Question about Fujitsu Pocket Loox 600
Loox 600 doesn't start
When I power up the pockett pc loox 600 it stays in the start screen and the pocket windows 2002 doesn't start. I can't even shut the loox 600 down it stays in the same loox 600 start screen.
I also give the loox several resets but it wound help.
Wat can I do to make the loox 600 work again?
  • Fujitsu Master
  • 13,433 Answers
Hey,
Have you tryed performing a hardreset on the pda?
If a hardreset doesnt fix the problem. Then it is eather a hardware issue or your operateing system is corrupt.
You can reflash your operateing system with a com or a usb cable maybe even from a memory card. But frist you need to get your hands on a working copy of the os. It might be easyer to take the pda to a local repair shop for analysis and repairs.
Posted on Feb 11, 2008
How to delete all contacts from pocket loox N520
CLEAN REGISTRY - This resets the device to factory settings, losing applications but keeps your data intact.
FACTORY DEFAULTS - This completely wipes everything and resets the device back to it's factory defaults.
SKIP
Try Clean Registry first.
Aug 24, 2012 | Fujitsu Siemens Pocket Loox N520 Pocket PC
I want to change language dutch to English in My Pocket Loox 720. Is any way to chage language?If not how can i change that? Please explain how to reinstall windows mobile?
ALL YOU HAVE TO DO IS LOOK IN THE BOOK THAT YOU GOT WITH YOUR PHONE IT WILL TELL YOU STEP BY STEP AND IT WILL ALSO LET YOU SEE THE ORDER SO YOU CAN CHOSE ENGLISH.
Mar 29, 2010 | Fujitsu Siemens Pocket Loox 720 Pocket PC
Battery replacement pocket loox n560
If you want to buy the battery for your Fujitsu N560, kindly check these links and it might help:
http://cgi.ebay.com.sg/Extended-Battery-Loox-N560-N560c-N560e-N560p_W0QQitemZ330287493568QQihZ014QQcategoryZ75446QQcmdZViewItem
http://www.lelong.com.my/Auc/List/2009-06DeSale35361186_AUCTION_--Best-Price-Gtoracer1-Siemens-Look-400-410-420-N520-N560-Battery.htm
http://shop.eten.hu/mugen-power-3000mah-extended-battery-for-fujitsu-loox-n520-n560-with-battery-door-p-167.html
Hope it helps and have a great day!
Jun 10, 2009 | Fujitsu Siemens LOOX N560 Pocket PC
Battery charge indicator seems faulty.
Solved own problem. Bad conection between pcb and battery contact pins. Reheat each battery pin on the pcb carefully until solder reflow occurs then remove heat. PDA now repaired
Aug 03, 2008 | Fujitsu Pocket Loox 410 Pocket PC
Loox 600 to internet via wireless broadband router
Well, i've removed WEP encryption from the equation and it seems to be running perfectly now.
However, when i turn it back on, it all goes wrong again.
So, for now, i'm leaving it off, but i've got mac address filtering on to guard my security!
Hopefully this will only be a temporary solution, as i'll keep tinkering when i get time.
Dec 08, 2007 | Fujitsu Pocket Loox 600
No POWER ON out-of-the-box & after initial battery charging.
Even if the battery is dead it should still be able to boot on external power.  I think the best bet, though slow, would be warranty.
Oct 12, 2007 | Fujitsu Siemens Pocket LOOX T830...
Pocket loox t830
I had this problem. Only solution is a full Hard Reset which is a combination of Power Switch Photo Switch and Reset Switch. BUT you will loose everything on the PDA.
Jun 01, 2007 | Fujitsu Siemens Pocket LOOX T830...
Fujitsu Pocket Loox 600 Logo
287 people viewed this question
Top Fujitsu Computers & Internet Experts
Alun Cox
Computer Links
Are you a Fujitsu Computer and Internet Expert? Answer questions, earn points and help others
