Back to:
Tags:
Intel Network adapter
PRO/100 Server Adapters and Novell 4.11
By Brad - usenet poster
We are also experiencing the same communication hang up problems reported by others on this forum.
Hardware: Compaq Proliant 5000 servers,  Intel PRO/100 Server Adapters (PBA 660114-006)
Software: Intranetware 4.11 w/IWSP5B patch kit.
Symptom:  Communication stops after running a couple of hours.  PACKETS SENT and RECEIVE of MONITOR LAN/WAN statistics stop incrementing.  Server is running but unable to communicate in or out.
We first tried the odi set from the diskette (NBI, MSM, ETHERTSM, E100SNW, VLAN).  Then tried 3.30 versions of NBI, MSM, ETHERTSM from IWSP5B. Then we downloaded the latest 100VDISK set, and installed all drivers and NLM's as a set.
We always experienced the same problems, and have been forced to replace the Intel NICS.
What is the definitive answer to which exact NBI, MSM, ETHERTSM, E100SNW, AFT, VLAN NLM's and drivers INTEL has certified with Novell patch kit IWSP5B?
Brett
I have the same problem Post a new problem
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
Best Solution
posted on Aug 10, 2005
FixYa! (100)
Odud
Rank:Apprentice Apprentice
Rating: 0%, 0 votes
Jeff,
I have not heard of a specific problem loading iwsp5b.
If you have HIMEM.SYS in your server CONFIG.SYS file, try
removing it before iwsp5b install.
 IWSP5B updates you to 3.31 ODI specification.  For Intel(R)
 PRO/100B and PRO/100+ adapters you can use our 3.31 spec drivers
 from 100pdisk.exe
 http://support.intel.com/suppo rt/network/adapter/100PDISK.HT M
 For the PRO/100 adapter (also called PRO/100A adapter), replace
 your ethertsm.nlm Jeff,
 from 100pdisk.exe
 your ethertsm.nlm and msm.nlm with the ethertsm.nlm and msm.nlm
from the \common\sys\system directory of iwsp5b.EXE (Novell
archive).
You will also need 100acl32.exe.
http://support.intel.com/suppo rt/etherexpress/pro100/100ACL3 2.HTM
Hal G
 Intel Internet Support Engineer
 *All other brands and names are property of their respective
owners
Was this solution helpful? Show your Appreciation by rating it:
Thank You!
Was the solution helpful?
Show your appreciation by commenting on PRO/100 Server Adapters and Novell 4.11:
I don't want to Accept this solution
Solution #2
Not Rated (0)
Cornish
Rating: 0%, 0 votes
Thank You!
Solution #3
Not Rated (0)
maartenw
Rating: 0%, 0 votes
We have a Pro/100 PCI busmaster and I cannot
 get the iwsp5b patch to load. I keep getting
a "page fault exception" error.  According to
the novell web page someone reported a similar error
with another pci busmaster card and the fix was
to remove the card.  It also said it has something
to do with the odi drivers.  Are all pci or pci
busmaster cards not working with the new novell patch?
Thank You!
Solution #4
Not Rated (0)
2Pansy
Rating: 0%, 0 votes
Jeff,
 from 100pdisk.exe
 your ethertsm.nlm with the ethertsm.nlm from the
  \server\33spec directory of ODI33F.EXE (Novell archive) and
 replace your msm.nlm with the msm.nlm from the
\server\33spec\41X
 directory.  You will also need 100acl32.exe.
Hal G
owners
Thank You!
Solution #5
Not Rated (0)
Janice
Rating: 0%, 0 votes
Brett,
These are the versions (from IWSP5B) that we have tested with.
NBI.NLM
NBI.NLM      08-29-97
MSM.NLM      02-03-97
ETHERTSM.NLM 02-03-97
E100SNW      11-07-97
VLAN.LAN     05-22-97
AFT.NLM      12-16-97
Hal G
owners
Thank You!
Can you Help with these Network Adapters problems?
Network Adapters
hello sir/madam I have Asus (M2N-VM HDMI ), I was...
Network Adapters
The instruction at 04499gda regerancad memory at 0000008....
Network Adapters
hello sir please help me
Network Adapters
I am reinstalling this in my old Pentium 2 but do not...
Network Adapters
our belkin wireless G plus mimo usb network adaptor is not...
Loading problems.
Repair Service
Find Network Adapter Repair Service Provider Near You:
Browse the Repair Service Directory
Repair Service Providers, Get Listed FREE
Prescreened Contractors
Get Matched to Prescreened Computer Networking Professionals
Category
Zip code
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
