If still no sound, the TV main board is defective.
May 13, 2010 | Panasonic TH42PX7 42 in. Plasma TV
No sound out put on both speakers
There can be at least a half dozen reasons for this. Check the simple stuff first starting with the mute button and volume control. Check that the input selection is for the component you want to operate, and then that the component is properly connected to the receiver.
Dec 19, 2009 | Sony STR-DE545 Receiver
Optical digital cable connection ?
It only works through DVD setting
Jun 20, 2009 | Sony STR-DE545 Receiver
No sound coming from Sony Receiver STR-DG510?
Sounds like you are pretty close with this one. If you select fm tuner do you get audio. If not you may have the speakers on the wrong a-b setting. Make sure the audio from your cable box is not muted or turned down.
Mar 15, 2009 | Sony STR-DG510 Receiver
Receiving "Unlock" message and "Not Used" on my reciever
The HDMI inputs are pass through inputs only. The reciever cannot recieve any sound signals through the HDMI's. The reciever acts as a selector switch for the HDMI inputs. Whatever input you have selected on the reciever is the one that is being sent through the output to your TV. The "unlock" display shows when there is no sound signal sent to the reciever. There is no code to unlock. This is the reciever's way of telling you that there is no sound being sent to it from that input. Since there is no sound being processed from the HDMI's, you need to hook up an additional audio cable from the device to the reciever (preferrably an optical cable). When the reciever recieves an audio signal, it will then "unlock" and you will get sound. The only purpose for the HDMI jacks on this reciever is to give you a bonus HDMI jack so you only have to use one on your TV. I know it is confusing. I had to look into this problem myself, so I'm happy to help. Higher end recievers will actually recieve and process sound signals from the HDMI's.
Dec 30, 2008 | Sony STR-DG520 Receiver
No sound from DVD player or didital audio
change the input mode by the little button on the front. See if that helps.
Nov 25, 2007 | Sony STR-DE545 Receiver
Problem with 'central' speaker output
took apart my reciever and found that the blue relays in back in the middle are starting to malfunction. I tapped on them and they clicked. When I tapped the right one, i got the sound back in my center speaker.
Oct 30, 2007 | Sony STR-DE545 Receiver
Phono input
I am not really familar with this receiver but almost all phonograph must go into a phono in. Due to the fact that a phonograph does not have whats called a pre amplifier. generally the receivers have a phono in and that input has an more sensitive amplifier cicuit in the input. That is why if you plug it in to something else unless it has a preamplifier the sound will be real soft. I think Radio Shack sells a amplifier you plug the Phonograph into one side and the other side into the receiver then you can use any input you choose.
Aug 28, 2006 | Sony STR-DE545 Receiver
Sony STR-DE545 Receiver Logo
582 people viewed this question
Top Sony Audio Players & Recorders Experts
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
