Question about Photography
Aperture setting I have an old XR-X3000 SLR and I do not know what the "A" aperture setting is for on the lens (35-80mm) Can you help please?
  • reeko Feb 03, 2008
    On some Ricoh lens` there is a "P" setting on the aperture ring. Both the "A" and "P" settings are achieved by pressing a button to unlock the ring. You have to press the button again to select all other aperture settings. reeko.
    Thanks zeusfaber, I know all about how a lens works. I think you didn`t quite grasp my problem. reeko
  • 247 Answers
Inside the lens is an "iris" which allows you to adjust the effective diameter of the lens, and control how bright an image it casts on the film. This is controlled by the aperture ring.
Smaller number settings set a bigger hole in the iris and let more light in - allowing a shorter exposure time, but reducing your depth of field (so if you're focussed on an object at two metres, stuff at 1m or 4m might be blurred)
Larger number settings set a smaller hole and let less light in. This means longer exposures (and more risk of camera shake), but offers a better depth of field (so although you're focussed on something at 2m, objects much closer or further away are also more likely to appear shrp too.
A.
Posted on Feb 03, 2008
I turn on the camera and i get the leters. fEE on the screen and i can't take pictures. My camera is a NIKON N80 please help thanks
Turn the aperture ring on the lens to its smallest setting (largest f/number). You can control the aperture from the camera body, the same way as on a lens without an aperture ring.
Sep 25, 2011 | Nikon N80 35mm SLR Camera
What does fee mean
It means that the lens is not set to its smallest aperture. Turn the aperture ring on the lens to its smallest aperture (largest f/number). You can control the aperture from the camera body, the same way as on a lens without an aperture ring.
May 19, 2011 | Nikon N65 35mm SLR Camera
What does FEE mean? The camera won't take a picture and I see that in the display of my Nikon N90S
FEE error message displayed on SLR camera LCD Description If the cameras LCD screen displays "FEE" in the area where the aperture is normally displayed, please ensure that the lens is attached to the camera correctly. This error message will appear if the lens is not attached correctly to the camera or if you are not using a CPU lens such as the Nikon AF or Nikkor P lenses. Alternatively, if the lens has an aperture ring, it may not be set to f22 (or the highest aperture number on the aperture ring - normally marked in orange). Select the aperture number marked in orange on the lens and lock it using the aperture locking switch to prevent this occurring again.
The FEE error message
Set to F22, or the highest aperture number - normally marked in orange. Note the locking switch.
If the above did not resolve the problem and you still experence the the error display FEE, please contact your local Nikon office. Before doing so please also check the following.
1157d.gif That the EE servo coupling highlighted above on the lenses has not been broken. That the F-min switch highlighted above on the camera body has not been broken. If either of the two items above are broken please contact your local Nikon service center.
Apr 19, 2011 | Nikon N90S 35mm SLR Camera
I bought an older 28mm nikon lens for my d60. when i try to rotate the apertrure ring, the d60 screen says that the aperture must be set to the highest setting. am i stuck with this aperture...
Set the aperture to its smallest opening (largest f/number) and lock it. You can control the aperture from the camera, the same way you do it on a lens without an aperture ring.
Apr 04, 2011 | Nikon N50 35mm SLR Camera
On the Nikon N90s what does the flashing fEE mean?
It means that your lens is not set to the minimum aperture and your camera is either set to program mode or shutter priority. Also, it can mean that your flash is in an incorrect mode.
For any camera operating mode where the camera controls the aperture automatically, your lens must be set to the minimum aperture setting - which will usually be f/22. This aperture marking will be the one in orange.
IF your lens IS indeed set on f22 and you still see the fEE, then you may have mounted it incorrectly. Remove the lens and try to carefully remount it (with it set at f/22).
Let me know if you need further help or clarification.
Dec 13, 2010 | Nikon N90S 35mm SLR Camera
When turned on it flashes FE E and I can't take an exposure. Help!
FEE means that you have failed to turn the lens aperture ring to the minimum setting. This is essential on your model as it controls the aperture settings via the command dial on the body.
If you have already set the lens to the minimum aperture (minimum=highest number) then please report back with a comment for additional options and state whether the problem is with all lenses or just one.
If I have solved your problem then please let me know by taking a moment to rate my answer.
Oct 04, 2010 | Nikon N60 35mm SLR Camera
WHEN I PUSH SHUTTER BUTTON FEE LIGHTS UP WILL NOT DO ANYTHING . I DO HAVE NEW BATTERIES IN IT.
Your camera is telling you that you have failed to set the aperture ring on the lens to its minimum value (highest number). This is vital as the F65 controls the aperture completely via the camera body and does not use the manual lens aperture control.
If you still have FEE after doing this then please report back for further guidance., but if I've solved your fault please let me know by rating my answer.
Sep 25, 2010 | Nikon N65 35mm SLR Camera
Nikon N80 error message appears when I turn on camera. Message is f EE in top right corner. New batteries installed did not fix problem
Your camera is telling you that the lens has not been set to it's minimum aperture.
As the camera body controls the aperture, the lens must be set to the minimum (highest number) aperture in order for the camera to be able to select any aperture between maximum and minimum.
If the lens is already set to minimum aperture then please report back for further options, but if my reply has solved your problem then please rate my answer.
Apr 03, 2010 | Nikon N80 35mm SLR Camera
HELP APERTURE PROBLEM! When I attach any lens to the Nikon FM10
This is normal. the lens stay at the largest opening so you can see to focus, then the mechanics will close to the setting when the exposure is made. This is part of the reflex in single lens reflex (SLR). This part staying open when you focus keeps lyou from having to open the aperture to focus and then close it to the correct setting to shoot the picture.
Jan 29, 2010 | Nikon FM10 35mm SLR Camera
Camera flashes "error" when turned on
Check if the aperture is set on anything other than 22. This would generate an error message. the N50 (and other auto Nikon cameras) needs to have the lens aperture set to the smallest -- AutoFocus lenses have a lock on them to lock the aperture at the smallest. Some models, such as the N5, can be set to use either the lens' aperture ring or the camera's command dial to set the aperture, but most simpler Nikon auto cameras can only be set by the camera. Setting the lens to its smallest aperture tells the camera that it can control the lens. If the lens is set to anything else than the smallest aperture, F-- shows up on the camera's LCD, and the camera locks up. Check your camera manual for complete info.
Mar 05, 2006 | Nikon N50 35mm SLR Camera
Photography Logo
119 people viewed this question
Top Photography Experts
pontelemon
pontelemon
Are you a Photography Expert? Answer questions, earn points and help others
