Question about Sharp R-510HW Microwave Oven
How to set power level on touch pad microwave
Microwave not heating. how to reset power level? old sharp carosel.
  • bigneet49 Feb 03, 2008
    why bother to answer with (?????), if you didn't have a solution! Ur WASTING MY TIME & yours unless you just don't have anything else to do!
Posted on Feb 03, 2008
I cannot reset clock
Touch Timer/Clock pad and number 2 pad.
Enter the correct time of day by touching the numbers in sequence.
Touch Timer/Clock pad again.
Aug 15, 2015 | Sharp Carousel R530EST Microwave Oven
Sharp microwave 8888 is flashing and I cannot remove
see this steps and fix it. God bless you
Reset the clock. Press "Clock" and the correct time, using the number pads. Press "AM/PM" if applicable, and press "Start" or "Clock" to confirm.
  • 2 Press "Timer On/Off" to reset the timer if nothing on the touch pad will operate. Use the number pads to select a new timed amount, if desired, and press "Timer On/Off" to start. Press again to cancel.
  • 3 Press and hold "Clear/Off" for three seconds if the timer will not function or is blinking when you touch the pads. This will release the "Child Lock" feature. Make a new touch pad selection.
  • 4 Disconnect power to the microwave if following Steps 1 through 3 does not resolve the blinking timer. Wait a few minutes, and then restore power to reset the microwave.
  • However if the problem persist the display board
    main control board is faulty
    Oct 02, 2012 | Sharp Microwave Ovens
    I have a R-8520 Sharp carosel microwave. Previously the convection stopped working, now it does work but heats up too much to the extent that fumes come out from the back of the microwave and it smells of...
    I think it might be a good idea to consider having the appliance replaced, the unit is a fire hazard and judging by the burning smell it is on the way out.
    Jun 16, 2012 | Sharp Carousel R530EST Microwave Oven
    Sharp Microwave on "Lock" and
    The Child Lock prevents unwanted oven operation such as by small children. The oven can be set so that the control panel is deactivated or locked. To set, touch CLOCK, the number 1 pad and then touch the START pad and hold for 3 seconds. Should a pad be touched, will appear in the display. To cancel, touch CLOCK, the number 1 and STOP/CLEAR pads
    Mar 08, 2011 | Microwave Ovens
    How to set the clock on my sharp carousel microwave
    Touch STOP/CLEAR pad.
    Touch TIMER/CLOCK pad.
    Enter the correct time of day by touching the numbers above in sequence.
    (for example: for 12:30, touch 1 2 3 0)
    Touch TIMER/CLOCK pad again.
    Sep 25, 2009 | Sharp Microwave Ovens
    The clock works & counts down but the microwave won't heat
    • Disconnect the power for 30 seconds. After restoring power, do not set the clock.
    • If your model has an ON/OFF clock display, you can choose not to have the time displayed. To choose this option, press the 0 pad for about three seconds. To Turn the display back on, press the 0 again.
    Touch the clock pad. Enter in the correct time of day by touching the numbers in sequence. Touch the clock pad again.
    Aug 03, 2009 | Sharp R-1460 Microwave Oven
    Outside caseing heating up while cooking`
    Also, Please reply back with your brand and model number so we can help you.
    Nov 20, 2008 | Sharp R-1480 Microwave Oven
    Sharp carosel micro wave Model R-9h54
    I'm very sorry to tell you that keypads for all Sharp R-9H-type models are no longer available.
    When the oven becomes unusable, it will simply have to be retired.
    Sorry we couldn't bring you better news, but we're happy to help you and we'd appreciate your thoughtful rating of our answer.
    Aug 01, 2008 | Microwave Ovens
    Touch pad works but microwave doesn't turn on
    NO the microwave doesn' t overheat or froze.
    I couldn't answer to your question 100% because I don't know this model,
    Some microwave don't heat if you don't set the heating temputer on, the power level. I've seen lot's of customer in the past couldn't get heat because all they press was time and didn't set the heat level.
    second it is posible it doesn't heat because the magnetron power supply is burt out, this is the electronic board inside the unit below the magnetron, panasonic or know for burning this board to often, if it was I, they would have been design to inposible to blow them . Microwave have gone a long way and notice that the quality is not there no more. The old once or the same thing as the new once's but made more of plastic. The parts (main parts) or all the same design but mad to brake down after a shorter time. The older model lasted a minimum of 20 years, today they have the same magnetron but they don't last as long as before, made to brake. If they brake faster, the re sale or higher so more money to make.
    To me it's just insulting to think that way, vehicule or the same , the repeat parts sales make profit go higher. It's all a tratege to make money faster and not respecting the consumer.
    Third problem you may have is the magnetron is shut or the cap.
    You would need a tech to tell you that part.
    Regards
    Bob
    ps do what 99% think like trough it out, but make shure you understand you're creating polution everytime.
    Jan 20, 2008 | Panasonic NN-S563 Microwave Oven
    Sharp R-510HW Microwave Oven Logo
    166 people viewed this question
    Top Sharp Microwave Ovens Experts
    William Miller
    William Miller
    Devabhakthuni...
    Devabhakthuni...
    Are you a Sharp Microwave Oven Expert? Answer questions, earn points and help others
