Question about Shuttle ST61G4 (811686000310) Barebone
Power up on ST61G4
When powering up my Shuttle it just locks with the power light and the hard drive activity lights full on. The message "NO SIGNAL" appears on my screen. Constant switching on and off with the button on the front of the machine eventually resolves the problem and it then is ok.
Any ideas anybody
    Brigadier General:
  • 6,966 Answers
The "No Signal" display is an indication that there is no video output from your PC going towards the monitor. Cycling the power on/off a few times before the unit will start indicates there is a problem with the PC basic configuration. This may include:
1. Defective, dirty, loose memory sticks - clean or replace;
2. Defective, dirty, loose video card - clean or replace;
3. BIOS/CMOS settings too aggressive or not stable - set to default;
You can also try resetting the CMOS/BIOS to default settings by moving the reset jumper from its original position to the opposite end (1-2, then make it 2-3) temporarily. The reset jumper is normally very near the Lithium back-up battery. Alternately, removing the battery for an hour would also do the same, reset.
In some instances, it is the CPU fan blower that does not startup causing the system to halt. If so, it needs to be removed, cleaned, lubricated and re-installed.
At other times it can be cause by devices nearing end of its life. These may include the HD and the CD.
Still, this could also be caused by external devices which cannot be accessed/read at the startup such as a flashdrive.
Hope this be of some help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Posted on Feb 04, 2008
Green power light doesn't light. Is my data retrievable if the hard drive doesn't appear active. verified power supply is supplying the needed 12 volts.
It probably is but it is an expensive procedure. Try ERS data recovery services: 1.888.248.3148, they are good!
Dec 11, 2016 | Power Computers & Internet
I have problems in sarting up my EI System laptop ,the power light is on but no display on screen
The power light will only show whether power is reaching the machine. The important light is the hard drive activity light and perhaps the wireless activity light.
If the power light is all you have you should take your laptop to the computer doctor but if the hard drive light shows activity it would be worth connecting it to a separate monitor and if it then produces a display you might be able to figure out what has happened.
Sep 19, 2016 | Computers & Internet
When I turned on my system, it had system error contact xbox customer support. There is a red light flashing on the bottom right, around the power button. I don't know what to do. Please help.
Some of us suddenly when we turn on our Xbox 360 console one day we got one red light flashes on the ROL (Ring of Light) around the Xbox 360 power button, and we got an Error message appearing on the TV screen "System error" also might occur with any error code like E66, E67, E68, E71, E74 or E77, all the same.
When you get any of these messages appearing on your screen with one red light flashing on the ROL of your Xbox 360 console that's an indicator of a hardware problem with the console connection to one of the parts connected to it as the hard drive or cables.
So, first disconnect all power and AV cables from the back of your Xbox 360 console and also unplug the power cord from the wall socket, wait for a minute then reconnect them all back and try to turn on your Xbox 360 console once more.
If that doesn't work, it seems then to be a fault with your Xbox 360 hard drive so turn off the console again and remove the hard drive then turn on your Xbox 360 console without the hard drive, supposed then to work fine, it might be an intermittent issue and when you reconnect the hard drive your Xbox 360 will work fine all after, or it will just work fine without the hard drive so it will be then definitely a fault with your Xbox 360 hard drive so call Xbox 360 customer support to exchange the hard drive for you.
The Xbox 360 console might even keep giving you the same error code even after you remove the hard drive so it will then appear to be a fault with your Xbox 360 console not the hard drive & also in a case like this we need to contact Xbox 360 customer support to exchange the console.
Read more: http://xbox360help.blogspot.com/2007/03/one-red-flashing-light-xbox.html#ixzz14pQlSds6
Nov 09, 2010 | Microsoft Xbox 360 Console
What do the activity lights on the keyboard of the Dell Laptop C640 represent?
To the right of the power button and below the Dell AccessDirect button are three lights. These have a lock synbol below them. The first one from left to right is signified by a number 9, this light is turned on when the numberical keypad is enables. The center light is signified by a letter A, it is on when the uppercase letter function (Caps Lock) is enabled. the third one, far right, signified by a down arrow, is on when the scroll lock function is enabled.
The device status lights on the far right side near the front of the laptop case. The top light is the power status light, the middle light is the Hard drive activity light, the bottom light is the status light for power management, battery, AC etc.
Oct 17, 2009 | Dell Latitude C640 Notebook
Wont post led 3 flashes
if its the red flashing light on the tower, its the hard drive activity light.
when the monitor goes on stand by, does the tower retain power? (green light on and flashing red light sometimes?) Does your keyboard's scroll lock/num lock/caps lock keys and keyboard lights work?
Sep 07, 2009 | AOpen AX4SPB-UN (91.8AT10.013) Motherboard
Gateway laptop will not power on
Sounds like to me, that you do have power going to your computer(other wise your lights wouldnt be on), but that your hard drive is dead.
You can take it to a computer shop and have them replace your hard drive.
Dec 28, 2008 | Gateway MT6730 Notebook PC
Computer randomly fails to boot
how many video cards do you have installed?
Nov 14, 2008 | E-Machines eMachines Desktop PC
Toshiba Satellite P200 doesn't boot
Try pressing FN/F5 keys simultaneously, or the key that toggles internal/external Display. Look for the double screen Icons on the keys.
Tap the Pause Key.
Restart and press and hold F8 key when Toshiba logo appears. When the boot Menu appears, select Last Known Good Configuration.
If all else fails ther should be a reset button on the side of the LT. Consult owners Manual for location
Aug 15, 2008 | Toshiba Satellite A100-S8111TD Notebook
Processor issue? bios/motherboard?
First, Pull the hard drive. If the hard drive shorts out it can cause all sorts of problems. Generally it detects Hdd before mouse and keyboard.
Apr 18, 2008 | Averatec 3200 Notebook
No splash screen, no activity just lights (evo N610c) Plz help.
turn on your computer and do nothing,, when it seems the computer stop running key in fn+f4.
Dec 30, 2007 | Compaq Evo N610C Notebook
Shuttle ST61G4 (811686000310) Barebone Logo
252 people viewed this question
Top Shuttle Computers & Internet Experts
Iqbal Husain
Iqbal Husain
David
David
Alun Cox
Are you a Shuttle Computer and Internet Expert? Answer questions, earn points and help others
