Question about Canon PowerShot S400 / IXUS 400 Digital Camera
Blank LCD screen
I've had the Canon IXUS 400 for quite some time now and has always worked without problems. However one fine day The LCD screen went blank. It can still take photos and I can see them on the PC, it can zoom and presumably focus but there is no way I can see what I am shooting. What can I do and will it be worth repairing?
  • 3 more comments
  • Anonymous Feb 04, 2008
    I'm not sure about the "DISP" switch as the camera was being used by my wife and later my son, though none claim to have modified the settings. The pictures on the PC are good, not different from photos taken when the LCD was working.
    At first there was a very faint "Canon" visible on screen as soon as it was switched on, but now even this is no longer visible.
    I suspect that the LCD backlight is the problem but I'm not sure.
    Also I opened up the camera (having already had to do so some 1 year ago as I had to remove the internal battery to reset the firmware back to default) and removed the internal battery but there was no change.
    Thanks for your replies. I did press the DISP switch but no luck. Thanks also for the info on the flash capacitor - I completely forgot about that. I had jiggled the cable before but with no useful results.
    Problem is, should I get a new camera with better specs or try to get a replacement screen (unfortunately I couldn't find the backlight on its own)?
    I checked the battery and at full charge (I charged it yesterday) it is reading 4.0V (+ and ground or + and -) - so I presume it's good.
    OK - It's almost fixed!! I decided to go through your suggestions once more and removed all connectors and reassembled. Just before closing the camera back into its case I tried it and it worked. I closed it and the screen went black again!. AFter several attempts it now appears to be a problem with a switch (switching between viewing and shooting). I will have to open the camera once more and see what's wrong with it - I suspect that on closing the case the external 'switch' is not aligned with the switch on the camera. Thanks for your tips t00nz.
  • eymoreno Feb 09, 2008
  • Canon Master
  • 4,738 Answers
First, let's try the obvious. Did you accidentally hit the "DISP" button (bottom row of buttons, third from the left)?
If not, you mention you can see the photos on the PC. Do they look fine, or are they also black or distorted?
Posted on Feb 04, 2008
  • 1 more comment
  • CameraR
    CameraR Feb 04, 2008
    Your mentioning of the faint Canon logo does suggest a backlight problem. You'll probably need to open the camera again. The Sxxx series cameras are particularly cramped inside, with many components jammed into a small space:
    http://www.ixus-world.de/index.htm?tips/...
    Would first suggest checking the LCD screen's ribbon cable connection to its connector. Reseat it or even just jiggle it to see if that reestablishes a good electrical connection. If not, next step would suggest replacement with another backlight and screen (suggest ebay looking for an S400 to cannibalize, BUT with a stated working screen). Here's some example replacements. Sorry no S series, but a lot of SD series:
    http://camerarepair.blogspot.com/2007/11...
    And finally, since you might be opening the camera, remember the shock hazard of the flash capacitor, and how to discharge it:
  • CameraR
    Oh but first, humor me and press the DISP button one time with the camera on, just to confirm that the LCD was not turned off.
  • CameraR
    Oh, there's one more obvious thing to check before opening the camera, the battery. When was the last time you changed out your rechargeable battery? If your still using your original S400 battery, it should be wearing out about now. You can check it with a voltmeter.
6ya staff
SOURCE:
No live display on LCD screen
This sounds like it might be a defective CCD imager. If so, Canon should fix this for you for free, including free shipping both ways. This is regardless of your camera's warranty status. Please check the following two links for more info:
http://camerarepair.blogspot.com/2007/11/canon-digital-cameras-showing-black.html
http://www.usa.canon.com/consumer/controller?act=PgComSmModDisplayAct&fcategoryid=225&modelid=13390&keycode=2112&id=29819
Applicable cameras include:
A40, A60, A70, A75, A80, A85, A95, A300, A310, S1 IS, S60, S200, S230, S330, S400, S410, S500, SD100, SD110, IXUS V2/300/400/430/500, IXY Digital 200a/300a/400/450/500
Mar 25, 2008 | Canon PowerShot S400 / IXUS 400 Digital...
Blank LCD Screen when in shoot mode
Mar 23, 2008 | Canon PowerShot SD100 / IXUS II Digital...
Blank LCD screen
you have accidentally turned the lcd pannel button off.just turn it on.
Feb 03, 2008 | Canon PowerShot A630 Digital Camera
Re Camera
If it also takes blank pictures, sounds like it might be a defective CCD imager. Don't know if dropping had anything to do with it. But if it's a defective CCD, Canon should fix this for you for free, including free shipping both ways. This is regardless of your camera's warranty status. Please check the following two links for more info:
Jan 11, 2008 | Canon PowerShot S400 / IXUS 400 Digital...
LCD Screen blank
Don't fret! This sounds like a defective CCD imager. If so, Canon should fix this for you worldwide for free, including free shipping both ways. This is regardless of your camera's warranty status. They just fixed my three year old A310 for free last month. Please check the following two links for more info:
Dec 17, 2007 | Canon PowerShot A310 Digital Camera
LCD is Blank when Camera is on.
Dec 16, 2007 | Canon PowerShot A75 Digital Camera
Canon screen problem
It sounds like your camera has encountered either a bad CCD issue, which is the image sensor capture device under the lens. Usually when it goes bad, you get crazy colors, or problems with the image. Or you might have a broken LCD, which can be replaced for fairly cheap as well. It is kind of hard to tell from your description with the problem. There is a pretty good company that might have a replacement CCD for you, they usually sell them for cheap 15-25 dollars, or a replacement LCD for around 60-100 dollars.
You can find them at www.darntoothysam.com
Dec 02, 2007 | Canon PowerShot SD100 / IXUS II Digital...
Lcd screen does turn on
This is a defective CCD problem that is known to Canon. They will replace the defective part for FREE. Go here for more details: http://www.imaging-resource.com/badccds.html
Nov 10, 2006 | Canon PowerShot A75 Digital Camera
Canon ixus 400
throw it and a new one a bit more modern.
Aug 20, 2006 | Canon PowerShot S400 / IXUS 400 Digital...
Blurry LCD
Canon S400 IXUS 400 ? Screen problems This is a known issue and Canon will fix it free of charge Go the the canon us or uk websites go to service then search for S400 (US) IXUS 400 (UK)
Aug 31, 2005 | Canon PowerShot SD400 / IXUS 50 Digital...
Canon PowerShot S400 / IXUS 400 Digital Camera Logo
127 people viewed this question
Top Canon Cameras Experts
old marine
old marine
Doberman
Ekse
Are you a Canon Camera Expert? Answer questions, earn points and help others
