Question about Hotpoint 23 in. BFI68 Built-in Dishwasher
Hotpoint BFI680 My dishwasher (hotpoint BFI680) works on occasions but more often than not goes on then it beeps and the 4th LED light ("eco auto") light is flashing. Water is getting through to the machine fine and ive tried resetting the machine - any suggestions?
  • charwood233 Jan 07, 2009
    I have the same problem. It seems that machine is draining out and the pump (sounds like a pump) is staying on indeffinately. The dishes are aslo wetter than normal suggesting the dry cycle has not been completed/started.
SOURCE: dishwasher error codes please help
I too had this problen today. Printed off a manual from the Hotpoint website. Very helpful troubleshoot section. Anyway, flashing eco and fast lights and beeping sound indicates 'water feed pipe blocked' You need to check the water inlet connections on your tap.However, when we pulled it out we noticed the blue water inlet pipe was slightly kinked. Straightened this out and hey presto! It works fine again. How this happens when its worked ok for 18 months will never know but still. Try it! hope this was helpful...shewoo
Posted on Jul 21, 2007
  • 351 Answers
SOURCE: Hotpoint Dishwasher BF1620
ive not worked on hotpoint dishwashers,does the dishwasher drain? at the point it plays up is it supposed to be filling or washing.check the filters inlet valve etc.do you still have the manual for the dishwasher.the flashing lights are most likley a fault code but we dont get hotpoint dishwashers in australia.sorry i cant be of more help.Ian
Posted on Mar 23, 2008
SOURCE: hotpoint dishwasher bci450
Here are the eco related error codes for your washer..
1)Light 3 (eco) flashes. Water is present in the flood catching tray at the bottom which usually indicates that there is a leak somewhere. More often than not this is just a pipe with a poor fitting and simply tightening the clip is enough to stop the leak. Our machine had a very slow leak from one pipe (not enough to trigger the alarm) which was fixed in this way. The leak is detected by a small float switch located in the flood catch tray.
Undo 4 screws on the metal plate under the dishwasher 3 at the front 1 at the back, this reveals The pump check the seals are in place on the waste pump.
2) Wash indicator lights 3 + 5 (eco + pre) flashing rapidly. Filter is clogged. Pull out the filter and clean it.
3)Runs for approx. 3 minutes and then stops. Lights 3 + 4 (eco and fast) flash. Probably caused by being plumbed into a hot rather than cold water supply. The incoming water is hotter than required for the wash which causes the machine to cut out. Plumbing the machine into a cold water supply will fix the problem with no apparent long term problems.
Posted on May 23, 2008
  • 3 Answers
SOURCE: Hotpoint FDW60 dishwasher - flashing lights
check the filter.
Posted on Jun 06, 2008
SOURCE: hotpoint dishwasher dwf50
i had the same problem and like an idiot paid for hotpoint to come out and all the guy done was tip the dishwasher backwards to empty the water(which he didn't clean) and tell me that im using to much rinse aid and salt coz we use 4 in1 tabs hope this helps smiley
Posted on Jun 13, 2008
Hotpoint dishwasher 4th & 6th lights flashing
You will need to provide the model number of the dishwasher. However, the likely causes of the lights flashing are many, including water inlet failure, blocked drain filter, leaking seals causing flood switch to trip. You may want to go to the Hotpoint site and find the manual for your model.
Nov 05, 2012 | Dishwashers
The program light goes off and the BF162 doesn't start...
When you keep the button pressed for a few seconds the lights go off, this resets the dishwasher. Then press the p button again to the program you want 1st light is heavy soil 2nd light is normal soil, 3rd light is eco wash, 4th light is rinse. At the end of the cycle the program light you have selected will flash.
Apr 24, 2009 | Hotpoint 23 in. BFI62 Built-in Dishwasher
Hotpoint FDW60 flashing eco light
if the eco light is flashing, this indicates that saftey float switch has activated in the base of the dishwasher usually caused by a leak, a polystyrene float activates a microswitch which cuts of the water inlet supply
Mar 28, 2009 | Hotpoint 24 in. FDW60 Free-standing...
Hotpoint fwd60 eco and intensive lights flashing
Hi, I have a Hotpiont FWD60, the "delicate" lamp has started flashing about twice a second. Any ideas? Thanks, Nick
Mar 04, 2009 | Hotpoint 24 in. FDW60 Free-standing...
Hotpoint fdw60 eco error code
I had this problem too, but discovered the cause and the remedy.
The flashing eco light signifies that the drain sump has water in it. Before the machine takes on water it checks a float located in the sump. If the float says that there is water in the sump then the machine presumes that there has been a problem when draining and decides not to take on any more water.
In my particular case, the sump collected extra water after the machine has last drained itself because the bottom spray arm has come off and allowed some water to enter the machine. Make sure that you check that!
The simple solution is to empty the sump of water. Do this by tipping the machine onto its right side. Warning! You will get wet feet! There was about a 1/4 pint of water in my dishwasher.
After that you should find that your dishwasher works perfectly again! Why Hotpoint couldn't include this simple task in their manual I'll never know! Health & Safety I guess...
HTH!
Mar 24, 2008 | Dishwashers
Dishwasher error codes please help
Apr 26, 2007 | Hotpoint 24 in. FDW60 Free-standing...
Open Questions:
See all Hotpoint 23 in. BFI68 Built-in Dishwasher Questions
Hotpoint 23 in. BFI68 Built-in Dishwasher Logo
345 people viewed this question
Top Hotpoint Dishwashers Experts
Marvin
Marvin
Are you a Hotpoint Dishwasher Expert? Answer questions, earn points and help others
