Question about HP PSC 1510 All-In-One InkJet Printer
Landscape print gives dots or lines in the upper margin
When printing a landscape text (booklet), dots and/or lines appears in black in the upper margin (5 mm from the edge of the paper). Working with vista home 32, and its latest drivers from www.hp.be
Anybody a solution? Thank you!
HP 1510 All in one series. Whenever we print landscape, black dots or lines appear on the upper margin. We are using Vista and Office 2000, printing from microsoft word.
  • LaJa Feb 03, 2008
    Yes, have done this already, thanks. I have changed the cartridge and cleaned the cartridge head, but to no avail. The problem only happens with Word (office 2000) and using Vista and only when I want to print landscape using a Word document. It is a software problem that I have now found out. Apparently, they are in conflict, I have to update my microsoft office!! Hope this helps anyone else having this problem, apparently it is widespread.
  • 407 Answers
Unplog your printer.clean your printhead of the printer by a tissue paper.
Posted on Feb 03, 2008
Bizhub c200 printing with streaks of red and blue lines what to do
If that lines are consistent with the red and blue and it does not appear during black and white print that means the cleaning blade in the affected color units need to be replaced
May 16, 2014 | Konica Minolta bizhub 250 All-In-One Laser...
I am a teacher. We have Dell computers with windows 7 on them. Recently our school district downloaded Microsoft Office 10. Since the new microsoft office, my xerox phaser 8500 is printing strange. ...
Hi fsaltzman,
You need to check the margin settings in the print preview option, make sure you decrease the margins that are set by default and try printing a test page , this should work fine.
On the File menu, you need to click Page Setup, and then click the Margins tab.
Here you can adjust the margins as per your convenience.
To View page margins :-
  1. You need to go on the Tools menu, select Options, and then select the View tab.
  2. Under Print and Web Layout options, select the Text boundaries check box.
The page margins appear in your document as dotted lines.
You can use these dotted lines to correct your margins so that your student's assignments are not cut off and there is no large margin as you have mentioned in your question.
You can view page margins in either Print Layout or Web Layout view only, and they do not appear on the printed page.
Hope this helps
May 11, 2011 | Office Equipment & Supplies
I am printing a booklet using the bookfold option in Word 2007 on my Windows 7 laptop. The margins page has normal margins (1,1,1,1) highlighted. Page setup, in Word, says my margins are 1,1,1,1 with no...
Sounds like you need to go into Properties in the Brother, possibly in advance options for a setting that over-rides the printer settings for the page settings.
What happens if you choose a 1.5" right margin in the document.
Mar 25, 2017 | Brother MFC495CW
Unwanted 'dots' on printout
There is a dot somewhere on the drum, remove the drum and toner cartridge from the machine, then remove toner from drum. Look at the shiny roll, you can turn it from the black gear on the side. Once you find the dot use a cue tip dipped into little bit of alcohol and clean it off.
Mar 31, 2010 | Brother MFC 240C All-In-One InkJet Printer
Problems printing a booklet
What size paper are you printing on? Reset the side margin to make narrow and see if that helps.
Sep 23, 2017 | HP Officejet Pro 8500 Wireless All-In-One...
Center and margin lines are appearing in a booklet.
rpcs driver= printer properties--printing preferences--print settings--add/change custom settings---edit--draw border.
May 07, 2009 | Ricoh Aficio 450 Copier
Samsung CLP-500 output problems
i have found that removing the toners, and shaking them side to side, while keeping them horizontal, which seems to spread the toner for even distribution. This can sometimes fix the problems with fading prints. hope it helps.
Margins i think might be a problem with the wysiwyg of the program, some don't do it well, but also excel in particular has a shrink to fit page option, you may find the percentage not at 100%. you can also copy an excel table to word and print from that if it is driving you nuts.
