Question about Holmes Products Holmes 3 Gallon Cool Mist Humidifier Humidifier
Hm495tg White powder on everything. Easy to see on tv screen and eyeglasses! What is wrong with this unit? holmes hm495tg
Nothing. The white powder is most likely minerals in the water you are using. This is an electrostatic humitifier and it turns water into vapor without using a filter so the minerals are not filtered out. I suggest trying distilled water or water from a Brita system (this system removes minerals).
Posted on Jan 14, 2009
    Problem Solver:
  • 5 Answers
Possibly calcium or other deposits from the type of water you are using in the unit..........
Posted on Feb 03, 2008
6ya staff
SOURCE:
Air Innovations humidifier has everything covered in a white powder why
What is everything. The filter the outside, ??? Do you know what the white power is?
Mar 19, 2014 | Humidifiers
Refill cap center plunger is broken
I dont see any other way to fix other than purchase another cap...
I ordered 2 replacement caps from here they were the cheapest tat I found http://www.jardenstore.com/productdetails.aspx?BrandId=494&pid=1783 but they seem to be out of stock at the moment These http://www.appliancefactoryparts.com/humidifiers/holmes/holmes-water-tanks.html are 3 dollars more here hope this helps
Jan 29, 2014 | Holmes Products Warm Mist HM5700...
Holmes 2060w runs but no water is evaporating
change the filter and check for fan moving to circulate the air in the unit
Nov 24, 2013 | Holmes Products Humidifiers
Holmes HM5700 Won't reset. Screen comes up with reset and starts counting down form 450
Mine did this also so I unplugged it and took it apart and cleaned it. I used a sponge to clean all around the heating element with a mixture of white vinegar and water and also put some in the water resevoir and shook it for a few minutes and rinsed it out. It ran perfectly after I did this. It gets mineral deposit build up after a while so you might need to do this every week. There are directions on the back of the humidifer that explain this and what you should do. I hope this helped
Oct 30, 2010 | Holmes Products Warm Mist HM5700...
How do you change the filter in a holmes cool mist
http://www.jardenstore.com/manuals/MANUALS/HM1865-U_43_74701759.PDF
here is the website for the manual. when you download it go to the maintance section and it will let you know. if not. basically all you have to do is turn off your unit first. take the base and the tank off take out the wick filter disgard and put in new one. put everything back and turn on unit. and it should would like new
Aug 15, 2009 | Kaz 3300 Humidifier
No mist!
unfortunately on a cool mist unit the mist shouldn't show up. on most units that's what it does. the warm mist units show the mist.. the best way to tell is if you put your hand over the spout that the mist is suppose to come out of for about 2 minutes and you pull it away and it feel clammy then it's working. if your hand is still dry please let me know and i'll see what else i can do for you.
Feb 26, 2009 | Holmes Products HM500-UC 1 Gallon...
Wondering if damage to Holmes HM500 humidifier is fixable...?
unfortunately running the unit for too long will permanently ruin the unit. there isn't really a way to fix it. i do deeply apologize for that. so unfortunately you might have to replace the unit.
Nov 22, 2008 | Holmes Products HM500-UC 1 Gallon...
Humidifier does not reset
According to Holmes, one of the causes of the Reset light staying on is scale buildup on the heating element.
Remove Scale: Allow to cool before maintenance.
1. Repeat steps 1-5 in the Daily Maintenance section.
2. Clean the base by partially filling the base with one
8-oz cup of undiluted white vinegar. Let solution stand
20 minutes, cleaning all interior surfaces with a soft
brush. Dampen a cloth with undiluted white vinegar
and wipe out entire base to remove scale.
3. Rinse with clean warm water to remove scale and the
white vinegar solution before beginning to disinfect
the tank.
4. Wipe the heating element clean with a soft cloth after
it has had chance to cool.
If the scale has really built up it might take longer than 20 mins for the vinegar to get rid of it and you might need to refresh with new vinegar.
Your Manual can be found at this link:
http://www.holmesproducts.com/Manuals/Holmes/HM5250-UC_English.pdf
Good Luck.
Apr 07, 2008 | Holmes Products HM5250-UC Humidifier
Humidifier doesn't stop
I had the same problem if you dissasemble the unit you will probably find a capacitor between two blue wires has blown out
Mar 30, 2008 | Holmes Products Cool Mist HM3500...
Will not reset
Per the operators manual you have to reset it. 1. Unplug the unit
2. Remove and refill the water tank, being sure to follow the Daily
Maintenance Instructions. Replace the tank onto the base.
3. Wait 5 minutes for the Automatic Shut-Off to reset.
4. After the 5 minutes, plug in the unit and turn the unit on to HIGH
(HI). The RESET light should now be off (if not repeat steps 1 through
3). In about 2-3 minutes, the humidifier will begin to produce
moisture.
Jan 03, 2008 | Holmes Products (048894556579) 4 Gallon...
Holmes Products Holmes 3 Gallon Cool Mist Humidifier Humidifier Logo
365 people viewed this question
Top Holmes Products Humidifiers Experts
Ekse
ray gallant
ray gallant
Katherine Guy
Level 1 Expert
Are you a Holmes Products Humidifier Expert? Answer questions, earn points and help others
