Question about Hoover SE230 Front Load Washer
Electrical problem No red power light on and a burning smell, the fuse has also blown. The fuse has been replaced and still no red light?
  • 625 Answers
Motor winding or wiring has shorted to chassis ground. unplug the motor connections and see if fuse still blows. if you have a multi meter use it to find the shorted conductor. there may be a black spot where its insulation has broken down and arced to ground.
Posted on Feb 03, 2008
Hoover model 70930 vacuum. System check indicator stays red.
If the smoking at the base smells like burned rubber it's probably your belt. If it smells electrical it's probably your motor or an electrical problem.
Mar 08, 2017 | Hoover Vacuums
How do I replace the fuse on a rainbow vaccum?
The D4 model Rainbow has a Thermal Cut Off
This has to be manually replaced. It is attached to the Field 120v D4
If this has blown, then most likely something is causing. The Armature Tall 120v D4 could be going bad.
You can also speak with our technical support team Contact Us
RainVac
Jan 27, 2016 | Rainbow D4se Classic Canister Vacuum...
Hi iam having an electrical problem after jump starting car at first i put the jump cables wrong way round !! then corrected error started car ok but had a fuse burn smell ! sho checked everything and...
check all positive wires coming from battery sounds like you melted one and it's touching something it shouldnt, Thats what u smelled, clean and tape damaged wire(electrical tape) check wires behind fuse block also
Aug 30, 2011 | Hyundai Excel Cars & Trucks
My 06 GSXR 600 just died while driving, and the elect were also off, I waited over 3h and then tried to started back again but there were no Elec at all, not even the lights were on and there were a hint...
Hi first thing to check ins that you have 12 volts at the battery, it is unlikely that the burning is coming from the injection ecu, if you have 12 volts in the battery but no ignition lights the chances are the burning you have smelled is an electrical short circuit, which has caused the fuse to blow, in addition to the fuse located in the fuse box, check the starter relay, most models incorp a main fuse here, follow the poss red wire from the battery to locate the relay here the wire will split in to 2, check here for any fuses, secondly if you have no life at all in the battery not even enough to make a glimmer on the ignition light, the burning you have smelled could have come from the regulator rectifier in the bikes charging system check the rear of this unit for any burning to the silicone sealent, a fault with this could have blown a fuse also, it would be difficult to estimate a repaire cost without knowing the fault, try turning the ignition switch to the lock park position and check if rear light iluminates, this uses a separate ignition live, if this lights you would then know if you have suficiant power in the battery, to iluminate the ignition lite aand the fault would not be battery related,
Oct 27, 2010 | 2008 Suzuki GSX-R 600
My door locks stopped working, I was sitting at a red light and smelled a burning smell. My dash lights no longer worked. I have head lights but no tail lights. I took it to the mechanic and asked him to...
A major short. I wouldn't use the car. Especially if you smelled a burning smell. because your car can catch fire. This is very rare to happen to a car, but take it to an electrical system repair garage.
Aug 15, 2010 | 2002 Mercury Mountaineer
My stove digital lights are off and it will not light. The gas do work; I can smell it when i turn it on. what should i do
Well first you want to verify that the range is getting power from your electrical outlet. It is possible that the GFCI has tripped causing no power to the outlet. Once you have verified that there is power to the range you will next need to unplug the range and remove the back panel to do a visual inspection. Verify that there are no loose or disconnected wiring. Also look for any melted wiring or parts. Also check for any burned electrical odor. There might be an inline fuse located inside the range usually located on the hot side of the incoming electrical wire. Verify that this fuse is not blown. If the fuse is bad then you could try replacing it but if it blows again then there might be a short somewhere. And make sure you replace the fuse with the same rating that you removed. If the fuse is good then you might have a bad control board.
Jan 16, 2010 | Whirlpool GS460 Gas Kitchen Range
Lincoln digital dash electrical problem
You can take the car to Autozone or Oreillys for a free scan.
If you happen to need a digital dash, you can get one at a Salvage yard. Since you mentioned burned wiring, your car insurance may cover some of the repair under fire insurance. Give them a call.
Most likely since the A/C and radio worked, they are okay. The failure could be the dash display.
Sep 30, 2009 | 1996 Lincoln Town Car
Power supply problems
Have ordered a new power supply PCB as too many parts need replacement. Best to buy the whole lot.
Ventilation seems to be an issue with this unit, I am thinking of installing a small fan at the back to cool the voltage regulator and main transformer.
Thanks.
Jul 07, 2009 | Televison & Video
Fuse blew on power now stuck in Protection Mode
Sounds like the out put stage of the amp is shorting, They are either 4 large transistors attached to an aluminium plate (heatsink) or one large chip with heatsink. also sounds as the driver stage went too when you switched it on the second time. If you know nothing of electronics I suggest you take it to an audio repair shop, as it is cheaper to repair than replace high power amplifiers.
Mar 29, 2009 | Audio Players & Recorders
Burning smell (electrical) from my washing machine
possibly the suppressor capacitor. take lid off and trace where mains input is connected and that is the suppressor. they sometimes go pop
other possibility is the neon burnt out
Oct 03, 2008 | Smeg WD16BA Front Load Washer / Dryer
Hoover SE230 Front Load Washer Logo
130 people viewed this question
Top Hoover Washing Machines Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Hoover Washing Machine Expert? Answer questions, earn points and help others
