Question about Olympus SP-350 Digital Camera
Something with lcd
Hello, i have really not understanded problem with my SP-350
In one day something happened with a LCD screen: he began to invert colors. (on screen present view like a PREDATOR (from video with Shwarzenegger) view)I think u understand what about i talk
i just check it - beaten pixels are not present. Camera was not dropped in water, and just not dropped.
Thanks, but color depth is +-0, contrast same
i think problem in CCD :(
may service center fix it? and how much this cost?
Posted on Feb 03, 2008
  • 407 Answers
Try to lower the colour depth & adjust contrast
Hello, I'm having an issue with my Sanyo DP42848 LCD TV. When you power it on the LCD panel turns on for about 2-3 seconds then immediately turns off. You can power cycle the TV over and over and every...
It only tells us that the inverter cable needs to be reseated or replaced. It's not an expensive repair so fortunately you can consult any local certified technician and have them work on this.
Aug 30, 2011 | Sanyo DP42848 LCD TV
Broken LCD screen
your answer to this problem is easy. First take the batteries out of the camera, then open the camera ( screws should be in the back) the screen should just pop out of the cover and there is a ribbon cable that connects the screen to the circut board. Gently un-hook that ribbon where it plugs in to the board there might be a slid lock to hold the ribbon in place, it should unlock when you pull the cable out (memorize what position the ribbon is before unplugging). Now the fun part, do the same thing to the other camera, (carefully). To install the new screen, plug the ribbon back into the slot and it should be snug, if not there is a lock on it, gently push it back away from the ribbon ( a little finger pressure). Now, simply put it back together the same exact way you took it apart and don't forget the batteries. Have fun taking pictures...
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/stephen_171aeeebef53a898
Nov 01, 2007 | Olympus SP-350 Digital Camera
Laptop screen is very dim. There is a very faint image. The LCD screen is brand new so that's not the problem
As per your description, it is probably your inverter which is faulty.
The inverter is an electrical device which 'lits' the LCD. Without the inverter and the bulbs it powers, the screen would be too faint to be seen correctly.
To test if the inverter is defective, just turn on your laptop in a dark space, then put a flashlight on the screen to see if you have a fainted display. If you can see something, it is the inverter which is defective and should be replaced.
If you are handy, you can also remove the screen cover to see if there is a neon like light which lits up behind the LCD. If you can see the light, it means that the inverter is just working fine and that the is with the LCD itself, but if there is no light coming from behind the LCD, then you need to replace the inverter.
Picture of an inverter.
Replacing the inverter:
1. After removing the screen 'cover', locate a small circuit board (usually below the LCD). Unplug the electrical cables and replace.
Hope this posts helps you.
May 16, 2011 | Computers & Internet
My hp laptop turns on bt the screen will not come on how can i fix it
As per your description, there are two possible causes. Either the LCD is out of order and needs to be replaced, or that the inverter is defective.
The inverter is a electrical device which 'lits' the LCD. Without the inverter and the bulbs it powers, the screen would be too faint to be seen.
If you are handy, you can also remove the screen cover to see if there is a neon like light which lits up behind the LCD. If you can see the light, it means that the inverter is just working fine and that the is with the LCD itself.
In case the inverter is working correctly, try to check the LCD cables. If all cables are well connected, your LCD has to be replaced.
May 09, 2011 | HP Computers & Internet
Eepc 900 HA, MONITOR IS BLACK. IT LOOKS LIKE IS TURN OFF
Good day sir/maam, if you look very close to the LCD, you can see something like windows, but its really dark? chances are your LCD just lost its inverter module that powers your LCD's backlight. visit a local notebook dealer to confirm the problem. Ask if they have sources of LCD inverters for your laptop model. the service and replacement also.
Oct 02, 2009 | ASUS Eee PC 900 Notebook
LCD flashing
If the screen is just flickering on and off then chances are that there is a loose connection on the inverter, this type of fault can happen over time and is mostly due to opening the lid and closing it.
If you want to tackle the problem yourself the inverter is located at the bottom of the screen and is hidden behind a piece of frosted plastic.
For most people this is a fairly easy job as it just involves removing the screen bezel (plastic screen surround)
If you need any more advice please post back
Regards
Jun 21, 2009 | Lenovo ThinkPad T61 Notebook
My Olympus SP-350 cannot focus, wierd colors in the LCD screen
We took it to a camera shop,and found the sensor was blown.
May 20, 2009 | Olympus SP-350 Digital Camera
Black screen no picture
Your inverter has died and is a very common fault with all LCD monitors. The inverter powers the lights that sit behind the screen so you can see what is happening. So no lights, no picture.
Shining a bright torch at an angle from the top you will be able to see the image on screen, but very feintly.
This is something your local TV repair shop will be able to take care of fairly cheaply. It's not a good idea to play around in these types of monitors unless you have some understanding of what lay ahead.
Let me know if I can help further.
Apr 08, 2008 | BenQ FP91G+ 19" LCD Monitor
No display object on LCD viewer screen
press the disp/guide and see if the display changes..if not then repair
Jan 19, 2008 | Olympus SP-350 Digital Camera
Olympus SP-350 Digital Camera Logo
79 people viewed this question
Top Olympus Cameras Experts
Steven Wander
Steven Wander
Jerry Greenberg
Jerry Greenberg
Are you an Olympus Camera Expert? Answer questions, earn points and help others
