Question about SAMTRON 55V 15" CRT Monitor
Cleaning inside of monitor
I have Samsung Samtron 55V monitor and want to clean the dust inside the monitor. How to open the case cover? What precautions to take to avoid shock? Should we blow the dust using compressed air... Pls help
    Scholar:
  • 160 Answers
Hai,
We can clean the Monitor with the below precautions but should not be done while under warranty.
1. Unplug the power cable and signle cable
2. Place the Monitor on a table
3. Place a card board infront of the montior
4. Reverse the monitor by placing it safely
5. Un screw the bolts which are fixed on four corners
6. Remove the cover safely
7. By using the blower or brush clean the dust inside the monitor
8. Let it be open for few moments and close the cover
i think the problem of cleaning the monitor inside is solved
thanking you
Posted on Feb 21, 2008
  • 46 Answers
I never heard of cleaning a moniters internals. but yeah go ahead. use a artist medium paint brush and compressed air. watch out for compassitor it will still have a live charge even if unplugged.
Posted on Feb 03, 2008
I can't open Monitor
there will be 2 plastic lugs on the top of the monitor. using a flat blade screwdriver you can undo these
May 12, 2010 | SAMTRON 55V 15" CRT Monitor
How to open back cover of samsung 55v moniter
Read somewhere that you need to insert a blunt screw driver in the slots between the cover and the the top of the front cover and press down lightly. hope this helps...
Feb 01, 2010 | SAMTRON 55V 15" CRT Monitor
My samsung 55v samtron monitor get wet and now it is not powering on what may be the problem what spares i need to change
vry critical....
however look mainly for the smps section..the fuse, bridge, ic (dp104c) & hot (c5404), high value resistances, diodes, opto-coupler ic, ntc, switching transistors n other associative transistors..open the final anode cap carefuly n thoroughly clean with a cotton dapped/soaked in iso-propyl alcohol, also clean the souldered side of the pcb(s), if necessary look for dry soulder n re-soulder them..beware u must b a professional
Aug 02, 2009 | SAMTRON 55V 15" CRT Monitor
Removing back cover of samsung monitor 15'' crt 55v
I need some solutions to remove back cover for the CRT samsung monitor
Jan 17, 2009 | SAMTRON 55V 15" CRT Monitor
SAMTRON 55V 15 in.CRT
If the power cable is detachable, you can check it for continuity with a multimeter.
If you are aware of the hazards of imploding glass, high voltage, and x-rays, you might consider opening the monitor to replace a fuse.
May 23, 2008 | SAMTRON 55V 15" CRT Monitor
HOW TO OPEN COVER OF OVERSIDE?
first remove back side lock then take small pin like tuser insert into small hole & Push it up side it will open
Nov 14, 2007 | SAMTRON 55V 15" CRT Monitor
Open cover of Samsung Samtron monitor
remove two screws on lowerback of the monitor. Loosen the case at the botton and on the top. Two holes will appear on the top. With thin screwdriver push down inserting the screwdriver into this notch.This will release the case. Tks
Oct 30, 2007 | SAMTRON 55V 15" CRT Monitor
Problem with opening monitor cover
to remove the back cover of samtron 56 v monitor is very simple.
locate the 2 bottom screws of the cover, remove them. pull slightly back the cover holding the bottom and about half an inch gap will be seen. insert a flat screw driver straight down through the upper side hole with your left hand and hit the head of the screw driver with your right hand. a slightly big sound is heard and that side is disengaed. repeat he same with the second hole. and you have done it. try.
Oct 10, 2007 | SAMTRON 55V 15" CRT Monitor
Samsung SAMTRON 55V
just find it on http://www.eserviceinfo.com/download.php?fileid=4374 just vote for me so that i can help u again
Aug 29, 2007 | SAMTRON 55V 15" CRT Monitor
SAMTRON 55V 15" CRT Monitor Logo
136 people viewed this question
Top Samtron Computers & Internet Experts
Daniel Sweetlin
Daniel Sweetlin
Level 1 Expert
pankaj rautela
pankaj rautela
Richard Lilja
Richard Lilja
Are you a Samtron Computer and Internet Expert? Answer questions, earn points and help others
