Question about HP DeskJet 940c InkJet Printer
HP940C doesn't print the blue ink
I've installed two new cartridges but still no blue ink will print.
Appreciate your advice.
TIA
di
  • Anonymous Mar 21, 2014
    I just changed my toner cartridges out with new ink I purchased from ebay and it is printing solid Blue pages.
    Master:
  • 619 Answers
Hi, the printer need nozzle check you can determine what are the problem ink cartridge. , if blue does not display in nozzle check printer need head cleaning twice.
Posted on Feb 03, 2008
6ya staff
SOURCE:
I've installed a new ink cartridge for my lexmark x2500 and I did not receive a prompt to run a test and now my printer will not print. what can I do?
Check that the cartridge is properly i9nstalled. Unplug unit for about 5 minutes. Plug back in, it should re-boot and work.
murf427
Aug 29, 2012 | Lexmark X2500 All-In-One Printer
I have an hp psc 1215 all-in-one. My black cartridge won't print. It recognises if I swap it out for a new one, and goes through all the motions. It registers the correct ink levels. The cradle...
The problem is not with the ink-cartridges. You've proved that, by swapping BLACK cartridges.
The problem is that the ink-jets that spray the BLACK ink onto the paper are clogged.
Thus, no BLACK ink reaches the paper.
Open the HP Printing Assistant, and open Utilities, and run a few "print-head-cleaning" cycles, to try to unclog the print-head.
Jul 19, 2011 | HP PSC 1215 All-In-One InkJet Printer
The colour is not printing anywhere near the same as the image, its very yellow I have done the cleaning and the test print shows the blue to be very pale and I have tried 3 new ink cartridges, I did print...
Great job on cleaning the cartridges and even trying 3 new ink cartridges. Pretty much you did the basic troubleshooting already. This looks like a hardware problem but I strongly suggest you contact Lexmark technical support to further investigate the problem. Thanks.
Aug 12, 2010 | Lexmark X1270 All-In-One InkJet Printer
My prints are all coming out faded and light- i;ve tried to clean the nozzles and head adjust, the cartiges are all new. Any advice?
Did you use Epson Genuine Cartridges?
ALL…. Epson & Brother Requires Genuine Epson Cartridges. !!!!!!!!
That sounds like your problem.
In Purchasing Epson's CX 5400, CX4600, & CX7400 and more, I found out that Epson does not like Generic Printer Cartridges. I also Purchased a Brother. That also does not like Generic Print Cartridges. Color that should be Yellow, will turn out Green, Blue Brown, etc.
These printers have a CHIP that will detect if it is Generic or Genuine. When they see it’s Generic Cartridges, it will print lines thru the words, stripes across the picture and also do a mix match with the colors. It also will not let you print anything, if only one of the cartridges is empty.
I wanted to print only Black, and would not let me, because I did not have any ink in one of my cyan cartridges. Go figure.
That's what these Companies do., so they can keep selling the ink cartridges. Some Printers, are able to use Generic, and some are refillable. Some you can refill them up yourself and I heard, quite MESSY.
So I learned, thru trial and error, that you must use the ORIGINAL Genuine Cartridges for these PRINTERS. Some people say some models work fine compatible, but not mine.......
I had to replace the printer, but Epson, Lexmark & Brothers are always on sale. My Brother & Epson cost me $50.00 with Rebate. .
This is the only advice I can give you. If you find this helpful, pls rate me.
Thanks and Good Luck :0)
Feb 09, 2010 | Epson Stylus Photo R1800 InkJet Printer
Epson Workforce 600 "ink cartridge cannot be recognized" error
My printer quit printing blue after I cleaned the print heads. What can I do? I tried recharging the cyan cartridge and cleaning the print heads again. it's still not working! GRR!!
Aug 22, 2009 | Office Equipment & Supplies
Colour cartridge missing but I only want to print
No you cannot. Each one of your cartridges is smart chipped. When this cartridge registers as empty it acts as an on/off switch thus turning the printer off.'
You need to replace the empty cartridge in order to print.
Go printer settings and check option to print only black.
Jul 30, 2009 | HP Photosmart 3210 Printer
Printer S400 won't print out blue and pink ink
Hi..
The nozzles have gone bad...it needs to be serviced or replaced...i appreciate your efforts yoy put in to fix the problem thats best we can do after all its a machine.if the printer is in warranty contact the manufacturer.
Regards,
debroy
Nov 25, 2008 | Canon S400 InkJet Printer
No black ink print. Prints in light blue
Cartriges have a shelf life. It's printing in blue either because it has dried up or is out. Different cartriges have different timelines but if you haven't been using the printer often, it could have dried up or is simply out of ink. I would suggest first to try cleaning the head of the cartrige where the ink comes out with alcohol and a Q-tip and then if that doesn't work, buying a new black cartrige.
Nov 06, 2007 | Office Equipment & Supplies
Blue & yellow ink
Cheer Mom: I?m at Dell Headquarters in Austin, Texas and I just came across this post. Beyond what you've described, I don't think there are any troubleshooting procedures left to try. The cartridges are the only replaceable part on that particular model so at this stage I would say that it's time for the printer to be replaced. If it's still covered under a service plan, we would just send the replacement out free of charge with an airbill to get the old one back here, if not, one could be purchased. To be honest, I?m not exactly sure what the cause of the issue is but am fairly certain that you?ve covered most of the troubleshooting steps that would apply. Feel free to contact me if you have any questions. Neil Dell, Inc.
Sep 15, 2007 | HP PSC 2175 All-In-One InkJet Printer
HP DeskJet 940c InkJet Printer Logo
445 people viewed this question
Clive
Clive
Ekse
Thomas F. Schneider
