Unit not producing heat but fan cuts on and off
Gas pack unit not producing heat but air carrier fan cuts on and off, could it be thr limit switch and if so where is it located?
  • 74 Answers
Most newer unit the fan comes on if the limit is tripped. The limit is located in the blower section and in the burner section.
Posted on Jan 05, 2010
I have a carrier 48nlx024 I replaced the fan control board and the fan comes on by itself when t stat is off
Do you have a "circ" feature on your tstat? This will periodically bring the fan on to circulate air. Be sure you are on auto. Is the fan running continuously? Possibly have relay backwards.
If you need further help, reach me via phone at https://www.6ya.com/expert/thomas_092728000e6acb79
Sep 02, 2017 | Carrier Heating & Cooling
My blower on my carrier furnace unit won't turn off? a/c or heater doen't turn on.
gas furnace??? check the start capacitor, put unit in ac mode and see if fan comes on(switch fan to on at thermostat) if it does not a fan problem or capacitor problem. when in cooling mode thermostat controls fan, when in heating mode, furnace controls fan
Feb 18, 2015 | Carrier Heating & Cooling
Goodman gas pack unit indoor fan stays on all the time
Problem may be with the high limit switch located above the burner assembly with two wires to flat rectangular looking plate. Jumper the two wires and see if the fan quit's running. If so replace high limit switch.
Aug 22, 2011 | Goodman CKL36AR36 Air Conditioner
Hi, I have Starling QVX heater. The air flow space where the limit switch is located heats up to around 210 Degrees after the furnace runs for awhile then the switch cuts off the gas and the fan...
The should be a temp stamped right on the limit switch telling you it's limit. It is very possible it is going bad. I know they make adjustable limits but would not go too much higher than what is in there now. Good Luck!!
Apr 27, 2017 | Sterling RF30 Natural Gas Garage Heater
My father has an older model two and a half ton goodman gas package unit. it has had two boards put in it, the problem is that the unit will go through a heat cycle and the combustion motor and the...
the fan induction motor produces a vacuum, check of orofice on motor is plugged by pulling hose off switch end and putting in mouth while running and sucking, this will make a whining sound immediately if no restriction. the fans are controlled through the board by vac., swich, limit sitches, and timers in the board itself. maybe a bad ground on flame sensor.
Jan 29, 2009 | Heating & Cooling
Fan running but no heat
It could be the circuit board, relay, heat strip coil or limit. If you have the fan switch at the t-stat in auto and the fan is running constantly it's probably a high temp limit that tripped. Was your filter clean or dirty? If you had a dirty filter and/or A/C coil it will restrict air flow and cause the furnace to overheat.
Jan 18, 2009 | Carrier 38CKC042 Air Conditioner
Only blows hot air inside
Set thr thermostat to AC instead of HEAT.
Dec 29, 2008 | Carrier 36KCARMS Air Conditioner
Carrier Natural Gas Furnace/Air Conditioner, Model 518CXX036000MBAA
Is this a package unit??? Or is it inside the home?? How old is the furnace. The first thing to do is axcess the fan and see if it is controlled by a computer or its old enough to have a fan switch. Trace the red wire from the fan mtr that should take you to the fan switch
Dec 01, 2007 | Carrier XHB123D X/Y Series Heat/Cool Air...
Fan continues to run after desired heat is established , I blew out the line at pilot and the unit is taking 10 to 15 mins for fan to cut off
Looks like your fan limit switch may be bad. It fits into the warm air side of the furnace. It tells the fan to come one and off when the heat is blowing over the limit switch. Now if that limit is defective it also will affect the lighting of your heater being it electronic ig-niter or just common thermocouple type controlled pilot light. Now above your post I think the wong information was given about your gas heater, so giving you the exact information will be difficult. Now from hearing you explanation of the problems, I hope my information was a help to you, Thanks Sea Breeze
Oct 26, 2007 | Carrier XHB123D X/Y Series Heat/Cool Air...
Heating & Cooling Logo
126 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Mack Baxter
Marvin
Marvin
