Question about HTC TYTN GSM Phone
PHONE DOES NOT RING
DEAR SIR I AM UNABLE TO RESOLVE THE PROBLEM FOR THE PHONE NOT RINGING THE MODEL IS HTC TOUCH DUAL. HEADSET WORKS FINE . BUT WHEN I REMOVE THE HEADSET THE AUDIO OUTPUT IS NIL
I've been experiencing the same issue with my Tytn II!
My ringtone no longer works. The message tone works, but when someone rings me it just vibrates. I think it's something to do with the bluetooth handsfree i.e. it tries to route the ring through to the headpiece, even when it's disconnected. The exact same thing happened with my iMate jamin.
These PDA phones can be so irritating, they should really get it right!
  • 32 more comments
  • VIrritated Feb 03, 2008
    Yes it does. If I go into ring settings and test the ringtone, it works.
    I've deleted my paired headset, still doesn't work. I don't think there's a way to change the headset ringtone routing function.
    Clearing the jack plugs also didn't make a difference. Although I'm not sure why it will, the headset I use is not wired i.e. I use a wireless headset.
  • VIrritated Feb 04, 2008
    TPVijay,
    Checking that the ringer is on was the first thing I did. It still doesn't work. The only solutions I've been provided so far is to hard reset. There has to be another way.
    Otacon,
    I'm using the BlueAnt x3.
  • Anonymous Mar 11, 2014
    orange wrench light and B 13 on honda oddessey
    remove kia rio window crank
    my phone is saying initial programing needed.
    i went ridding the other day stopped somewhere for lunch and climbed back on and the clutch kept sticking in and slowly releasing or i would have to no kidding push it out ????
    GE JVM1630 microwave was working fine. Reset clock to DST and now with door open, the turntable rotates and it seems like it is heating. Close door and unit shuts down. Unplugged it, cleared it, etc. without luck. Tried heating coffee by holding door slightly open. Table rotated but the coffee didn't seem to heat up. HELP! Bill
    Using voice commands to navigate on a Windows 7 Operating system desktop computer
    Do not have manual or model number. The clock and timer are one knob with no directions on stove. Try to set clock and it always sets timer instead.
    need to update driver
    Indicator light on Coffee maker side does not come on, the hot plate is not heating and it does not brew. Expresso side still works perfectly
    Element broken
    Automatic not work
    i also have a grinding noise coming coming from my drive line, and i just changed the carrier bearing, is that an indication that i need transmission fluid, or do i need a new oil slinger?
    haow can
    My external drive shows up as a letter but I am unable to open the drive. I am asked to format or cancel. After I click on cancel, the message states "The volume does not contain a recognized file system. Please make sure that all required file system drivers are loaded and that the volume is not corrupted." This is a smartdisk firelite 40 gig external drive, several years old. I have quite a bit of information on the disk and need to retrieve. How do I recover this. I have tried the software from any data. The drive letter showed up but I get an error message "No Drive found. Please insert drive".
    replace heater core
    origional instructions lost
    simplex kaba 7000 lost code
    I have a santo 2340-8 kg and the warning light and sounder keeps beeping. temperature seems ok but i have turned the freezer on and off several times but it will not clear can you help
    I just opened and placed in a new black in cartridge, yet I cannot print anything due to the message; "Black ink cartridge needs replacing. Replace black ink cartridge. Press CANCEL to continue with non-printing operations." I even try to place the old cartridge and I get the same message.
    how to change the battery in 2004 hyundai sonata key fob
    huskey 33 gal aircompreesor will not shut off after max 150psi
    can I plug my ipod into the auxiliary cable to play music if so how do I change to aux on the setting on the player?
    very little water in rinse and darks come out all fuzzy
    lord elgin serie number J33197
    Adobe reader will not load on my 5s for free keeps asking for payment
    Need to get Internet other than wifi
    Just want to do maintenance on it.
  • Anonymous Mar 12, 2014
    how do i clear cookies on a samsung sgh i717 cellphone
    My truck starts and idles fine I can drive it on a little trip and pull up to stop and it dies but it starts right back up. Then sometimes I drive it and put it in reverse and it just dies
    floater sending unit already replaced with a new one
    Genius:
  • 3,422 Answers
Well try this out and let me know if it worked:
first clear r jack plug with a any pin like a cloth pin or paper attach pin .because there are lots of gumes or other thing
Goodluck,
Please don't forget to rate me as fixya..
