GE Profile Spectra JGBP90 Gas Kitchen Range
Problem for GE Profile Spectra JGBP90 Gas Kitchen Range
GE PROFILE RANGE TOP
By psnowden on Feb 03, 2008
I am very careful and cautious when cooking or cleaning on the range. However, the enamel has a residue from oil when frying. When I am cleaning the burners, the residue doesn't come off on one burner and is pealing the enamel on the other.
Same Problem
Feb 16, 2008
-   my range is 6 months old & I've had the cooking grates replaced 3 times. Two sets were made in China & 1 set made in Mexico. The enamel on the top appears to be either scratched or worn off after several uses. The repairman says the problem is with the cookware I'm using but I never had this problem with previous ranges.-   4mrd
Feb 10, 2008
-   cannot remove any of residue left around burners. Top is flat area should be easy to clean but isn't. Did not receive manual for stove. I would like one.-   Guest
Solution #1
posted on Feb 04, 2008
Not Rated)
textonor
Rank: Guru
Rating: 88%, 131 votes
psnowden this can happen. If I remember correctly GE is using a Hi Temp paint, not porclean, on this range. And if they are using porclean, it is a thin coating. With current ranges the cooking oil gets into the finish and runs the heat up causing the finish to lift. The is espically true with white. The gentlest clean will in time not stop this from happening. You can get some hi temp touch up paint to make it look better, however it will keep doing this, espically on the burners you use the most.
Was this helpful?
Yes
No
Popular Solutions for GE Profile Spectra JGBP90 Gas
Questions and Unsolved Problems for GE Profile Spectra JGBP90 Gas
Do you recommend GE Profile Spectra JGBP90 Gas Kitchen Range?
Answer
Answer
what type of external temp gauge should I get and where?
Answer
I have a GE XL44 gas stove. the oven only works when the stove top is on. the ignitor has been... (More)
Answer
oven door on self cleaning oven is locked. How do I get it open?
Answer
How do I get it open. Plus the stove works, but the oven does not.
Answer
replaced the oven ignitor and all was well but never got to temp before quitting and now like the... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Kitchen Ranges Experts
Top Range & Oven Repairmen
(972) 859-0929
Honest, Dependable, Affordable, Available &...
Appliance Parts & Repair Service
(423) 303-3784
Oven and Range parts delivered overnight...
 Appliance Parts Pros.com
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
