Question about Fisher and Paykel GWL11 Top Load Washer
Fisher and Paykel mw051-u
Ehen i turn it on and set wash program, the hot and cold water both only seem to leak out of where it is supposed to come from, it sounds like the pumps are still working yet not much water comes out at all, i've tried changing from hot, cold, warm and yet still the problem occurs, i've double checked the inlets and the outlets aswell as the hoses and there appears to be nothing there that would restrict the water flow....... Please help?????
    Sergeant:
  • 351 Answers
You need to replace both inlet valves.
Posted on Mar 03, 2008
SOURCE:
Leaking fisher & paykel smart drive 501
Check your hot and cold hoses at the back for leaks,
these are just crimped on plastic ends and can crack and leak..
Jan 13, 2013 | Fisher and Paykel Washing Machines
I have a Fisher Paykel washer that was leaking water into tub; repair people changed cold water valve but it is still leaking; although not as much. Could it be the nozzle spray holding droplets of...
Hi just read your posting.1st try turning the hot water tap off and see if the water continues to come into the tub.If the water continues to come into the tub then turn the cold tap off.If the water stops coming into the tub after the hot water tap is turned off then you need a hot water valve.If the water stops after the cold tap is turned off then the cold water valve is still faulty.Please reply on how you got on and I will help you further.Looking forward to your reply.
May 16, 2011 | Fisher and Paykel Washing Machines
GW52F Fisher and Paykel Washing Machine Col...GW52F Fisher and Paykel Washing Machine Cold water valve does not seem to be letting any water into the washing machine, so it does not spray rinse or deep...
You are better off swapping the valves over in the machine until you can buy a replacement valve. I've done this for a month or so until I replaced the valve. Works as long as you only use a cold wash and your cold water is not too cold as to make the machine want to add some hot. If it does this then simply press start to clear the fault.
Jan 21, 2010 | Fisher and Paykel GWL11 Top Load Washer
I've got a Fisher and Paykel MW051-U washing machine. Everything seems to work fine, but after each wash cycle i notice that it is leaking water, i've tilted it and confirmed that the water is coming from...
access through the back panel to have a look at the drain pump which is likely your fault. Run a cycle and watch it when it drains you will likely see water leaking from the pump (about $25 and easy to change)
Aug 23, 2009 | Fisher and Paykel GWL11 Top Load Washer
Fisher & Paykel Washine Machine is filling up hot and not cold?
As nice as these machines are, I've read bad things about Fisher & Paykel reliability. It sounds to me like you have a bad solenoid.
FYI, you should leave the water lines on (both hot and cold) all the time, no need to shut them off unless you're unhooking the machine to move it or work on it. The machine should control the temperature itself.
Jun 14, 2009 | Fisher and Paykel (IWL12)
Fisher Paykel GWL11 Cold Water Not Flowing
you can swap the hot and cold valves over and see if this fixes the problem as it sound like your cold valve is faulty but not the hot valve.
Cheers
Mar 24, 2009 | Fisher and Paykel GWL11 Top Load Washer
Fisher and Paykel MW051 washing machine.
If you can stop it with your thumb there is NO DOUBT it is water pressure.. Pull the hose and check the tap direct, that will tell you if you have a plumbing problem of just a funky hose...
Good luck
May 08, 2008 | Fisher Paykel EcoSmart GWL15
Fisher Paykel eco smart washer top loader
If you talk with the company, they'll explain that their machines are designed to clean clothes in cold and warm water and that, in most instances, they don't feel "hot" water is at all necessary; especially if you use the soak cycle. You have to remember that the company is all about eco solutions and energy efficiency. They included the 'no hot water setting' work around just to as a customer accommodation. I haven't found that it takes all that much pressure, you just need to keep them depressed long enough for the unit to get the message and signal that it has.
Jan 16, 2008 | Fisher and Paykel Fisher Paykel Intuitive...
Fisher and Paykel GWL11 Top Load Washer Logo
226 people viewed this question
Top Fisher and Paykel Washing Machines Experts
Archie Ferrarini
Archie Ferrarini
Gerry Harvey
Gerry Harvey
jimorris77
Are you a Fisher and Paykel Washing Machine Expert? Answer questions, earn points and help others
