Question about Dell Dimension 3000 PC Desktop
Won't turn on...
I open a Dell Dimension 2400 (long story behind)... all I did on this one was to remove the hard drive...I clean the inside by blowing some of the those compressed air duster...then i put the hard drive back, and the thing turns on, it stops like for a second and goes back on...but nothign appears on the screen!!! Please help me!!!
  • 407 Answers
The fault is in the connector.do check it properly.else replace it
Posted on Feb 03, 2008
How do I remove and replace a CPU cooling fan on my Dell Dimension 2400
Make sure u can open the casing well to expose the interior parts without causing any damage. Then by close look at the processor area , that is where the heat sink is located. Normally the dell dimension 2400 has a green channel shaped structure that acts as a passage for the air that enters in and out for cooling the heat sink. It has a locking parts that slides into the casing back by slight pressing to the back of the casing just behind the processor area, be so observant to notice the locking parts. then the fan is just fixed behind that green " channel like" and its fixed on the rear side of the casing, 25275582-o0cuhlgwrl13okm3u3q5444d-5-0.jpg
Nov 08, 2014 | Dell Dimension 2400 PC Desktop
Is wd1200jb-00gvc0 hard drive compatible with dell dimension 2400
That is a western Digital Hard drive compatible with most computers even Dell Computers
May 15, 2014 | Dell Dimension 2400 PC Desktop
Hard drive boot failure
what is the error message? If operating system could not find, try you original windows installation CD, during you boot from the CD there is a repair option, follow the wizard to complete.
Sep 03, 2012 | Dell Dimension 2400 PC Desktop
How to clear memory from dell 2400
i don't understand when u say it works fine but you need to remove old memory.... inside the PC, you will find the a green rectangle stuff near the processor fan. that is the pc memory. But if your referring the memory as a data, then the data is stored inside the hard drive. if you want to wipe all the data, u just simply format the hard drive. all the data will be gone. hope this will help you.
Jun 14, 2012 | Dell Dimension 2400 PC Desktop
My Dell Dimension 2400 refuses to load Windows XP
What happens?Does it hang on the loading page or does it restart itself before loading?
If it hangs on the loading page,press CTRL,ALT and DEL.This boots the system.
If it restarts itself,remove the hard disk and re-fix it again.Problem solved?
Remove the CMOS battery and the hard disk and re-fix them again.Problem solved?
If not,you may have to repair your operating system.
This how you do it:-
  • Remove your hard disk and enslave[fix it as a secondary drive] it on another machine with a good operating system.
  • Start the machine.Accept to run unnix[using two drives]
  • The machine will automatically detect your hard disk's failure on the operating system and repair the damaged files.
  • On completion and after Windows opens,turn off the machine and remove your hard disk.
  • Fix the hard disk now on your machine and start it.
Hope this helps.Thanks!
Please rate this answer.
Oct 31, 2011 | Dell Dimension 2400 PC Desktop
Where is the hard drive in the dimension 2400 dell. I see the cd drives, the power supply, the cooling fan, the heatsink, the video card, the memories... so where is the hard drive?
You know the power button in the front? If you open the cover to see the insides, there is the HD that is kind of covered by a metal slot (has like holes...). Well, the HD is right next to the power button in the front, but inside.... Here is a picture. The wires are attached to the HD. yup.
Feb 22, 2011 | Dell Dimension 2400 PC Desktop
What to do after installing a new hard drive?
Download and install the drivers from support.dell.com
Install them in this order
http://www.fixya.com/support/r4432358-proper_order_install_drivers_dell
Apr 04, 2010 | Dell Dimension 2400 PC Desktop
Dell Dimensions 2400 Primary Drive 0 Not Found
For this problem it only means that the Hard Disk of the computer is not being detected
Try doing the ff:
  • reseat the IDE or SATA cable of the Hard Disk
  • Clean the port where the cable is connected (make sure that the computer is unplug)
  • reboot the computer
  • if problem persist contact computer manufacturer
Hope this will help
Thanks
BYron
Sep 24, 2009 | Dell Dimension 2400 PC Desktop
Dell Dimension 2400
Open your dell, remove the cd drive backwards, the cd driver has two green rails where it glides on. Those rails you ned to put back if you replace it with onother driver.
Good luck to you
Dec 18, 2008 | Dell Dimension 2400 PC Desktop
DVD drive bay
yes you should be able to play CD on the DVD reader.
Dimension 2400 have drive slide mounted on the side of the hard drive, cd drive and floppy. they are different for each device. you need the 2 side mount for the dvd. in order to mount them in the Dell.
the drive is inserted from the inside of the box toward the front. The front panel will prevent the device from pop out.
yes, 3 party DVD, CD drive will be shorter and fater that what Dell porvide, but it will work, al long as the opening is accessable.
get the HP DVD driver.
Nov 04, 2008 | Dell Dimension 2400 PC Desktop
Dell Dimension 3000 PC Desktop Logo
43 people viewed this question
Alun Cox
