it wont connect to the internet and i'm not tryin to use wifi. i plug it in directly in the back and it will not connect at all like it is no internet connection whatsoever
Hey,
Im having the same problem....It keeps saying that cannot find IP address...I have read that, it could be that im using bell sympatico and its DSL. Supposibly you need PPPoE.....How do I find that?
Have you tried connecting other devices the same way? Do they connect? What devices? What type of internet connection? If its PPPOe then you may need to set up user name and password.
Comments:
Feb 04, 2008
- OK so its an ethernet connection, have you tried connecting that ethernet port to your pc?
playstation only displays normal resolution. goes blank when i select hdmi settings. it worked just...
(More)
playstation only displays normal resolution. goes blank when i select hdmi settings. it worked just fine before a weather storm. could the lightning have affected it somehow?
ps3 say serious tech error on red screen ne way 2 fix it? I reformatted the Hard drive then it still...
(More)
ps3 say serious tech error on red screen ne way 2 fix it? I reformatted the Hard drive then it still went red. Is it the system itself?
switched tvs and now video settings wont allow it to work is there any quick fix or do i need to...
(More)
switched tvs and now video settings wont allow it to work is there any quick fix or do i need to hook it to my old tv to change settings first
new ps3 slim bought in california US for use in INDIA while plugging in the power chord , forgot to...
(More)
new ps3 slim bought in california US for use in INDIA while plugging in the power chord , forgot to use adapter to convert 240V to 120V and put power switch on for few seconds before realizing . changed to volt adapter and tried to switch on ps3 console but only briefly green flashes. Allow the system to rest overnight after switching off, but again same problem! Please advise