Jan 23, 2009 | Samsung CLP-500 Laser Printer
Designing a document in book form and printing in Word 2007
When you select Book fold for your page setup, Microsoft Word prints two pages on one side of the paper. When you fold the paper, it opens like a book. This option is intended for documents that have more than two pages.
1. Set up your document as a booklet.
When you create a booklet, it's best to start with a new, blank document so that you have better control over the placement of text, graphics, and other elements. You can add a book fold to an existing document, but you may have to reposition some elements once the book fold is in place.
A. Start a new, blank document.
B. On the File menu, click Page Setup, and then click the Margins tab.
C. In the Multiple pages list, select Book fold.
If your document is not set to landscape orientation, Microsoft Word sets it to landscape.
D. In the Inside and Outside boxes, type or select the amount of space you want for the inside and outside margins (margin: The blank space outside the printing area on a page.).
If you need even more space along the fold to accommodate binding, type or select the amount of space you want in the Gutter box.
E. In the Sheets per booklet list, select the number of pages you want to include in a single booklet.
If the number of pages in the document exceeds the number of pages you select for a booklet, Word prints the document as multiple booklets.
F. Select any other options you want in the Page Setup dialog box.
G. Add text, graphics, headers or footers (header and footer: A header, which can consist of text or graphics, appears at the top of every page in a section. A footer appears at the bottom of every page. Headers and footers often contain page numbers, chapter titles, dates, and author names.), and other elements to your document as usual.
2. On the File menu, click Print.
3. Set options for printing on both sides of the paper.
If you're using a duplex printer (one that automatically prints on both sides of the paper)
Click Properties, and then set the options you want. If you have a choice of setting the page orientation and duplex options, select landscape orientation, and flip the document on the short edge or short side.
If you aren't using a duplex printer
In the Print dialog box, select the Manual duplex check box. Word will print all of the pages that appear on one side of the paper, and then prompt you to turn the stack over and feed the pages again.
4. Select the page range you want to print.
If you click Current page or Pages, Word prints the page you indicate, plus the three other pages that belong on the same sheet of paper.
If you click Selection, Word prints your selection using the default page layout instead of booklet layout.
Dec 25, 2008 | Computers & Internet
Help
Hi, solution for your envelope
10 envelopes The print side of the envelopes faces up.
The envelopes are loaded vertically against the right side of the paper support.
The stamp location is in the upper left corner and printed with landscape orientation.
NOTE: For Japanese customers: If you are mailing within Japan, the envelope can be printed with portrait orientation with the stamp in the lower right corner or with landscape orientation with the stamp in the lower left corner. If you are mailing internationally, print landscape orientation with the stamp in the upper left corner.
The paper guide rests against the left edge of the envelopes.
You select the correct envelope size. Select the next biggest size if the exact envelope size is not listed, and set the left and right margins so that your envelope text will be correctly positioned.
Oct 25, 2007 | Dell 810 All-In-One InkJet Printer
How do I print on both sides of my paper
On printers without a duplexer (a device that flips the paper to allow printing on both sides) you will have to print the first side, manually flip and print the second side. If you're using MS Word or MS Publisher you can easily configure the program to organize the pages for you: Start a new, blank document. -Click File, Page Setup then click the Margins tab. -In the Multiple pages section select Book fold. -Set your document to landscape orientation if it is not already. -In the Inside and Outside boxes, type or select the amount of space you want for your margins. -In the Sheets per booklet list select the number of pages you want to include in a single booklet. If the number of pages in the document exceeds the number of pages you select for a booklet, Word prints the document as multiple booklets. -When you get ready to print make sure you check the manual duplex box (should be in the first dialog box that appears when you click on File, Print). Word will print the first page, and then prompt you to take the pages that just printed and load them into the input tray of your printer. The trick is to learn how to orient the pages correctly for your printer. Good luck.
Jun 17, 2007 | HP DeskJet 1600C InkJet Printer
HP PSC 1510 All-In-One InkJet Printer Logo
150 people viewed this question
Seeker5211
Seeker5211
