i have a friend whose laptop was infected by a virus of which she cannot remove. I'm yet to ask her antivirus though. Based on her, it was a ".scr file extension". it was said that ALL OF HER DOCUMENT FILES WERE REPLACED BY THE .SCR FILE EXTENSION.
what is the best way of solving this problem? is it really a virus? she said that she cannot use or open her documents anymore because of what just happened.
really need help on this, thank you!
Comments:
Feb 03, 2008
- thank you so much! I'll suggest these solutions right away! I'll ask her too for further details.
Its the W32/Rungbu-A virus, it infects Microsoft Word DOC files by
copying itself to the same filename but with an .SCR extension,
appending the DOC file to the SCR copy, and then hiding the original
DOC file.
The W32/Rungbu-A then sets the computer not to show
hidden files (in order to hide the DOC file), to give SCR files a Word
icon (so the SCR file looks like a Word file), and to hide file
extensions (so the SCR file just displays the filename, not the SCR
extension). When the SCR file is run, the Word document is displayed as
normal.
To recover your .DOC files just follow these steps:
You have to delete all files detected as W32/Rungbu-A.
Set the following registry entries in order to show extensions and hidden files:
You must change the attributes of the original .DOC files to stop them being hidden.
My answer to your second question, is in November of 2007 the .SCR file extension started to be used to transmit
a Trojan. As a script or a screen saver this file can execute other
files which carry the Trojan. The SCR file may be embedded within a ZIP
file which could also contain a file with a double extension. Many Windows screen savers come with a .SCR extension by default.
Usually these will be found in the Windows main directory. Use caution
if you receive a screen saver file via E-mail. These files can contain
executable code and can be worms or viruses. Note: This file type can
become infected and should be carefully scanned if someone sends you a
file with this extension.
the laptop is infected by a trojan.it genarally comes when you download screensaver online.install a good antivirus like latest version macafee.the AVG free edition also a good one.
It does not sound like a Virus.
Is she able to Open her docs. using another extension.
If she has a antivirus prog. update prog. Disconnect from Internet,disable System Restore,run virus scan.
Delete any viruses found.
Reboot
Enable System Restore.
lets know how you went.
i have wipro laptop model no 7B1110, which was formatted , now i want to install drivers couldnt...
(More)
i have wipro laptop model no 7B1110, which was formatted , now i want to install drivers couldnt able to find , can anyone guide me plss.
I'm having trouble getting my Verizon MyFi card to configure on my Dell PC w/ XP or my Dell laptop...
(More)
I'm having trouble getting my Verizon MyFi card to configure on my Dell PC w/ XP or my Dell laptop with Vista. The files load--but it doesn't find it when you look for a connection. I've spent 1-1/2 hours with Verizon's tech support and the ppl at Verizon took my laptop to work with it today for several hours but couldn't find a solution. It must be a setting in my computer. They lowered the firewall on the compuer to load the drivers but that didn't work. They checked the administrator settings. They checked to see that the MyFi was being "seen" by the computer and even were able to install it on another computer so the card is good.
