Question about Cuisinart TOB-30 Toaster Oven with Convection Cooking
Broiler element I am using the cuisinart classic toaster oven broiler. I have followed the directions for bake, however after following the preheat directions and placing the biscuits in the oven to bake; the broiler unit still comes on to maintain temp. This burns the top of the biscuits. Help. Ida-Jo
    Problem Solver:
  • 5 Answers
Its an on or off thing. No way to control the flow of electricity.
The elements are bigger than necessary to heat the unit quickly, the problem you have is a bad thing with food that burns easily but a good thing that makes these units come up to temp so quickly after turning on.
Unfortunately the only thing you can do is put more space between the element and your food or use aluminum foil (not suggested, its too close to the burners).
Eventually the contacks will fail (unless you are one of the lucky ones).
Good Luck
Posted on May 30, 2008
We have a new cuisinart classic toaster oven broiler. It burns everything I try to bake . Never had this problem with others .
Hello, Joy -
Since your toaster oven broiler is new, after you check the warranty information in the user manual, contact the Cuisinart company and find out what you need to do to obtain a new replacement.
Note: You may need to provide a copy of the sales receipt for the toaster oven broiler in order to obtain a replacement.
See the information from Cuisinart here (Product Inquiries):
https://www.cuisinart.com/support#us_tab
Best wishes.
Mar 19, 2018 | Cuisinart Toaster Ovens
How to change the lower element on a delonghi AD 699 toaster oven?
  • Preheat ovens only when necessary. With conventional ovens, keep the preheating time to a minimum. Unless you're baking breads or pastries, you may not need to preheat the oven at all.
  • Food cooks more quickly and efficiently in ovens when air can circulate freely. Don't lay foils on racks. If possible, stagger pans on upper and lower racks to improve air flow.
  • Use glass or ceramic pans in ovens. You can turn down the temperature about 25°F and cook foods just as quickly.
  • Do not open the oven door often to preview the food. Each time you open the door the oven temperature drops by 25°F. Watch the clock or use a timer instead.
  • Full-size ovens are not very efficient for cooking small- to medium-sized meals, it generally pays to use toaster ovens or microwave ovens.
  • Check to be sure the oven door gasket is tight. Adjust or replace gaskets as required.
  • If you have a self-cleaning oven, consider using the self-cleaning feature immediately after regular baking when the oven is still hot. Less energy will be required to reach the cleaning temperature. Try not to use the self-cleaning feature too often.
  • Keep range-top burners and reflectors clean; they will reflect the heat better and save energy.
  • Match the size of the pan to the heating element; more heat will get to the pan and less will be lost to the surrounding air. A 6-inch pan on a 8-inch burner will waste over 40% of the energy.
  • On electric stove-tops, use only flat-bottomed pans that make full contact with the element. A warped or rounded pan will waste most of the heat.
  • When cooking with a gas range-top burner, use moderate flame settings to conserve gas. Also make sure the pilot light is burning efficiently, with a blue flame. A yellowish flame indicates an adjustment is needed because the gas is burning inefficiently.
  • Whenever possible, use a pressure cooker. By cooking food at a higher temperature and pressure, cooking time is reduced dramatically and energy use is cut by 50-75%.
  • Hope this work ..........
    Jul 07, 2010 | DeLonghi AD699 Airstream Digital 1500...
    WHY CAN'T I BAKE A FROZEN MARIE CALLENDER CHICKEN POT PIE IN A TOASTER OVEN? (THE DIRECTIONS SAY I CAN'T.)
    I do it all the time. It works just fine. I wish I knew why they said not to. I didn't read that on the package until I had done it a few times. I guess what you don't know won't hurt you.
    Apr 25, 2009 | Cuisinart TOB-30 Toaster Oven with...
    Burnt pie
    YES YOU ARE your trying to bake something in a toaster oven :) toaster ovens have two modes toast /bake in this mode top and bottom elements get hot .and broil in this mode only the top elements get hot . the problem is the marketing the word OVEN makes you think of a normal oven that the bottom elements do all the work . toaster ovens work well melting stuff and toasting . thats about it . if you must bake in it try placeing a sheet of foil on top of your baked goods it might insulate the top of you food . good luck ... if this answer helped please rate it a 3 or 4 stars , this high rateing will help keep me in the paid answer department , thank you
    Apr 13, 2009 | Toaster Ovens
    Cuisnart Toaster Oven Broiler TOB-165 Element
    there not replaceable . metal straps are welded to the ends to make the electral connections . thats why there are no elements for this oven , sorry factory-store-home-dump AS FAST AS WE CAN
    Jan 20, 2009 | Cuisinart TOB-165 1500 Watts Toaster Oven...
    Cuisinart Toaster Oven Broiler Not working properly
    This is not a defect - it is just how the unit operates. You can set it to Broil, and the top element should not come on. Make sure the wire rack is turned upside down so that it curves inward and try one more time.
    -Tha Mp3 Doctor
    Jan 04, 2009 | Cuisinart TOB30BW Toaster Oven with...
    Cuisinart: toaster part of toaser broiler oven does not work
    Definitely a defect - return to store if possible, or call Cuisinart - it has a 3-year warranty.
    -Tha Mp3 Doctor
    Dec 24, 2008 | Cuisinart TOB30BW Toaster Oven with...
    Warning tone?
    Have you tried turning the function button to off? This has worked for mine.
    Aug 18, 2008 | Cuisinart TOB-30 Toaster Oven with...
    Cuisinart TOB-30 Toaster Oven with Convection Cooking Logo
    440 people viewed this question
    Top Cuisinart Toaster Ovens Experts
    D. E. Hev
    Lawrence Oravetz
    ray gallant
    Are you a Cuisinart Toaster Oven Expert? Answer questions, earn points and help others
