Question about Casio Databank DB35H1AV Wrist Watch
Casio illuminator Old battery is held in by a clip Do not know how to release clip have tried gently prising off but stubbon
    Master:
  • 619 Answers
Hi, release the small screw and turn left or right remove old battery and replace new one .
Posted on Feb 03, 2008
6ya staff
SOURCE:
How to change battery watche
Remove the back cover of the watch. You probably do not need a special tool to do this. The battery is likely right on top, held by a metal clip. Note the "polarity" and orientation of the battery, i.e., which end is up (take a picture, if necessary). Carefully remove the battery by gently prying up the clip that holds it in place. The battery type is engraved on it, and you will need to get a replacement of the same type or an exact equivalent. You could purchase one on-line or from Radio Shack.
With the replacement battery in hand, insert it back into its cutout within the watch mechanism, again gently prying up the clip. Make sure it's oriented the same as the original battery. Replace the watch back -- you may need to press down to make it click into place.
Sep 10, 2014 | Casio Watches
Replace battery on Casio DB-36-1AV
Open the back (4 screws). Careful with the rubber seal and spring inside. Use a pin to pry the battery clip away from the bottom of the battery. You need to pry the bottom out and up. When the clip releases, the battery is easy to remove/replace.
Oct 08, 2011 | Casio DB36-1AV Wrist Watch
I've removed the back of my casio db-36 watch, but I can't figure out how to remove the battery. The watch went blank last week.
There is a clip over the battery and then down on one side. You need something tiny and sharp... like a needle. You can insert the needle into the clip between the battery and the outside edge of the clip and gently pry the clip out and away from the battery.
Feb 06, 2011 | Casio DB36-1AV Wrist Watch
Casio module 2273 battery change
did u ever figure out how to get the retaining clip?
Mar 13, 2010 | Casio PRG-40T-7 Pathfinder
Older casio triple sensor has small metal bands(clips?)around the batteries ,how do you remove the old ones?
These small clips are just hooked around small prongs. You need a VERY small screwdriver (now that i think about it, a needle may work). Just pry the looped ends up and lift gently. I have done this a couple of times, however when I replace my batteries nothing happens. Last time I had to send it back - some info stated there was another battery deeper????? That is why I am looking into this now.
RDF
Mar 02, 2010 | Casio Triple Sensor Pathfinder PRG60-1AV...
How do you get the battery out of the case of a Casio AMW320RD-2AV? The back unscews and I can see the #370 battery held by some sort of blue band, but how to release it?
Under that blue band is the metal clip (contact). Take the tweezers and pull a little that blue band off, then find out where the contact is clipped on and undo it by pulling legs apart.. Buy exactley the same battery and replace it. Do make sure you wonn't plase the new battery other way round.
Rate, please.
Jul 22, 2009 | Casio Watches
How to release the battery clip on Casio Databank DBC-1500?
I would get it repaired by a Casio technician it will save a lot of headache. www.casiowatchrepair.com
Feb 24, 2009 | Casio DBC1501 Wrist Watch
Chabging the batterys on the prg 40
If you look very closely you will see that one side of the clip goes nearly under the battery. the plastic there has what looks like a small hole near the metal. It is in fact a slot. use a straight pin inserting it in the slot and gently moving the clip away from the battery. There is bend tension on the clip and it should raise slightly when released. Then use a tweezer grab the battery.
use your tweezer to hook the clip back over th plastic after you insert 4 new batteries.
Jul 01, 2008 | Casio PRG-40T-7 Pathfinder
Casio illuminator, w-94h
There is a tiny spring that must make contact with the back cover plate when you screw it back on. If the spring is missing, the piezoelectric buzzer will not work. The tiny spring is located toward the upper right in this photo of a Casio W-94H watch, directly underneath the "C" in CASIO that is etched in the metal. Note that the word CASIO is upside down in the picture, so if you can't see the picture for some reason, the hole for the tiny spring would be directly above the "C" in CASIO.
Nov 25, 2007 | Casio Sea Pathfinder SPS2011V Wrist Watch
Casio Databank DB35H1AV Wrist Watch Logo
318 people viewed this question
Top Casio Watches Experts
Janelle Schoonover
Janelle Schoonover
Ekse
k24674
Are you a Casio Watch Expert? Answer questions, earn points and help others
