Question about Alpine Air XL-15 Air Purifier
I cleaned my alpine air XL-15 and it will not go on.
I checked the inter lock switch but I can not tell if it is working. Is there a way to test it to see if works correctly. I reinsatalled the Glass plates the metal clips that hold the pates must make contact with the metal sceen bonded to the glass, correct.
Yes, the plates contact the screen. If you used soap on the plates there may be a residue. Use nonsudsing ammonia OUTDOORS and a toothbrush, then rinse thoroughly and let it dry before putting it back. It may take a few minutes of running to get the ozone going again after that. The interlock switch on some units is pushed back to go on, on others pushed down. Make sure the little plastic doodad (or metal on older units) is pushing the switch properly - you'll know if the fan doesn't go on.
- Robert
www.rawfoodlife.com
Posted on Apr 18, 2008
Alpine Air XL-15 Air Purifier - never taken out of box - won't turn on whatsoever. Plate is accurately placed and the rear filter is properly fitted.
Is the fuse in properly? Try popping it out and put it back in, also check it when it is out..just to be redundant since you did it already. push on the bottom of the filter the switch pushes in . I at pushed down my first time.
Jul 06, 2012 | Alpine Air XL-15 Air Purifier
I have 2 Living Air XL-15 that no longer will power on. I have checked and the clip that depresses the switch is fine but nothing. How can I tell if the fuse is no good?
Continuity is one way, they need to be able to conduct. If they are ceramic- use a test meter. If they are glass, does the wire reach from end to end or it melted? Does it resemble an old flash bulb that had been used? If so, or no continuity- replace fuse.
Also clean the contacts for the ionizer plate.
Jan 30, 2012 | Alpine Air Air Purifiers
My living air xl-15 prove it light does not come on anymore and it seems that the unit does not prodoce ozone. I tested the light in the normal postion set at 12:00 with the plate out but to no avail....
If you are sure that the plate is clean, in perfect condition, and inserted correctly, it would appear that the transformer is defective. This means that power is not going through the metal contact fingers into the plates.
The light probably has burned out. It is not essential to the working of the machine, so it isn't anything you need to be concerned about.
Vollara (formerly Alpine/EcoQuest) is no longer producing or servicing the XL-15. However, a newer version, called the Classic, is available. You can call Customer Service 800-989-2299 and they will tell you your options. Use #16618 if you need a referral number.
Jan 08, 2011 | Alpine Air XL-15 Air Purifier
I just purchased a used Alpine Air XL-15 from ebay.no ozone spell
You probably have a burned out high voltage transformer. That's what produces the ozone. Helpful hint...........the high voltage transformer is also the one used in bug zappers
May 10, 2010 | Alpine Air XL-15 Air Purifier
Does XL-15 air purifier work well in a lakefront home enviorment?
i dont know if it will kill mold. I had mine in the houston area--high humidity and it definetly cleaned the air. You could check with the manufacturer, their customer service is excellent.
Mar 21, 2008 | Alpine Air XL-15 Air Purifier
Alpine XL 15 not working after cleaning
Bottom small plastic covered screw is a trigger for interlock switch, won't work if it doesn't push in the metal trigger.
Jan 14, 2008 | Alpine Air XL-15 Air Purifier
Living Air XL (no smell)
pull out the plates and clean contacts that touch plates with rubber eraser then put plates back in check switch on back of screen to make sure its making contact.
~~~creekkid~~~
Dec 19, 2007 | Alpine Air XL-15 Air Purifier
Alpine Air Living Air XL15 not producing Ozone or Deodorizing. New plates
Confirm that the appropriate sections of the circuitry are powered up and drawing power; check the interlock switch action; toss it back to the maker because the Hi-V transformer or ladder circuit or sense or hold caps were (if testing proves) never quite functional.
Dec 03, 2007 | Alpine Air XL-15 Air Purifier
Alpine XL 15
Also make sure the safety interlock switch is properly closed when re-assembled. It's the springloaded switch inside the little notch in the chassis - the small tab on the lint screen should fit in and push that switch closed. If you do it wrong, the unit won't work. You should hear an audible click when the tab closes the switch.
Nov 17, 2007 | Alpine Air XL-15 Air Purifier
Alpine Air XL-15 Air Purifier Logo
70 people viewed this question
Top Alpine Air Air Purifiers Experts
Jerry Greenberg
Jerry Greenberg
Tom Chichester
Are you an Alpine Air Air Purifier Expert? Answer questions, earn points and help others
