Question about Mitsubishi WD-62525 62" Rear Projection HDTV
Mitsubishi WD-62525 DLP has no picture
No picture on TV, just a faint pink background. Thought it was the lamp, so I replaced that but still have the same problem.
  • johnphillipl Nov 13, 2008
    Mitsubishi WD62525 tv timer keeps blinking. the tv will turn on after a while but just checkered screen. code 12 is what i have been getting. could it be a fuse or a bad power supply. can someone tell me how to check or replace.
    thanks
    President:
  • 4,402 Answers
Here's something that might also be useful. After you turn on the set, and get the regular red blinky lights, hold down the Device and Menu buttons together for about 5 seconds.
The Power light will start to flash in a two digit sequence.
For example, 3 flashes, then 7 flashes = 37.
Here are the error codes, and the corresponding problem:
12 = No error detected, check power supply.
32 = Lamp Cover is open.
33 = Air filter cover is open.
34 = Lamp abnormality
36 = Light Engine (DMD or Lamp Fan stopped)
37 = Exhaust or Lamp Ballast Fan stopped
38 = Lamp Temperature High
39 = DMD Temperature High
41 = Short is detected
44 = DVI cable between FMT and Engine disconnected
Posted on Feb 11, 2008
The lamp went out in our wd-62525. I replaced it and cleaned the filter, now it makes a strange noise every few minutes and the picture gets distorted, then it's fine.We have had this set for only 16 months and have had to replace the mother board. What do you think the problem may be?
Posted on Feb 18, 2008
SOURCE:
I have a Mitsubishi TV Model# wd-62528, the red light comes on on the lamp light
Need to replace a new lamp. Or if you still see picture, go to menue and reset lamp. I f no picture, need to replace a lamp.
May 09, 2010 | Mitsubishi WD-62525 62" Rear Projection...
Do i need to change my lamp? or is something else?
is your tv a dlp?
maybe it can be you tv lamp..
need to know first.
Jan 25, 2010 | Mitsubishi WD-62525 62" Rear Projection...
KEEPS SHUTTING OFF
What type or TV is it DLP , LCD, Plasma?
DLP -----> LAMP--------->go to this 2 sites
http://www.discount-merchant.com/SearchResults.asp?Search=Mitsubishi%20WD-62525%2062
http://www.discounttvlamps.com/mitsubishi-tv-lamps-s/20.htm
PLASMA------->Digital boar or On switch it depends ... can you go on the Display Menu and it looks goo?
do you see any spots?
LCD-------------> You need DMD Bord
good luck tell me more so we can figure it out!
Jan 23, 2010 | Mitsubishi WD-62525 62" Rear Projection...
Tv totally black, with the red light of lamp on.
sounds like the 34 error which is caused by the power board capacitors. you can get the repair kit that should repair that issue. The kit contains the replacement capacitors and step by step instructions. Heres a link to the repair kit for your model.
http://servicemanuals.vstore.ca/product_info.php/pName/mitsubishi-v26-dlp-power-pwb-repair-kit/cName/repair-kits
Jul 06, 2009 | Mitsubishi WD-62525 62" Rear Projection...
Replaced lamp, no picture, turns to red light
please make sure to place Lamp Door/ Cover after installation of new Lamp in TV.
Jun 11, 2009 | Mitsubishi WD-52525 52" Rear Projection...
WD-62525 part #915P026010
Part number ( #915P026010 ) you wrote is called Lamp (bulb) of Mitsubishi DLP TV.
This part is available on Parts Store approx on $200
Thank you.
Oct 07, 2008 | Mitsubishi WD-62525 62" Rear Projection...
Dark picture problem
did you change the lamp with an original or bulb only - mitsubishi only sells the lamp and housing!!!
never use generic
Oct 06, 2008 | Mitsubishi WD-62525 62" Rear Projection...
Mitsubishi 62" dlp wd-62525
The lamp is either defective, not connected properly to the wiring or plugs (careful alignment required on the two connections), wrong type bulb, or the front panel is not replaced properly to trigger the panel sense switch (lower right side of panel)
Sep 02, 2008 | Mitsubishi WD-62525 62" Rear Projection...
Mitsubishi Projection TV WD-62525
Could be quite a few things wrong. first I would do self test diagnosis and see what error you get, then check that area. It could be a bad Ballast or it could be Fuse F9a09 and the Light Engine. It also could be Caps C9a37 and C9a38. For additional info www.ctechnicians.com
Dec 10, 2007 | Mitsubishi WD-62525 62" Rear Projection...
Mitsubishi WD-62525 62" Rear Projection HDTV Logo
664 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
