Broken plastic bit that connects the sata cable to the maxtor hard drive
I broke the plastic retainer that holds the sata cable to the hard drive GB 500. Looking at it I think the disk controller will have to be replaced if the plasticing mounting is mouded to the controller circuit board. Can you help? .
  • 43 Answers
Not really,if the retainer on the HDD is broken.
You could try embedding the sata cable to the HDD using a contact adhesive,but ensure none gets inside on contacts.This is only a qik fix but I have use in the past to get by.
Posted on Feb 04, 2008
I have a Hitachi internal hard drive that i would like to use as an external hard drive to boot from my e-sata port, i have a Toshiba portege and i curently use two hard drives to boot from, one for work...
yes you need power to the external hard drive whether ide or sata possibly depending on your hard drives power supply
12V+5V AC sata Adapter Power Supply HDD HARD DISK DRIVE
hope it helps
Mar 27, 2012 | Hitachi HTS541612J9SA00 120 GB SATA Hard...
Will not recognize sata drive need to know necessary connections
There are only two connectors on a SATA drive, namely POWER and DATA.
Check that both cables are securely connected.
Try the disk-drive in some other computer.
Nov 02, 2010 | Maxtor MaxLine Plus II 7Y250MO 250 GB SATA...
Usb input from hard drive to computer is broken
Will replacing the data-cable replace the broken-off piece?
If not, then for about $30, you can buy a new "empty" external case, and then "transplant" your current disk-space into the new case.
Take your current external drive to the computer-store, so that the new case that you buy will be the correct case for your existing disk-drive.
Of course, because you have a "small" (100GB) disk-drive, any warranty for the disk-drive probably has expired, and it would be good "preventative-maintenance" to buy a new external disk-drive, before your current disk-drive unexpectedly "quits" on you.
Jun 15, 2010 | Maxtor Personal Storage 3100 (M01E100) 100...
I am looking for a user guide for a Black Armor 320 GB Maxtor, ¿can you help?
why would you need one ? Maxtor has a jumper label
on their face that is all the info you'll need to operate
this HDD , the rest is in the OS set up NTFS or
FAT32 , stick with the NTFS and you'll have no
problems , the jumper label indicates using as a
master , Slave or a Cable select , the IDE cable
in your computer if using an ATA HDD has two
connections the top one is the master the lower
one is the slave , if the HDD is a SATA it has its
own special connection which is marked SATA
Jan 19, 2010 | Maxtor Hard Drive
6 pin port broke off inside maxtor port. hard drive mini(bad construction). When I hold the piece just right it will be recognized by the computer. Can some soder the the piece back on?
dferdetta
If your SATA port broke I would recommend you call Maxtor's support if you are still under warranty. Note some hard drives have upto a 3 year warrranty from the manufacture date.
If you are not in warranty you might try this but I would recommend that you pulll all your data off first just in case this does not work.
Hope this helps
Issken
Jan 12, 2010 | Maxtor Hard Drive
How do I set the jumpers on my Maxtor DiamondPlus 9 80 GB SATA /150 HHD drive as a second drive.
SATA drives are jumperless -- each drive has its own cable to the motherboard or controller -- so there's no setting on the drive to say "primary" or "secondary" as there was with IDE.
The connection on the controller or the motherboard will determine which drives are primary and which are secondary.
Jan 06, 2010 | Maxtor Hard Drive
How 2 install in my new hp also have a burner on same cable burner works but both dont work 2gether
a dvd burner on same bus as a hard drive..the cable needs to go to hard drive first then the dvd drive..is that the case? also, if it's SATA, the order on which cable comes from the board to hard drive SATA 0 is critical
Dec 06, 2009 | Maxtor (6L250R0) 250 GB Hard Drive
Maxtor one touch iii unable to read drive; the external hard drive previously worked and now it doesn't read the drive
please remove the raw drive from the casing
it may be a sata drive of maxtor please power it up directly to your pc with a sata power and sata cable
the drive will get recognised .
if it gets recognised it means the interphase between the disk and the ext casing has been damaged
if you fail , the disk has lost its firm ware or rom chip rom bin file.
both can be flashed and recover the drive
BEcaerful you can break the plastic casing while removing the raw drive as it had been machine dyed and fixed and you may not find any screw s outside
datarecoveryfactory
Sep 04, 2009 | Maxtor OneTouch III FireWire 400 (F01G500)...
Maxtor 3200
Seagate troubleshooting Error Code 10, states that drive has failed. (Seagate bought out Maxtor)
Before you resign yourself to everything is lost on this harddrive, how about trying one more thing?
How about putting the harddrive inside in a new external enclosure, and see if it works? I suggest that perhaps the external enclosure it's in, is bad.
The harddrive inside is a 3.5 inch harddrive. Same width as used by a desktop computer. It is a Sata harddrive.
Here's an example of a 3.5 inch Sata, external enclosure,
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=3901268&CatId=2780
Just pop the external enclosure open that holds it now, take it out, and install it into an external enclosure like the example above. Plug in the USB cable.
Don't know if this applies to your particular Maxtor Personal Storage 3200, but when I went to search for the type of harddrive it uses just now, I ran into thsi, and thought I would pass it along. http://www.seagate.com/www/en-us/support/downloads/personal_storage/ps3200-sw)
May 10, 2009 | Maxtor Personal Storage 3200 (U01E200) 200...
Maxtor 250 GB SATA problem: Foreign disk problem
Simple you need to update your bios by downloading bios updates for you motherboard. Then it should recognise your HDD. The yellow triange just means your mboard does not have the necessary drivers to recognise the device. thanks
May 19, 2008 | Maxtor (6B250S0) (6b250s0-20pk) 250 GB...
Computers & Internet Logo
239 people viewed this question
Alun Cox
David Payne
David Payne