Posted on Feb 03, 2008
  • Priya darshan Feb 03, 2008
    Alright go to this link below and ur problem will be solved..
    click here
    please don't forget to rate me as fixya..
    President:
  • 1,944 Answers
Does your phone output any sounds when the headset is not connected to it?
  • 2 more comments
  • Damen Wong
    Damen Wong Feb 03, 2008
    Did you check under bluetooth settings that rings are not routed to your bluetooth headset?
  • Damen Wong
    Damen Wong Feb 04, 2008
    Say, which bluetooth headset are you using?
  • Damen Wong
    Thanks...I will get back to you...
  • Damen Wong
    Damen Wong Feb 06, 2008
    What you are experiencing could very well be a bug with the bluetooth headset that you have. Do you have another pair to see if this problem persists?
  • 34 Answers
This might be due to the settings....
Ringer settings
To change the ring type and ring tone
1.
On the Phone screen, tap Menu > Options > Phone tab.
2. In the Ring type list, choose whether to be notified of incoming calls by a ring, a vibration, or a combination of both.
3. In the Ring tone list, tap the sound you want to use
You can find more information at the manual located at the below location.
http://www.htc.com/support/pdf/htctouchdual/NIKE_HTC_English_Manual_16-KEY.pdf
Refer the pages 33 & 83
I hope it will resolve your problem...
With Regards,
TPV
  • Vijayakumar TP
    Vijayakumar TP Feb 04, 2008
    Is it working now?....if yes please rate me as fixya. if not please provide me more details about what you did and and the corresponding results...
    With Regards,
    TPV
I would just like to ask on what to do regarding on sim card missing. the sim works just fine with the other phones. i have tried several sims with the htc touch P3450 but it does not read the sim. it...
You have purchased a htc handset which will work only on a particular service provider like AIRTEL OR VODAFONE,
check your default internal memory ringtone section , whether it has airtel ring tone ....
then by that service providers SIM CARD , your hand set will work.
some times dual band sim cards dont work on triband service providers.handset
Aug 19, 2010 | HTC Touch P3450 Smartphone
Facing peculiar problme with my HTC Cruise Phone
Hi Nitin,
Select the network manually and try if other parties are able to reach you without any trouble.
Jan 08, 2010 | HTC Touch Cruise Smartphone
HTC Touch Diamond will vibrate, but won't ring on incoming calls
I just had this problem - and I have been messing with it for an hour.... but I finally fixed it - Try this - touch the speaker symbol on top (The system status window should pop-up) then touch the speaker symbol again (Now you should have two tabs - one for system and one for ring) Touch ring and slide it up. This worked for me.
Aug 02, 2009 | HTC Touch Diamond Smartphone
Phone doesn't ring, but other sounds fine
:) Sometimes happens to me also. I faced a similar problem before, I think one of the installed programs on your device does it, I couldn't remember the name of the application now but whenever I launch it, my phone sound goes to minimum, Just to let you know. Have a nice day.
May 21, 2009 | HTC Touch Cellular Phone
HTC Touch HD - Vibrate function
The '********" is a little motor that spins with an offset weight. It sounds like the motor is stuck.
Feb 10, 2009 | HTC Touch Diamond Smartphone
Phone doesn't ring for an incoming call
try installing this Hotfix
http://www.htc.com/us/SupportDownload.aspx?p_id=88&cat=0&dl_id=101
Hot fix for resolving ring tone and system sound loss problem in HTC Touch Date: 2008-08-28     CategoryHotfix
In some cases, there may not be any ring tone and system sounds on the HTC Touch when the device has not been soft reset after a few weeks of usage. Performing a soft reset will resolve this problem. You can also download this hot fix and install it on your device to prevent this problem from reoccurring.
May 26, 2008 | HTC Touch P3450 Smartphone
PHONE DOES NOT RING
my phone wont ring it just frozen what do i do
Feb 02, 2008 | HTC Touch P3450 Smartphone
HTC TYTN GSM Phone Logo
179 people viewed this question
Top HTC Computers & Internet Experts
SANJEEV KUMAR SURI
SANJEEV KUMAR SURI
Tom Chichester
Are you a HTC Computer and Internet Expert? Answer questions, earn points and help others
